I've just completed replacing my Low Pressure Fuel Pump and fuel filter, connected the battery, started the car, and the below code appeared. I don't recall tampering with any electrical wiring to have cause this issue. The fuel pump works fine. Any suggestion as to where/what to check for this problem? Thank You.
2005.5 Audi A4 Quattro Avant
6 speed manual / 2.0T
Thursday,22,March,2012,10:21:21:38368
VCDS Version: Release 11.11.2
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Control Module Part Number: 8E0 910 517 C HW: 8E0 614 517 BB
Component and/or Version: ESP8 quattro H04 0180
Software Coding: 0004526
Work Shop Code: WSC 06325 000 00000
VCID: 2757D7EC96F635B
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x00FF
Hex Value: 0xFFAB
Hex Value: 0x00FF
