Results 1 to 40 of 56
    Veteran Member Four Rings Oompous's Avatar
    Feb 07 2010
    2001 S4, 2006 C320 Sport
    Los Gatos, California
    How bad is anti lag for a turbo.
    I'm sure this subject has been beaten to death multiple times but for some reason all my searches yield nothing but "OMG I JUST GOT ANTI LAG" threads.
    So in all honestly if you rarely use anti lag how much is it going to shorten turbo longevity?
    and when i say anti lag i dont mean 2 step. i mean anti lag while shifting.
    like dis.
    Jonathan
    Santorin 2001 S4
    TiAL 605.2 | 034 | Apikol | ABD | AWE | MTechnica Turbo 18x9.5 et18
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    anti lag is hard on turbos, creates a ton of heat. But as long as you don't launch at every light you should be ok.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Feb 07 2010
    Quote Originally Posted by CELison View Post
    the anti lag file a friend found on nefmoto also has anti lag at 5500 shifts. is that worse than launching?
    Jonathan
    Santorin 2001 S4
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by Oompous View Post
    it creates a lot of heat as the fuel ignites in the manifolds and exhaust. I have anti-lag launch control and no lift shift. I use the NLS more, and so far my turbos are still alive.
    B9 S4- EPL/AWE
    Feb 07 2010
    how long have you had it?
    and how does your anti lag work?
    Jonathan
    Santorin 2001 S4
    Aug 14 2011
    1988 300zx, '00 s4
    Port Coquitlam, BC Canada
    Probably harder on valves depending on how the system is set up. If the mixture within the cylinder is exploding with the exhaust valves open, it will probably burn up valves. Not sure how the one on the audi is set up but the aftermarket kits i've seen operate like that.
    Daily:
    2000 S4. Stage 2 6spd, APR Tune, 2.5" catless DP's to 3" vibrant ss exhaust, KW-V1 coilovers, 18x8 RPF1's and winters on stockers.
    http://img29.imageshack.us/img29/6043/mg1746sized.jpg
    Project:
    1988 300zx GT35, Stance Coils, 18x9.5/10.5 Varrstoen 2.2.1's, lots else.
    http://img696.imageshack.us/img696/1483/profilent.jpg
    Veteran Member Three Rings greg@dubaudi's Avatar
    Feb 05 2005
    2001.5 pearl WB Avant, 2016 SQ5
    Alton Bay, NH
    If anything it looks fast and cool with all the flames and popping.
    2001.5 EPL/Tial 770 Pearl WB Avant///2021 SQ7 Nimbus Grey///2021 GMC 3500 Duramax
    May 13 2011
    2015 BMW F30
    Cool video.
    Sep 17 2005
    Fremont, California
    Spark plugs get eaten like candy.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    also make sure you aren't running cats
    Feb 07 2008
    The boonies, near Seattle
    This thread is relevant to my interests.
    To clarify,
    nls = foot planted on floor throughout run without over-revving motor
    Anti-lag = keeping turbos spooling during shifts so there is no lag on respool.
    Correct?
    -dre
    Aug 14 2011
    1988 300zx, '00 s4
    Daily:
    Project:
    Jan 29 2009
    To clarify,
    Correct?
    yes... although NLS will essentially do the same as anti-lag... although true anti-lag will work on downshifts too (via a throttle kicker, etc)
    Jul 28 2008
    01.5 S4, 09 Touareg, 88 Cabriolet 16vT
    Pittsburgh PA
    no one here needs anti-lag... if you are making or breaking your runs on an RPM dip during shift, you wouldn't be on here asking about it. If you are, you don't need it on a streetcar... and use your programming to protect the motor... rally drivers eat turbos because of this and really, current rally, uses much more complex computing to achieve safter 'anti lag'...
    if you are asking about longevity and considering this, you are mixing two unrelated items lol.
    Senior Member Two Rings zakario's Avatar
    Mar 19 2009
    2001 pearl S4 6 spd, e36 M3
    Albuquerque NM
    I have been religiously trying to kill my current transmission and turbos and have launched with anti-lag over 60 times in three months. I also use NLS to third and fourth all the time with no signs of wear. My transmission actually shifts smoother now
    This is not a recommendation that it is fine. Just giving my experience
    Active Member Four Rings nthusiastt's Avatar
    Oct 27 2008
    B5 S4 Avant
    probably pretty tough on clutches as well...
    Aug 29 2009
    London
    Quote Originally Posted by nthusiastt View Post
    The two main problems are you will kill the Clutch and Cats that's all but it all depends how often you use it
    AUDI A6 C6 3.0 TFSI MRC tuning stage 2 package plus Milltek Sport cat-back system
    Traffic Exchange Site http://www.24-7-traffic.com/
    Feb 23 2010
    Emmaus Pa
    I probably have 50 anti lag launches and 150+ nls. no issues
    B9 S4- EPL/AWE
    Veteran Member Four Rings Rdp616's Avatar
    Mar 23 2009
    Hibiscus S4
    SW, Pennsylvania
    No, you don't really need it. But who doesn't like to shoot flames on the asshole behind you?
    Single Turbo Hibiscus coming soon
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    I use my 2-step9launch control,) but I dont see a valid use (with k04's) when I have WOT shift(anti-lag) engaged. Twin turbo instantly spools. .
    Mar 19 2009
    Albuquerque NM
    Quote Originally Posted by ThirdStrike View Post
    I use my 2-step, but I dont see a valid use (with k04's) when I have WOT shift(anti-lag) engaged. Twin turbo instantly spools. .
    You're not pushing it
    Feb 07 2010
    To clarify,
    Correct?
    anti lag is launching, NLS is shifting
    Jonathan
    Santorin 2001 S4
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    WOT shift=anti-lag=no lift shift
    2step = launch control
    They all do the same thing; Limit rpm rev to a specified rpm limit while retarding ignition timing while allowing fuel to dump, creating combustion boost and exhaust fire (if you dont have cats)
    Feb 07 2010
    I wonder if you can get pulled over for it. or would it just be for exhaust? i cant see any police being like "oh you got no lift shifting you're screwed."
    Jonathan
    Santorin 2001 S4
    Feb 23 2010
    Emmaus Pa
    I highly doubt that. I wouldn't recommend doing anything WOT around a cop. Only around your buddies, people you are racing, and girls you want to impress with your display of fire and noise
    B9 S4- EPL/AWE
    Mar 23 2009
    Hibiscus S4
    SW, Pennsylvania
    And girls you want to impress with your display of fire and noise
    LMAO
    Feb 07 2010
    im not saying i would WOT around a cop. im just saying perhaps one were hiding around a corner on an onramp
    and impressing the girls goes without saying.
    Jonathan
    Santorin 2001 S4
    Veteran Member Three Rings zdriver's Avatar
    Jan 17 2010
    Boston, MA
    Well worth it
    Veteran Member Three Rings dubzackvr6's Avatar
    Oct 18 2010
    Stage 2 C7 A6, Tahoe for the kiddos
    SLC, UT
    what girls?
    Veteran Member Three Rings skinnytirez's Avatar
    Dec 28 2007
    GSXR 1000, 2010 A4
    Hayward, CA
    lol- the cop is going to be way more concerned with your speed than the fireball you are shooting... 2nd gear tops at appx. 65mph
    That being said I have been using anti-lag only when "girls you want to impress with your display of fire and noise" and NLS for over a year and haven't encountered any issues.
    I never use the NLS on shifts from 1-2 as the 1-2 shift collar in our transmission is garbage...
    Feb 07 2010
    Quote Originally Posted by skinnytirez View Post
    im wanting this shit more and more by the second.
    Jonathan
    Santorin 2001 S4
    Feb 23 2010
    Emmaus Pa
    B9 S4- EPL/AWE
    Oct 27 2008
    B5 S4 Avant
    Established Member Two Rings maxxxs4's Avatar
    Feb 14 2011
    Quebec
    I dont really understand exacly how does the anti lag and no lift shift work, I am confused. Could someone explain it clearly please because my J fonz tune is set up with a 4000 rpm anti lag and 5500 no lift shift. My car is still waiting for the flywheel so its not running right now. Thanks
    audi S4 2001 misano red . J-Fonz tuned FT's on meth
    Feb 23 2010
    Emmaus Pa
    als- Retards timing and dumps fuel, ignition happens in the manifolds to spool the turbos without any load on the engine.
    nls- cuts spark when clutch and gas are pressed in @ a specific rpm and over (usually 5500 or so) This allows the tb to stay open, the fuel being dumped along with the tb being open keeps the turbos spooled between shifts.
    B9 S4- EPL/AWE
    Feb 14 2011
    Quebec
    Alright thanks, would water/meth increase or decrease the potential risk of damaging the engine or there is nothing to do with it at all ?
    Feb 07 2010
    Quote Originally Posted by maxxxs4 View Post
    would just require different timing retardation and such
    Jonathan
    Santorin 2001 S4
    Jul 26 2009
    00 S4, 01 S4, 93 RX7 LS1/T56
    Dallas
    I think you guys are making this a bit more complicated than it needs to be. As I understand it the tuners that are adding NLS and ALS to our factory ECU's are doing it very simply. In essence they are adding 2 extra rev limiters that work by retarding the ignition timing. As people have already said when you retard the crap out of the timing the spark plug fires when the exhaust valve is open and all of that energy makes it's way directly to the turbine wheel instead of pushing the piston down and raising rpm. There aren't any extra air valves or injectors being added like some high end racecars use.
    The normal rev limiter is only active when the clutch is engaged.
    The second highest rev limiter (NLS) is only active when the clutch is disengaged AND you are moving.
    The lowest rev limiter (ALS) is only active when the clutch is disengaged AND you are stopped.
    For example say you're rev limiter is set to 8krpm, your NLS is set to 6krpm, and your ALS is set to 3krpm.
    When you get ready to launch you push the clutch in while stopped and got WOT which actives the ALS so you sit there are 3krpm. When you let the clutch out the ALS is immediately disabled by the clutch being engaged and the car starting to roll. You wind first gear out to 8krpm where the rev limiter shuts things down. You push the clutch in to shift which activates the NLS and drops the engine down to 6krpm. You make your shift and continue on through your run up to 8k, clutch in for a shift down to 6k, etc etc. The throttle stays wide open for the entire run.
    Chris Sanders
    02 A4 Avant
    01 Noggy S4
    00 BB S4
    1993 RX7 w LS1/T56
    Sep 11 2009
    NE
    The Me7.1 implementation you're all talking about is very simple. There is no retardation involved at all in either NLS or 2-step. Both work by just intercepting and interrupting spark event over a set engine speed limit (RPMs) .
    The net result is that the engine is still fueling like normal while the spark event is suppressed. This results in completely unburned mixture from no-spark event to travel down the manifold where it ignites once in contact with hot manifolds or when next batch of, this time ignited and hot, air arrives.
    Hence the fireballs.
    The code to accomplish this is very simple and you can see it on nefmoto.com where I started the original thread on NLS/2-step implementation on me7.1. With a help of couple assembly gurus, the code was developed and upgraded to incluede bells and whistles like clutch pressed condition, rpm and speed level for 2-step, rpm and plate angle levels for NLS.
    Enjoy.
    Jan 29 2009
    Quote Originally Posted by julex View Post
    Enjoy.
    Sums it up right there...
    All the more reason to see why a well liked tuner that is charging for NLS and ALS for code that isn't even theirs... they just took it from a community and started selling it as an "option"
