There is a black rubber spring like cover under the control arm that sort of disappears into the wheel well. Well, it has some play in it when the wheel is turned back and forth (instead of moving in and out, there is some up and down movement too). It's almost like a joint that's loose, or something is broken inside that rubber sleeve.
Is that the cv boot?
Can whatever is inside of that sleeve be tightened?
If it is the cv boot, how much should I expect to pay to have it replaced?
Whatever this problem is - do you recommend that I also have the same parts replaced/addressed on the driver's side?
Is this a job that is straightforward enough for my local Sears or pep boys to handle? (we all know how those dealership labor fees can get)
I'm currently at 92k. While they're in there fixing whatever is inside that rubber sleeve, will the tech have easy access to the front shocks? If so, should I replace them?
