Results 1 to 11 of 11
    Established Member Two Rings eugrub's Avatar
    Jan 06 2012
    2006 Audi S4
    Vadnais heights, MN
    Fog lights turns on when I turn off engine
    When I turn off the engine and open door then fog lights will come on even when headlights switch are turned off. It will go away in 1-2 mins. When I unlock the car with my remote and the foglights will turn on but if I open the door, fog lights will turn off. WTF? Can Vagcom get rid of this? If so, whats setting? LMK thanks man
    Veteran Member Three Rings Mani's Avatar
    Dec 21 2009
    2008 BMW 335i - Dinan Stage 3
    Irving, TX
    Are you referring to the coming home feature? If yes, it can be turned off using the small knob on the drivers left hand side right next to the cluster.
    Veteran Member Three Rings Time4Audi's Avatar
    Jan 15 2007
    Massachusetts
    It is actually more like a knob that pops out and allows you to turn off the feature - I = on / O = off.
    It is to the right of the headlight controls.
    Established Member Two Rings V8Beast's Avatar
    Mar 28 2011
    Earth
    I love that Feature
    Dec 21 2009
    Irving, TX
    Yes... I have 2 knobs there.... DRL and Coming home feature.
    Jan 06 2012
    2006 Audi S4
    Vadnais heights, MN
    Problem solved. I feel like an idiot lol Thanks guys!
    Senior Member Two Rings Trogdor1464's Avatar
    Apr 20 2011
    IL
    You didn't read the owners manual, did you?
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    No one ever does Trogdor1464!
    Veteran Member Three Rings nicotino15's Avatar
    Jul 24 2011
    2016 Q5 3.0T
    DFW, TX
    yeah, you can turn them on and off via the little knob, but you can adjust the length of time they stay on via vag-com. I think I adjusted mine down bc they stayed on for so long, can't remember what they are set at though.
    Established Member Two Rings richmeyer's Avatar
    Jan 24 2012
    where in the owners manual is that feature? I've seriously looked through the manual twice looking for it. I'm no dummy either...
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by nicotino15 View Post
    Default is 60 seconds.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
