I'm hoping that someone can describe how exactly the coolant reservoir on this car (2003 1.8T Quattro in my case) is supposed to work as I am experiencing a mysterious rapid loss of coolant after doing some major work on my vehicle: timing belt/water pump, head replacement (swapped my AMB with an AEB) and check valve simplification + removal of SAI pump system (AEB head can't use this anyway.) This was all done after my timing belt failed prematurely (after just 35,000 miles due to a seized water pump) and resulted in 12 bent valves
Anyway after 2 months of work my car was finally ready to return to the roads! Being anxious to see how it ran I quickly filled the coolant, power steering, checked the oil and went to start it: somewhat to my surprise it actually came to life and ran smoothly nearly right away (idled rough at first but quickly smoothed out.) I took it for a drive and was very happy with how everything was performing: engine was smooth and quiet, and besides a noticeable turbo lag (which I understand is to be expected when going to a large port head while still using the stock turbo) it seemed to be performing 100%. Not long into the test drive my temp started to rise above the 1/2 way mark and I immediately pulled over and let the car idle as the gauge rose to about 3/4, coolant light came on briefly and quickly went off once the temp dropped back down to 1/2. Being just a few miles from home I carefully drove it back and the temp gauge stayed at the 1/2 way mark for the rest of the drive.
After some research it occurred to me that I more than likely had enough air trapped in the cooling system to prevent the coolant from properly flowing and I would need to bleed all the trapped air out...of course! I proceeded to re fill the coolant reservoir (which was almost completely empty by now) open the bleed valve and run the car with the heater turned all the way on to see if I couldn't get all that trapped air out of the system. Sure enough I first got a lot of air bubbles coming out of the valve and eventually mostly coolant but once the engine had heated up I was getting hot coolant sputtering all over out of the bleed valve with intermittent pockets of air but still no heat in my car. Being that this was creating such a mess I decided to shut it off and continue to bleed the system by attaching a hose to the bleed valve opening and collecting the hot coolant in a bucket. Continuing to bleed the system I still wasn't getting any heat so I decided to rev the engine a bit while carefully watching the temp gauge. After doing this my heater finally kicked on and I continued to get heat after letting it idle for some time. Satisfied that I had removed all of the air from the system I first pulled the the hose and closed the bleed valve before shutting off the engine (I was told to do this by a mechanic friend of mine to prevent any air from being drawn back through the open bleed valve after shutting off the engine. I then re filled the coolant reservoir and took it for another drive. This time I was able to drive it hard and keep it in the power band for a sustained period of time without the temp gauge ever rising above the 1/2 way mark. I drove it for maybe 10 miles all while doing a number of hard pulls with no signs of cooling problems until I was nearly home. Yet again the temp gauge began to rise above the 1/2 way mark and I immediately let the vehicle coast while the temp continued to rise just slightly above 3/4 before quickly returning back to 1/2 again (the coolant light also briefly came on and went off once temps were back down.) I very carefully drove it the remaining 2 miles or so to my house with the gauge staying at 1/2 and to my surprise my coolant level was suddenly back down to nearly empty! I carefully checked everything over for leaks and after not finding anything gave it some time to cool down before filling the coolant again and taking it on another test drive with nearly identical results: the vehicle performed flawlessly for about 15 miles of spirited driving then temps started to rise and yet again I was nearly out of coolant
After shutting it off I carefully inspected the engine bay as everything cooled off and noticed the sound of air leaking from somewhere. I found that the air was coming from an opening underneath my coolant reservoir that appears to simply be an open channel leading to the top where the cap threads on the reservoir and my guess is that it's purpose is to prevent overfilling the reservoir? I'm wondering if this channel should be open to the reservoir when the cap is closed (which was the case on my vehicle as air was rushing through it as the vehicle cooled off with the reservoir cap securely screwed on. Is there supposed to be some sort of O ring or gasket that is meant to seal this channel off when the cap is in place that was perhaps misplaced during all the work I did on the vehicle over the last 2 months? If anyone could post some high res pics of a properly functioning reservoir cap that I compare mine to that would be extremely helpful! I am continuing to check all coolant lines and connections for leaks and can't find anything so my guess is that when the coolant reaches a certain temperature it is vaporizing out of my reservoir and after looking closely around the engine bay surrounding the reservoir this does seem likely as I can see a fair amount of condensation. Any help is greatly appreciated, I have gone through a ridiculous amount of coolant already and would prefer not to lose another gallon of it before understanding how exactly this system is supposed to work
Dan
