I am really contemplating removing the ABS system from my car when I upgrade to my big brake kit, for a number of reasons. Simplicity, more adjust ability (i can run a proportioning valve), better for competition and winter driving (if you know what you're doing).
is it as simple as taking the output lines from the master cylinder and send one to a tee for the front brakes, and one to a tee for the rear brakes? Can I keep the ABS module "plugged" in avoid the beeping and blinking of my abs light when I'm driving?
Ideally I would like to install dual master cylinders for f/r with balance bar for brake bias, but this requires removing the ABS.
