Results 1 to 29 of 29
    Jun 30 2009
    2010 Audi A5 2.0T
    Calgary, AB
    When to change Engine Air Filter?
    Hi everyone,
    I've searched everywhere and I can't seem to find an answer to how many Miles/Km do you change the Engine Air Filter on a 2.0T Engine ?
    I have Audi Care and I looked at the schedule and there is no mention of Engine Filter change. There is the oil, and dust/pollen filter but nothing on engine filter.
    I just had my 55K service and looked over all my maintenance schedule invoice and not once Audi has changed my Engine Air Filter or a suggestion that it should be changed at a certain time. I haven't had a chance to looked in my owners manual yet, but I'm sure an expert on here can answer my question.
    For those who have Audi Care, has Audi changed your Engine Air Filter?
    Are they trying to cheap out on this? Or is it just not part of the maintenance schedule?
    Thanks in advance for your answers!
    Veteran Member Four Rings jeffrey146's Avatar
    Feb 19 2012
    04 S4 nogaro avant MTQ, 2013 CT200H F sport, 93 EG hatch
    Draper, Utah
    As a rule I would say about 10k miles or a year. However, if you drive lots of dirt or sand i would say more often. I would recommend a K&N reusable filter. It'll save you money in the long run.
    Nov 10 2011
    Illinois
    55K as per Audi manual. Do not try the K&N. While K&N might be nice for other cars the fitment is horrible on most Audis and the oil can destroy the MAF. I dont know of hand how often you are suppose to replace after that but around 30K or so.
    Current: 2014 Audi A5 2.0T P+ | 3M Colorstable 35% Tint | Brilliant Black | Chrome Grill Inserts | Interior SMD LEDs |
    Previous Ride: 2009 Audi A4 2.0T P+ | 3M Colorstable 35% Tint | Meteor Grey | Chrome Grill Inserts | Blesk SMD LEDs - license and under-door |
    Jun 23 2010
    Athens, PA
    I was always under the impression that it was 10k miles as well. However, no matter what filter you have, stock or otherwise, I would still service it every 10k miles.
    Apr 11 2011
    clutter
    hawaii
    Quote Originally Posted by kstrohm View Post
    K&N states that it's just an excuse dealerships shell out just for you to buy and force you to replace your filter. Hope they are correct because that's what I am running.
    http://www.knfilters.com/maf/massair.htm
    -roger
    Stock...
    Jun 30 2009
    2010 Audi A5 2.0T
    Calgary, AB
    Thanks for everyone reply so far.... I just checked my Audi Maintenance book and I still don't see anywhere that mentions Engine Air Filter??? Maybe I'm going crazy, but I couldn't find anything that states a mileage where the Engine Air Filter is to be changed? Unless this is assumed to be changed when the Engine Oil & Oil Filter is changed??
    Veteran Member Four Rings maga4's Avatar
    Aug 12 2011
    Olathe, Kansas
    Quote Originally Posted by tenfour View Post
    Thanks for the link. Looks like they will even back you up if the dealer claims an issue for it. Sounds good to me.
    2010 A6 3.0T Prestige, Quartz/Black
    35% Tint, VCDS, Hardwired V1, LED Interior/License Plate, Chipwerke Pro, WeatherTech
    Previous: 2011 A4 P+, APR Stage 2, 35% Tint, Eibach Pro-Kit, VCDS, Gloss Black Grille, Fogs,
    LED Interior/License Plate Lights, Short Shifter, BFI Catch Can, V1, Rieger Lip Replica, FRT's FMIC, aFe Filter
    Aug 27 2008
    Houston Area
    Quote Originally Posted by acjetpilot View Post
    US schedule, but has Km as well : http://www.audiusa.com/us/brand/en/o...intenance.html
    Air filter is shown as a 55,000 miles, 85 Km swap - 55,000 miles is after AudiCare runs out, so I'd assume 85Km would be for you as well?
    For those saying to change it at 10,000 miles - what kind of s*#@ conditions are you driving through?
    I had mine out at around 20,000 mi and I was amazed what good shape it was in.
    2013 6MT S5 - Monsoon/Black
    Prem+ | Sport diff | Adaptive dampers | Nav | B&O
    Res AWE exhaust | USP intake | USS Sways | OEM 19" speedline | AluKreuz | 034 Trans mount | Interior LED | VCDS tweaks | F1 tint | Xpel PPF
    Previous : 2009 6MT A4 | Quartz/Black | Prem+ 2001 5MT A4 | Silver/Black | Premium pkg
    Veteran Member Three Rings gunsmoker's Avatar
    Oct 24 2011
    Mansfield,MA
    You can get a washable dry performance filter: http://afepower.com/shop/details_new...0L&&brandID=59
    Select Dry Pro S. It's currently out of stock. That's what I have and I'm happy with it.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    About 20-25k for me. I drive 60 miles a day/6 days. Most of that is in conditions where I use the "recycle air" button on my dash. Just swap it out now and see how bad it looks. From that you can judge +/- going forward.... OEM filter is not too expensive....
    Oh and make sure to clean the other filter on the grille side... That one prevents moisture from getting in, but can get clogged easily.
    -cW
    2023 X3 M40i Alpine White
    Jun 30 2009
    2010 Audi A5 2.0T
    Calgary, AB
    Quote Originally Posted by B8_Jim View Post
    Thanks for the link, it's the same schedule I have. It's "dust and pollen fliter" that is replaced at 55k. I don't see the Engine Air Fliter? That's what confuses me on this schedule.
    Oct 24 2011
    Mansfield,MA
    They call it "Air Cleaner".
    Jun 30 2009
    2010 Audi A5 2.0T
    Calgary, AB
    Quote Originally Posted by gunsmoker View Post
    So I called up my Audi Dealer and asked when the "Air Cleaner" is suppose to be replaced. Their answer was at 55K miles which equals to 85K KM. I swear this doesn't sound right, and I checked the Audi Care schedule and it does say replace at 55K miles. I'm assuming these air filters are super good, otherwise that's a very long time for Audi Care to change the Air Filter.
    Aug 27 2008
    Houston Area
    A VERY long time, as audicare stops after at the 45K mile service...
    Mar 02 2007
    Fresno, CA
    Don't wait until 55k to replace your filter. Here's what mine looked like the first time I changed it...
    Now I change it at least every 20k.
    Jun 30 2009
    2010 Audi A5 2.0T
    Calgary, AB
    Thanks Blake,
    I'm going to change it for sure. I'm just surprised that Audi's recommeded change interval is so high. Stupid me , I just assumed when they did servicing that a air filter would be something they would include with Audi Care.... I didn't even think to check until now.
    Oct 24 2011
    Mansfield,MA
    It's not that the filter is super good. It's how the box is designed. There is a snow screen at the mouth of the funnel. It's more accessible and is to be cleaned at 15k, 55k, 95k, etc. miles. That picks up the big particles. Then there is the U path, at the bottom of which there is foam plastic that can pick up the heaviest particles. The Carbonio box, for example, gets rid of the U path to supposedly improve the flow, but it affects the filtration quality. Truth in engineering, Audi says.
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    What miles did the AFE users changed theirs?
    Sent from my HTC One_M8 using Tapatalk
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Established Member Two Rings dbv2's Avatar
    Mar 06 2016
    To
    The interval is for 85,000 km. That's my next service interval. It's about a $500 odd visit to the dealer. It's an oil change, engine air filter change, and cabin air filter change. Everything is straight forward, I don't know but haven't looked up how to change the cabin air filter myself but it's a service interval I don't plan to have done by the dealer. The next service is just an oil change. And the one after that is spark plugs at like 115. Pretty simple stuff if you're at these intervals.
    Jul 08 2015
    Quote Originally Posted by dbv2 View Post
    Most itll take you is 2 mins to change the cabin filter. 3 screws to be unscrewed under the passenger dash.
    May 20 2014
    IL
    I did it with afe dry filter at 30000 miles. Stock filter was dirty as hell i would not wait till 85000
    Mar 06 2016
    To
    Quote Originally Posted by JeriQo View Post
    Really? Interesting, I'll have a look. Is there a DIY you can point me to? I'll probably grab both air filters from my dealer Tuesday. I have a service appointment, my mech pulled up 4 fault codes relating to defroster flapper motor failure. I just picked my car up Friday, so I'm a bit upset the car wasn't fully looked over prior to delivery. But I was told it should not cost me anything given the fact I just got the car a week ago.
    Quote Originally Posted by jtwlebrd View Post
    He's referring to kms not miles, he is from Canada.
    Jul 08 2015
    Check youtube or carcarekiosk.com. the dealer priced me 92 bucks which is a total rip off. The filter is only 14 bucks.
    The diy video on this is literally 15 secs long. Thats how easy it is. Even my gf changed the air and cabin filter herself.
    But for the b8, check under the passenger dash,unscrew 3 screws, pull open that foamy cover and pull the filter out. Replace.
    Apr 05 2016
    Central NJ
    I just changed the engine air filter on my 2016 A6 2.0T. I bought a replacement filter on ebay. WIX 49343. Fit perfectly. Cost was a shade less than $19.00. Install was embarrassingly simple. I just wonder what the cost is at a dealership. Yikes.
    Jul 08 2015
    Quote Originally Posted by Pinspector View Post
    close to 100 for just the cabin.
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    Yeah 100 bucks easy at a dealer for the engine air filter. I changed mine around 50k and it could have easily gone another 10k. It wasnt very dirty. It really just depends on your driving conditions.
    Current: 2013 A4 TFSI | Past: 2010 A4
    CAEB Longitudinal EA888 Gen2 155kW
    MPG 24city 31hwy
    Senior Member Two Rings LGHT's Avatar
    Jun 07 2018
    CA
    Not to side track the discussion, but I've always put K&N in my cars, but when I talked to the audi shop who will be servicing my car (first time owning an audi) he said leave the stock paper in as the K&N's will ruin your car. This comes from a shop that does 50% service and 50% racing, builds and tuning.
    Veteran Member Three Rings BrewDude's Avatar
    Mar 13 2009
    04 R32 FT450
    KLAS
    I check it every other oil change. If it's dirty it gets cleaned. Mind you I have an Afe filter and live in the desert, so dust is a concern here choking out a filter. Had a Pipercross filter and it disintegrated in my air box and made for a fun time cleaning the mess up. Fortunately it didn't foul up the MAF.
    Sent from my Pixel 2 XL using Tapatalk
    Senior Member Two Rings RLwantsS5's Avatar
    Jul 11 2014
    2022 Lexus Ux200 (wife)
    Bonita Springs, FL
    I did pro 5 r engine filter from ECS. Love it. Slight whistle between 2500 and 3000 rpm. Did it myself. Took 10 minutes. Reusable.
