Results 1 to 6 of 6
    Veteran Member Three Rings estomax's Avatar
    Jan 16 2009
    07 A6 Avant 3.2L, 13 Leaf, 08 Titan
    help me with vibration, 5 mm spacers, hub rings 66.6 to 57.1mm
    hey guys,
    so i went out and got myself some 2011 A4 wheels, thinking this would be a nice subtle OEM upgrade to my stock 17s. The old wheels are 17x7.5et45 and the new ones were 18x8et47 so i figured that is pretty darn close and should fit just fine. Now the other thing i didn't know is the fact that these are 66.56mm hub while the 2003 a6 i have is a 57.1mm hub. I also went from 235/45r17 to 245/40r18 tires, which maybe if i hadn't gone wider would have saved me from needing spacers.
    Once the tires were put on the rims they scrubbed on the upright, so the tire shop said i need to either grind the upright or get spacers to make them fit. I went out and got some 5mm spacers and was able to fit the wheels and no more rubbing - yay!. now the problem was that above 45 mph i had a shaking issue. The local tuner shop where i got the spacers said i need to get hub rings as that is probably the reason i am shaking. I went and got some plastic hub rings and the shaking was reduced, but still noticeable at 50 mph+
    I have now dug myself in 200$ with the spacers/longer studs/hub rings and am wondering if i am just screwed with these wheels.
    TL:DR: Are there 5mm spacers with 66.56mm to 57.1mm hub rings integrated in one? That is probably what i need. Has anyone here had success with 5 mm spacers AND hub rings? My plastic hub rings sit pretty deep in the wheel so that might be one reason they are not lining up on the wheel right. Should i get some metal hub rings like these?
    or would going with a custom spacer/hub ring combo like here work
    thanks for any input, i'm getting ready to rip my hair out..
    Marko
    here's a pic after i lowered it off the jack stands, the suspension doesn't actually sit that high after u drive it around the block.
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    we have a plastic ring that goes from 66.6 (outer diameter) to 57.1 (inner) for $3 each (part # AP666571)....
    Jun 14 2005
    Anaheim, CA
    I don't think you'll find hubcentric rings incorporated into a 5mm spacer, but you may be able to get some custom made. You could try the metal hubcentric rings, although I don't know if that will make a huge difference. I've used multiple plastic ones and have not had issues.
    Brandon @ VMR Wheels
    Veteran Member Four Rings sirmium's Avatar
    Feb 10 2011
    MotorCity
    i did same thing but other way around, ordered 57.1 for 66.6 hub, so i had CNC shop bore out the hole. They did amazing job, no problems at all. But while i was in process i found website/company that makes custom adapters to order, i dont remember the name, google can help. They seemed pretty reputable.
    '23 Tesla Model X | '17 Ducati Supersport S
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    H&R makes hub adapters with a 57.1mm inner bore and a 66.56 mm "hubcentric ring" on the outside in 5mm, 8mm, and 10mm thicknesses. All 1 piece machined aluminum. List is $159.95-pr, we have them for $123.16-pr but currently only have the 8mm size in stock.
    Jan 16 2009
    hey guys
    just to post an update, the custom spacers from motorsports-tech worked and made the wheel fit really snug. These are probably the same as what H&R offers. The only downside of the motorsports-tech was that it took over 2 weeks to make/get them, so if you're in a hurry go with H&R.
    now i need to figure out what center caps work, the ones from ebay are a tad bit too small.
