Need Help figuring this one out because i have tried everything and i am stumped. I should also preface that i do not have a VagCom for logging
Car is K04 with APR and is boosting waaaaaaay too much. Pretty much i have to let the gas off to keep the needle on the boost gauge from going 360*. It already did once and blew some vacuum hoses. (which were found an repaired) Car had an N75 C which i pulled and replaced with an E from the dealer thinking the C was defective. They both behave the same. No regulation.
Checked the lines to the waste gate and found two leaks, replaced the entire line.....no change.
Drove around with the N75 unplugged to see if the waste gate was stuck and that was not the issue either. Wastegate regulated the boost and it would not go passed 6\7psi.
Drove with the MAF unplugged.....also no change.
Changed the APR chip to stock....no change.
I have not changed the MAP or the Coolant Temp, but i have new ones just in case. Does the ECU need to be reset perhaps?
