Picked up and installed some spacers from ECS i figure i would let you guys know how they are doing so far.
I picked up 20mm for the rear and 17.5mm for the fronts, they are sold by themselves and in kits which include the proper lug bolt needed for the thickness of the spacer
all said and done, it was a pinch over 200$ for bolts and all 4 spacers shipped to my door, which after seeing how much H&R wanted for spacers was a breathe of fresh air.
ECS remarks and it's plastered on thier site that these spacers are only for OEM wheel applications only, I did not investigate, but i assume that OEM is built to a tighter hub bore tolerance than aftermarket??? speculation at this point and i only have expeirence with them on the stockers so i can't give you any details on that.
install was about as difficult i would imagine any spacer job to be, the hub-centric portion of the spacer fit the OEM wheel incredibly tightly, I would recommend putting the spacer on the wheel, then both of them on the car's hub as the spacer fits incredibly tightly on the wheel. I had to spin the spacer in order have it seat flat on the wheel, I really cannot overstate how tight they fit.
anywho, there have been absolutely no vibrations or alignment issues whatsoever which i was pretty skeptical about given all the threads that have come up about this.
i would post pics, but i am embarrassed about the ride height of my car (eibach prokit being installed on the 16th)
