Results 1 to 14 of 14
    Mar 10 2008
    18 A4, 14 S4
    Colorado
    Tire Sizes for Staggered 19 Inch Wheels
    I'm looking to buy 19" wheels in staggered format for my 2003 A4 Avant and want to know what size people are running for 8.5 width and 9.5 width.
    I have had 18" wheels up to now, but only in 8.5 width, and I use 225/40 R18 for the stretched look or 235/40 R18 for the even look.
    Any recommendations for these?
    Dub
    Veteran Member Four Rings iamshayan's Avatar
    Jan 13 2010
    Toronto Canada
    Im running stretched 215 35 up front and 225 35 in the rear. on 8.5 and 9.5.
    front
    rear
    http://www.flickr.com/photos/58547753@N03/6160234603/
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Photobucket ruined all my posts.
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    Honda HRX
    Penna.
    Front 215/35R19 & Rear 245/30R19
    ...would be baller.
    This is the closest thing you will get to both a "parallel" sidewall & same rolling diameter.
    Mar 10 2008
    18 A4, 14 S4
    Colorado
    Thanks guys. I think 215 is a little too stretched. For 225, would you recommend 225/30 or 225/35?
    Veteran Member Three Rings movement360's Avatar
    Oct 31 2007
    2004 A4 1.8T Q6MT
    It's Hot
    you trying to put this on a B5?
    #3 Coalition of OEM+
    May 30 2008
    Honda HRX
    Penna.
    Quote Originally Posted by ColoradoB5 View Post
    its going to look the same as a 245 on a 9.5" wheel...
    ...just sayin'
    Mar 10 2008
    18 A4, 14 S4
    Colorado
    Quote Originally Posted by movement360 View Post
    Nope, this will be a B6 Avant.
    Quote Originally Posted by EErie B6 View Post
    ...just sayin'
    I hear ya cluckin, but that 215 left a little more rim exposed than I'm comfortable with. Maybe your PA roads are better than my CO roads, but I gots to have some more rubber there
    May 30 2008
    Honda HRX
    Penna.
    Our roads here suck and i could never pull it off.
    What do you plan on running in the back?
    If you can find matching (if you care about that)... You could rock a 225/35 with a 255/30
    Established Member Two Rings Young SS's Avatar
    Jul 10 2009
    95 Impala SS, Blk 04 A4 6speed
    Chicago, IL 60616
    been running 235/35/19 and 255/35/19 on 8.5 and 9.5 width for 2 summers. just a little stretch in the rear. enough rubber on the front to not leave lips exposed. extremely close rolling diameter.
    ST Coilovers, JHM Stage 3 Clutch & LWFW, JHM Short Shifter, S4 brakes (front), Joey mod, H.I.D. Fogs, S4 spoiler, Led Tails, Tinted Tails, (SUMMER) 19x8.5/19x9.5 TSW Snetterton, (WINTER) 17x7.5 BBS RC's,USP front Bumper
    Jul 10 2009
    Chicago, IL 60616
    Quote Originally Posted by iamshayan View Post
    front
    rear
    I saw this car at Vagkraft at the end of last year. I was in the B6 section with the black staggered 19's w/ ohio tags!
    Apr 08 2011
    2012 CW GTI 6MT!
    Los Angeles, California
    fronts are 225/35/19 8.5
    rears are 265/35/19 9.5
    and running smooth. rarely rubbing. but gonna go 245s on rear and get 8 or 10mm spacers.
    Kevin C.
    2002 B6 A4 1.8TM-Sold!!
    2008 A3 2.0T DSG FSI.Current
    2012 CW GTI 6MT.Current
    Mar 10 2008
    18 A4, 14 S4
    Colorado
    Sweet! Those are some nice looking wheels fellas. How about some shot of your rides do I can check them out?
    I've decided what I'm going to get...
    Jul 10 2009
    Chicago, IL 60616
    Quote Originally Posted by Young SS View Post
    At VagKraft 2011
    Sits flush
    2 3/4 inch lip on rear, (don't laugh, thats all I had left after buying them and getting these painted!)
    Oct 31 2007
    2004 A4 1.8T Q6MT
    It's Hot
    Do any of you stretch guys have/had issues with the bead seal holding air? Right now, I'm on sportec 19's w/ ET 35 running a 225/40 tire and it didn't hold air at 35psi. It's holding it in at 50psi, my shop says that if I go to 235/35 on the next set of wheels I'll be rubbing... I find this a little hard to believe, but when I examine the wheel hub there is a good chance of rub if I don't raise the suspension....Shayam, I'm really curious to hear your take, b/c you have a lot of stretch...
