Originally Posted by
audee
My 1996 A4's battery died and i can't unlock the doors. I can't unlock it with the physical key because they have air locks and using the key will not work. The trunk also does not work. I live in chicago so the locksmiths are around the $100 range and i do not want to spend that much on just unlocking the car. can anyone give me some advice on how i can unlock it as soon as possible please? thank you
It should unlock manually, unless the front door locks have the internal rods disconnected.
Apply a jump pack directly to the engine mount (earth) and the main starter motor feed (+12V direct from battery). This will power the car, so you can use your remote fob to gain access. If you don't have a jump pack, you can use jumper cables from another car's battery, as long as the cables are long enough. I hope your ride isn't slammed.
I would also suggest you get your internal door lock rods replaced, or re-connected once you get your ride open. Good luck!
