Results 1 to 4 of 4
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Running without serpentine belt OK?
    Can I run the car briefly (less than 1 minute) without the serpentine belt on?
    I currently don't have the car here, but IIRC, the power steering pump is driven by the serpentine belt (together with alternator and AC compressor), while the timing belt drives the water pump?
    Running without the serpentine belt for a few seconds would help me isolate the whining noise I want to tackle next.
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Established Member Two Rings alhoward101's Avatar
    May 15 2010
    Bmw 335is
    Atlantic City
    yeah thats fine, you won't hurt anything. your battery just won't get a charge but a few starts w/o the alt charging shouldn't kill the battery.... if i were you i'd just pay $5 for a harbor freight stethoscope, then you could just leave everything connected and probe around till you found it. btw is the whining noise RPM related?
    Feb 20 2010
    Brighton, MI
    Thanks alohward. Got the HB stetho, but not yet experienced enough to do a lot of analytic work with it. Figure dropping the belt is quick and easy.
    Noise is STRICTLY rpm related, NOT PS load (that is why I am questioning if its the pump; normally, bad PS pump whining noise changes with LOAD).
    Water pump was (according to the shop worksheet/invoice) change during the timing belt changes (about 10k ago), ditto the usual pulleys of the timing belt.
    Alternator making noise (bearing?) noise?
    05 Golf TDI
    Mar 18 2010
    Ottawa
    If you have the Serp belt off then you rule out anything driven by it. Good trouble shooting.
    Yes run it with out. If the the noise is still there, then you are looking at the Timing Belt hardware. WHICH may have had only the belt and pump replaced. Not the idler bearings.
