Ok i have owned my b6 since new, and work for that dealership also. I did the pre delivery inspection on it when it came in also. So i know it was not beat on from the get go. The car currently has 51k on it with not a single internal issue or complaint. At 1k miles i did my first oil change and swapped to Mobil1 0w40 fs. For the past 9 years every 5k oil was changed. Never had a engine noise/ chain rattle even in cold winter temp below 30 degrees where i live. Car never used even a cap full of oil between changes.Well last week for the first time i decided to try a different engine oil as over the years i heard Mobil1 is not what it use to be. I did a oil change using Castrol Edge with Spt 5w40. Boy was that a big mistake.. 312 miles into this oil change and this baby sounds like a rattlesnake at startup. Anybody had any issues. I gonna go ahead and drain it. Wasted 95 bucks in oil. Mobil 0w40 is going back in for sure atleast for the time being.
Whats your outlook on this oil? Atleast next time i am going to stay with the same weight. Lol i should of know better.
