Results 1 to 26 of 26
    Jul 27 2011
    IN
    1.8T Axle, Raxles VS OEM Price difference!!!
    Hi,
    I replaced my car's(98 Auid A4 1.8T, AEB, 5 spd, FWD) Passenger side axle with a cheap axle some 4 months ago (another mistake from my side). At that time, I didn't think too much and just wanted to cut down the cost. So got an axle for $60 and the brand was 'Replacement'. Now the P/S side is clicking badly whenever I turn the wheels.
    So today I called ECS Tuning and thay gave me a price for the OEM Audi/VW Passenger side Axle assembly for $129.
    I also called raxles and they gave me a price of $1899 with core) and $270 without returning the core.
    Why this much price difference between OEM and raxles?
    As far as I know, raxles remanufactures the OEM core and why I should pay extra 100 dollars for the raxles axle when I get the OEM axle assembly for a cheaper price??
    Veteran Member Three Rings murdered APR a4's Avatar
    Jan 26 2011
    2002 Audi S8, 2003 Audi RS6, 2009 Audi Q5, 2002 Audi S4
    Hudson, Wisconsin
    Raxle's are different they are stronger and built to last way longer that is why so many people choose them.
    2003 daytona gray RS6
    2002 avus silver B5S4
    2002 black S8
    2009 deep sea blue Q5
    Veteran Member Three Rings Scientist's Avatar
    Sep 08 2011
    2001.5 A4 Avant
    Troy, NY
    Regarding axles, many outfits get the cores (bad axle) and repack them with grease and sell them as "remanufactured." Spend the extra money on a guaranteed axle. Ask your mechanic where he gets his, they are the most reliable source since it would cost them money installing a POS that will break under warranty.
    Same goes for steering racks.
    Jul 27 2011
    IN
    Quote Originally Posted by Scientist View Post
    My mechanic usually gets the OEM axles from dealer. He said the OEM will be little more costly from him compared to buying from an online shop like ECS. So he told me to get a better one such as OEM, Raxles or Lemforder(if they make any axles)..
    So I think its better to get the OEM Audi axle from ECS Tuning. And I hope it will last at least for some 40k miles(more than enough for my car with 220K miles..).
    Sep 14 2006
    OEM is the best for the axles..I got my OEM axle at autozone for $100 after giving them my core. It has a lifetime warranty so when it breaks again, take it back for a new one free.
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Jun 30 2008
    Erie, Pennsylvania
    I don't know what brand ECS was telling you out about, but you can be DARN sure it isn't new genuine axle at $129. A New Genuine Audi right front axle for a '98 1.8T FWD lists for $450. The best price you could probably get would be about $390. Even a genuine reman lists for $300.
    The bargain prices of chinese new and reman axles has made the price of perfectly good genuine used axles at junkyards almost nothing. I got 2 genuine Audi axles from a junkyard, $50 for the pair. Way better quality than you could ever hope to find at a parts store. Genuine stuff is the way to go, there is a reason they cost so much. Keep good boots on them and they last almost forever.
    Veteran Member Three Rings catbed's Avatar
    May 22 2011
    South Jersey
    It was my understanding that raxles don't break. And if they do, they are warrantee'd.
    01 A4 Avant <- TwinScroll T3 jawns
    Built 06A|Built AEB|RR Stg3 Clutch|01E 6MT|60 Trim|1000cc EV14s|Bad MAF|Clunking Suspension|Cracked Dump tube
    NefMoto Tuned
    Jul 27 2011
    IN
    I asked him twice whether its genuine Audi/VW axle and he said YES. He confirmed with somebody putting me on hold and said its Genuine VW axle.
    Do you think that ECS sells crap axles saying its genuine?
    I bought parts from them 5 times and they were all genuine Audi/VW ones. Maybe, you guys will know more ..
    Apr 22 2007
    Riverbank, Ca
    Biggest issues with cheap axles are the boots.... They crack after a short period of time..
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    Anything labeled EMPI or FEQ would be in the 90-110$ range are non OEM ones. They are the cheapo ones that either snap or have a cheap boot design. GKN/Loebro is the brand OEM Audi uses, so you can either purchase OEM VW/AUDI or GKN/Loebro branded axles. Originally they were priced at around 350-450$ depending on side, but now the price has gone down, so you can purchase an OEM one or GKN/Loebro branded one for <250$ a side.
    check out www.germanautoparts.com, perfect example of GKN/Loebro for 242$. At the time, when i needed to replace mine, boot was torn but no clicking, i went with Raxles, since it was cheaper than OEM at the time, but they did not skimp on CV joints, they only reused the shaft/core but everything else was new. Gimme them a call, Marty @ Raxles is a good dude.
    and just incase anyone questions other OEM VW/Audi brands, an example would be our Control Arms are sourced from either TRW or Lemfroder, but they are labeled OEM VW/AUDI. You can buy the same parts directly from TRW/Lembfroder and place them side by side w/ the one you get from the dealer and they will be exactly the same. Hope this helps.
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Active Member Three Rings 10kredline's Avatar
    Feb 03 2007
    San Gangster Valley, CA
    HAHAHA!!!! No wonder, the guy at ECS tuning said I called like 3 times regarding about their axle. Now I know who also called them...it was YOU! I just ordered the same thing just now. I also called Raxles and quoted me $199 but I ordered from ECStuning instead. Raxles are re manufactured but seems like good quality and a lot of people buy from them. I've been buying from ECStuning for a long time and I trust their products and quality. Plus I had remaining balances in my account. =)
    Current - 2011 Audi S4 B8 : IE Stage 2 Single : IE DSG Tune : IE Intake : CTS 180mm : 034 Engine/Trans/Insert : ECS X-Pipe : H&R Sport Springs : Michelin PS A/S 4
    SOLD - 1999 Audi A4 Santorin Blue : AEB 1.8TQM: F21 Turbo : UM Stage 3 : 3" MAF : Siemen 630cc : CX Racing FMIC : SSAC Test Pipe + RAI J-Pipe O2 spacer+ SSAC Full Exhaust : U-Shape Intake+AEM Dryflow : 034 2.0T Coil Conversion : Southbend Stage 2 : ST Coilovers : Walbro 255 Fuel pump : APR Snub
    Sep 19 2010
    I prefer keeping my car.
    What about DSS ( The Driveshaft Shop) axles? Anyone use them?
    Jan 25 2012
    Ankeny, IA
    I run a shop... unless a customer requests otherwise i use GSP axles for 70 bucks ea... they are 100% new material and i have not had a single issue with them going bad or tearing boots. my old a4 ran em for 150k not a single crack to be found in the boots.
    SOMETIMES .... just sometimes... cheap isnt always bad...
    Sep 08 2011
    2001.5 A4 Avant
    Troy, NY
    Quote Originally Posted by EUR Mechaniker View Post
    As I mentioned above, ask your mechanic. If he installs a cheap POS it will cost him so he knows where to get the good stuff.
    Veteran Member Four Rings the_pirate's Avatar
    Apr 08 2008
    Houston
    Raxles has a lifetime warranty I've used it a couple times. Their axles are worth the money if you are super low or building for HP. If you're neither I'd just go with an EMPI or GSP.
    History:
    2001 A4 1.8t manual swapped
    2007 GMC Sierra ext cab
    2002 Chevy Tahoe Z71
    2009 Audi A4 Avant - current daily
    Jul 27 2011
    IN
    Quote Originally Posted by 10kredline View Post
    LOL, I called ECS Tuning again to confirm whether the price of the OEM axle is really $129 ( as per walky_talky's suggestion). And yeah Walky_talky is true.
    ECS guy said that its actually an EMPI brand and not OEM.. What???
    Earlier when I called them, I asked twice whether you are telling me the price for OEM axles and they said YES.....The guy even confirmed with somebody putting me on hold..
    Quote Originally Posted by vwblackb5 View Post
    Thanks for this info. I am considering the GKN/Loebro axles since it's much cheaper than buying OEM axle from the dealer ($420 without the core). And I don't have the OEM axles to exchange the core.. (:
    So final call..Raxles or GKN/Loebro. Which one to get??
    Veteran Member Four Rings TConklin821's Avatar
    Mar 17 2011
    Binghamton, New York
    I bought brand new ones at AutoPart International and I've had no issues yet.
    2001 A4 1.8TQM. Custom catless turbo back, GTRS turbo, 440 green giants, FMIC, custom tune, ECS RA4 clutch + LWFW, short throw, ST coils, 235-40-18 tires
    ^RIP^
    Jan 25 2012
    Ankeny, IA
    get the GSP ones... like i said all new materials and havent had a single issue... they are lifetime warrenty and dont have a core charge. if you have an advance auto parts near your house 95% chance they are sittin on the shelf waiting for you anyhow...
    Jul 27 2011
    IN
    http://forums.maxima.org/4th-generat...gsp-axles.html
    I see lot of people suggesting it as a very low quality..(:
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    I have been running a EMPI front axle from Purems for about 8+ years now and plenty of drag racing in that time. Seems to be holding up just find with drag radials and 600+whp. lol
    Jun 26 2007
    New Jersey
    Quote Originally Posted by M-Hood View Post
    Purems is a great store btw, mike's an awesome guy. As for you mr. mike2ptzero, lol everything you own or experience on your monsterous b5 is/should not be considered a normal data point for us lowly non monsterous b5 owners. Everything seems to always work or always goes above and beyond performance spec. (compliments to you and your wealth of experience, not at all sarcasm if you can read between the lines)
    Feb 08 2011
    Well I guess that is true seeing my original transmission held together for 9 years of drag racing and 3 of my original axles are still going strong ofter 12 years of drag racing. lol
    Nov 21 2006
    san francisco, ca
    No offense mike but i think we hear all the good and not the bad. Sorta like a gambler.... :-)
    There has to be more to it. Hell i have been through so many motors at this point using the best companies and known quality parts, i still get shat on. What's your lucky charm? I need to get one.
    --dillon
    1998.5 A4 2.0TQM ADR/058, Custom ME5 tune by 034, ABA 92.8 stroke forged crank, Scat rods, JE Pistons (83mm/8.5:1), Schrick cams, Supertech springs and retainers, inconel exhaust valves (+1mm), Spa T3 mani with a Precision 5557E-B, 034 3inch exhaust, etc, etc, etc. 034 featured user
    2012 S4 Prestige, Titanium, Monsoon gray metallic, DSG. 034 ECU and TCU tunes and other bits.
    Feb 08 2011
    Quote Originally Posted by nunya View Post
    --dillon
    I guess my good luck with my A4 comes at having bad luck with other stuff in life. I seem to have good luck with my hobbies. lol
    Jul 27 2011
    IN
    I am getting the Gkn loebro axle from Germanautoparts. I get the new Gkn axle for a lesser price compared to the remanufactured axle from raxles. So going with GKN.
    No EMPI/ aftermarket. Done with aftermarket parts for axles..Never again!!
    Jul 27 2011
    IN
    Quick question:
    I was about to buy the P/S side axle from Germanautoparts.com
    In their website, axles are listed only as Left and Right. Is this "Right" side the P/S side axle?
    http://www.germanautoparts.com/Audi/A4/Drivetrain/8/1
