Results 1 to 35 of 35
Thread: blow off valve
    May 13 2011
    san diego california
    blow off valve
    Who makes the best blow off valve for our Audi A5?
    best pricing?
    Veteran Member Four Rings gd10's Avatar
    Oct 15 2009
    Long Beach, NY
    Quote Originally Posted by efx1 View Post
    best pricing?
    why would you want a blow off valve for the A5?
    May 13 2011
    heard it on another members car
    sounds pretty good
    http://www.youtube.com/watch?v=3ViWSy6YNcM
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    it's a bad idea, the sound i will be honest, does sound kind of cool i guess. but the b8 a5 2.0T engine was designed for a closed loop system, meaning that the ECU was programmed to accept and adjust it's A/F ratio based on the assumption that the 'blown off' air was going to be recirculated back into the intake manifold.
    by using a blow off valve, you are intentionally making your car run rich, and you could stall out on occasion. the best bet is the factory DV, but if you are hell bent on getting that woosh sound, see if forged racing makes a DV for this car....i'm too lazy to do the research on it but i would assume they have a mechanical spring DV, that will give you a similar noise but much muffled, but still louder than stock.
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Oct 15 2009
    Long Beach, NY
    sounds pretty good
    sounds good maybe, but decreases performance
    Senior Member Three Rings TGreene09's Avatar
    May 16 2011
    Detroit, MI
    Quote Originally Posted by gd10 View Post
    Diverter valves have been shown to not decrease performance. This has always been a hot topic though. And I agree you dont need a blowoff valve on a A5. Had one on a B6 A4 because and only it was recommended by APR to replace after an ECU upgrade. The 1.8T for some reason came with a weaker unit.
    2012 Audi TTRS | APR ECU STAGE 1
    2013 Audi Q5
    SOLD 2009 Audi S5 | AWE Exhaust & Filter | APR ECU & Intake | H&R 20mm & 25mm spacers | H&R Springs
    Sep 02 2005
    Montreal
    A blow off valve will work great once you add two large bottles of NAWZ.
    Sep 02 2005
    Montreal
    Quote Originally Posted by TGreene09 View Post
    Stating the obvious here, since the car already comes with a diverter valve.
    Jul 08 2010
    tucson
    danbury
    i think the guy was trying to say that the BOV decreases performance
    [CENTER]Scott
    2011 S4
    Jan 07 2011
    2013 C300 4Matic
    why bov? because racecar
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Jul 08 2010
    tucson
    danbury
    why bov? bc op clearly needs to be fast AND furious at the same time
    [CENTER]Scott
    2011 S4
    Senior Member Three Rings elf_cruiser's Avatar
    Mar 01 2010
    GT-R, F350, rockwell cruiser buggy
    Phoenix
    Quote Originally Posted by mr shickadance View Post
    "Granny shiftin' when you shoulda been dubble clutchin' ..."
    Sep 30 2009
    b
    This sub forum blows
    You can direct serious questions about the A5 to the A4 section, where people aren't so ridiculous.
    Or search, BOV's do not decrease performance, or increase it. They simply add the queef noise. There are a few different manufacturers with them.
    Jan 25 2007
    Junk
    San Francisco
    Yea, thats why i dont run a BOV, queefs are a big turn off
    2018 RS3 STG II
    Dec 31 2006
    boston, ma
    once again you add terrible advice and information to this forum.
    To the original poster, you want to, at the most, look at hybrid diverter/bov's. Running a pure bov on a recirculating engine is not recommended and possibly can cause damage. There are those running them that haven't had a problem but I wouldn't risk something happening just for the sound. Another alternative is to get a less sound suppressive intake and you'll be able to hear the diverter valve, which sounds like a bov, but not as loud.
    2010 A5 Brilliant Black, 6 speed
    Sep 02 2011
    TO
    sounds pretty good
    Buy an electrical teapot and a 12V adapter. That way, you can get the same sound without the performance decrease. And as an added benefit, you can have tea when you get thirsty..
    Veteran Member Four Rings TofuShop's Avatar
    Aug 24 2010
    looks like they have a custom setup in that video because that is not the location of the stock dv. if you want a bolt-on solution, Forge makes one with an electronic connection that functions the same as stock (open/close via ECU, not vacuum operated):
    http://www.audizine.com/forum/showth...lve-(FMFSITAT)
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by eclimax13 View Post
    quoted for all of the truths
    okan - stop giving out misinformation
    [CENTER]Scott
    2011 S4
    Sep 30 2009
    b
    What I said was in fact true. I recommended a search as well. For all the information on this topic that has already been discussed, What I said was supposed to be a short throw of info, which was not wrong. It was specific, but it wasn't wrong. So fuck off
    Jul 08 2010
    tucson
    danbury
    blow off valves vent to atmosphere, your car is programmed to work with a recirculating or DV.....by doing this you ARE running your car rich, today's cars can adapt to it, but that takes time and you are still running the car rich,....care to guess how that affects performance?
    [CENTER]Scott
    2011 S4
    Sep 02 2011
    TO
    Actually, a spark ignition engine produces peak power with a slightly rich mixture.
    Sep 30 2009
    b
    you're talking about 1 option out of 3 or 4 that are currently being made. Once again fuck off
    Mar 20 2011
    Petaluma, CA
    okan, he's kinda right, you need an ecu modification to comprehend the change made to how the A/f mixture gets altered. otherwise it will make a recovery, but will take longer and creat a rich condition. it might make the sound you desire, but it WILL reduce the power until the ecu picks up a rich condition from the O2 sensors. but this is the internet, everyone will get nasty so try to take the positive out of what was written and do what you'd like!! and enjoy your car, cuz it's your car!
    Jul 08 2010
    tucson
    danbury
    a bov that also recirculates could be an option, but im pretty sure you need a DV relocator as the DV on the stock ko3 is on the housing, i don't think im being a jerk i'm just saying, stop giving out misinformation, it does affect performance, how much? not much, but it's not right to say that a BOV on an engine system designed to run closed-loop is proper and won't cause performance loss
    [CENTER]Scott
    2011 S4
    Sep 30 2009
    b
    I'm obviously not being specific enough. BOV's in my case include Any type of Diverter valve, or Blow off valve. Generally what you are saying is correct, but every car is different, and I feel like you are take the general and putting in to a specific car.
    Anyway this is the info I found on the topic
    Quote Originally Posted by Info@EuroCode View Post
    The car will not run rich if you vent to atmosphere, this is an Internet urban legend. It is not like every molecule of air is inventoried and accounted for as it passes across the mass air flow sensor.
    The exact same jibberish could be argued that venting back into the intake will cause the car to run lean since the air was counted once and was expected to be burned, but since you closed the throttle plate the air never made it into the cylinders.
    Quote Originally Posted by 400HPA4 View Post
    This post is full of misniformation...first off there are no Carbonio intakes for the B8 A4, second, Forge does not make a true diverter valve for the B8 A4...
    What is available for the B8 A4 is a Forge DVFSIT, it is a spacer that allows you to retain the factory diverter valve and instead of dumping the boost back into the intake tract, some of the boost gets diverted into the atmosphere, by doing this you get the whoosh sound that folks that own turbo cars like.
    Is this childish? Depands on to who is listening I guess, there is no real answer to the question other than bee a free thinker, and do what you like to please yourself.
    Of course, everyone has an opinion, some we agree with, some we dont...
    Quote Originally Posted by cory_can View Post
    Geez....tough crowd. If you want the sound the best advice came from 400HPA4 when he mentioned the DV Spacer instead of a full BOV. Audi's system is 'closed loop' and requires the excess boost to recirculate in order to be monitored......not to blow off into atmosphere. If you run a full BOV you'll have air/fuel mixture issue which will cause other problems.
    Quote Originally Posted by b6onboost View Post
    Audi's run MAF sensors and the air is metered. They use closed loop systems with a Diverter Valve, which vents boost pressure back into the intake post MAF. So if you run a BOV the air is being vented out of the system, yet the ECU still assumes its there, so it still pushes fuel. The air/fuel ratio is off and you run rich.
    However, you only run lean for a second between shifts when the BOV releases. Under boost (acceleration) the BOV is closed and the car runs at the correct A/F ratio.
    So it's not automatically bad, but it isn't optimal. I personally think it's ricer to have a brand new B8 and have that high pitched BOV sound. If you want sound, get an intake and the DV will make a nice 'whoosh' sound.
    ^like you said BOV bad, DV ok.
    Quote Originally Posted by LB_NY_B8 View Post
    This Spacer Allows some of the air to be vented to the atmosphere when the throttle plate closes, it is perfectly harmless. There is no compressor surge.
    "A DV and a BOV basically do the same thing, they release built up air pressure when the throttle plate closes, by releasing the air pressure, the turbo is able to stil spin freely. The reason that the air pressure is "diverted" back into the intake tract is because current emission rules do not allow it to be released in the atmosphere"
    This is all as per eurocode.
    Quote Originally Posted by JMG View Post
    The desire to use a BOV for the "psst" sound on an Audi A4 has dated back to the B5 A4, and that debate has been restarted with each new generation of driver and build. Generally the use of a BOV on a close to stock Audi has been frowned upon because the A4 has been a closed system which utilizes a DV as opposed to an atmospheric BOV. Even some BT Audis don't need it.
    I suggest doing some research on what a BOV does and what types of systems they are good for. Then determine where your car's (the B8) MAF takes it's measurement, if its an open or closed system, and what kind of gains you will get as well as the risk factors for using a BOV on your car.
    What does an MAF do? On the B5-B7 A4 the MAF metered the intake air mass. This measurement is used to calculate the required fuel to be injected in order to maintain a proper air/fuel ratio. Because air mass reading is taken from the intake, venting air after the intake makes this reading inaccurate.
    What does a BOV do? It releases excess air when the throttle plate is closed so as not to cause excessive stress to the turbo. When a BT setup running lets say 20-30 psi, experiences pressure surges, this can significantly affect the time needed to "re-spool" the turbo, cause premature wear and tear, and even cause damage to the turbo and blowout. Thus, the BOV is used on high performance big boost cars which have been tuned to adjust for the air released by a BOV. For those that know what a BOV does and where it is needed, the sound is associated with highly modified turbo cars. For others, it just sounds cool. Or maybe it sounds cool because we have heard fast cars make that sound?
    Why didn't the A4 already come with one if it works so well? I'm not too sure, but the fact that the A4 uses a "closed" system is either a result of or one of the factors of using a DV instead of a BOV. Either way, the MAF and ECU were designed with a closed system in mind.
    Note that there are also "spacers" which allow for the BOV sound while still being able to use a DV. The Spacer still makes the system atmospheric, venting air that was measured by the MAF. While some spacers are adjustable, they are still venting metered air.
    One such spacer is made by Forge Motorsport, who expressly state that:
    source: http://forums.vwvortex.com/zerothread?id=2651617
    To summarize, the B5-B7 A4 was not designed to use a BOV or Spacer. The Spacer, which when used in conjunction with a DV, vents metered air, thus providing BOV functionality. The spacer/BOV has not been shown to improve performance in the 2.0T FSI and the manufacturer makes no claims that it will. Thus the BOV almost purely cosmetic for the B5-B7 engines with the stock KO3 running 8-9psi.
    What's wrong with a purely cosmetic mod? Nothing. But I do have the opinion that a mod should not misrepresent or give false impressions of the car it is placed on. This would include such mods as false badging (ie S4 badges on a A4, Turbo badges on a NA car) and fake BOV generators such as this:
    Fake Turbo Sound Whistler
    The Fake Turbo Sound Whistler does not hurt or increase performance. It's purely cosmetic and a complete misrepresentation of the car it's placed on. I wouldn't say that a BOV on a stock A4 is as much of a misrepresentation or nearly as reprehensible. But, taking into consideration that the BOV is designed for big boost turbo setups running, for example, 20-30psi, it is my opinion that the BOV would be a misrepresentation of my vehicle unless I am actually generating those kinds of numbers. There are those who think it's fine to make others think that their vehicle produces the boost levels that require the use of a BOV when they, in fact, do not, but I am not one of them. On the other hand, there are those who don't even know what a BOV truly does or when it is needed, so there is no misrepresentation at all. The sound is just "cool". IMHO that does no service to the enthusiast crowd as a whole, because the entire meaning of the mod is closer to being lost to nothing more than a cosmetic sound. I don't know about you, but that doesn't sound like the ideal way to promote the community.
    In the end, you make your decision. What is important to me may not be important to you. Take as many facts you can into consideration when you make your decision, and know that not everyone is going to agree with your decision or appreciate your mods, and they may have a good reason in their own mind.
    Consensus, Get the DV spacer, which gives you the same whoosh, without the BOV run rich situation. I think there are 2 actual BOV's made for this car, and 2 DV's amde for our cars. SO that's what I was talking about ^.
    Hope this is specific enough. And finally not "misinformation". I won't give out any info if I don't have anything to stand on. I usually give out good information. And I said to give it a search. When you search BOV - you get all the DV answers you need, because it's the same part, but doing slightly different things.
    For what's it's worth a BOV is recommended when modding, but for the most part we want to be running DV's instead.
    Dec 31 2006
    boston, ma
    Okan. You are so confused, it's scary.
    Sep 30 2009
    b
    I posted things on both sides of the argument? is that why? I must be, since I have no idea what you're talking about.
    Sep 02 2005
    Montreal
    This thread was about "blow off valves", not hybrid systems like the Forge spacer. The reason the Forge spacer works without any issues is because it retains a DV (any pressure release valve would do) that can be controlled by the ECU, through the MAP sensor (though I believe it is mounted before the manifold, so it's not a true MAP). Venting to atmosphere is not a problem, it never has been, but regular BOVs cannot be properly controlled electronically, and that is what causes potential fuel trim issues that can decrease performance. As long as the operation of the valve can be electronically controlled by the ECU, as required, there is no problem with venting and making that gay sound all the posers love
    Aug 05 2011
    LI, NY
    Just about all BOV's can be had in both circulating and also be able to blow off to atmosphere. Every car is different when you blow off to atmosphere, some have issues and some don't. Same make/model can have two different results, seen it happen.
    A good after market BOV will not leak or break down over time. And most important it will hold the boost and not bleed off.
    Here's one made for the Audi A5 2.0
    http://www.forgemotorsport.com/conte...oduct=FMFSITAT
    The one in the vid looks like Tial BOV which is a high quality piece, I got one in my 3000GT
    2019 RS5
    2013 Audi S5 Estoril Blue - SOLD
    Weekend Warriors - '97 Mitsubishi 3000GT VR4 / '96 Mitsubishi 3000GT VR4 Spyder
    May 13 2011
    Thanks oohnoo for the link
    Here's an A5 with K04 turbo upgrade with blow off valve
    http://www.youtube.com/watch?v=f3x3yfUZTDE
    Sounds great !!!
    Nothing ricey IMO
    Sep 02 2005
    Montreal
    Sounds great !!!
    Nothing ricey IMO
    Yeah, it sounds like a BOV, what did you expect... Everyone knows what it sounds like, and that has never been the issue. The retarded part is the whole concept of defeating a more modern and sophisticated system by converting it back to a more primitive system with no benefits what so ever. Would you also like a carburetor for your 2.0T? Or how about a non-synchronized manual transmission... yeah, didn't think so.
    May 13 2011
    Mxrz,
    You must know everything about everything huh
    You are the same guy on the A5oc forum teaching us about wheels
    U must love asians
    Sep 02 2005
    Montreal
    If you say so.
    Senior Member Two Rings HiTMaNN's Avatar
    Feb 09 2012
    Audi A5, Benz S550, & Dodge Ram
    Vancouver, B.C.
    Mxrz,
    U must love asians
    LoL What does loving Asians have to do with BOV's?
    May 13 2011
    stereotype BOV belongs to ricer cars only
