Results 1 to 25 of 25
    Senior Member Three Rings Italiano's Avatar
    Jul 27 2009
    2012 BMW X5, 1979 Corvette
    Charleston, SC
    Po303 cylinder 3 misfire detected*
    So what I thought was a DV failure turns out to be a Po303 code - cylinder 3 misfire detected. Am I right in thinking this is a coil pack problem? If so do I replace just cylinder 3 or should I replace all 4? The car has 51k miles.
    2014 S4 (B8.5) APR Stage II+ ll APR Pulley upgrade ll APR Exhaust ll APR TCU Upgrade ll 20% tint
    May 21 2007
    Florida
    most likely it is a coil pack. i personally would just replace all 4 since they are cheap. i would keep the 3 "good" ones in the trunk(im paranoid from my shitty b6 1.8t coils). also, youre coming up on your scheduled maintenance for spark plugs (55k assuming you run OEM plugs) so i would get those done too. a plug would have to be REALLY fouled to cause a check engine light so i dont think those would be the source of your issue but it is a good idea to take care of it while youve got the coils out (not that its hard to remove a coilpack though). IF you do notice a severly fouled plug i would inspect your valve cover gasket to make sure its not leaking and fouling the plugs.
    2018 Navarro Blue Q5
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 14 2011
    12 Taco, 13 Ex, 16 Civic EX, 15 JKUR
    Agree with dbl030....replace all 4 and keep one of the spares in the car for future emergencies.
    I just got my first P0301 and the 4 replacements are in transit.
    I had a mkiv with a 1.8T and the same crappy ignition coils, hence the same strategy.
    2007 2.0T Q 6MT, S-Line, Ti Package, BB
    Revo Stage 2 | JHM Stage 1 Clutch | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | 034 SD Tranny & Motor Mounts | Neuspeed Snub | H&R Sport Springs | Bilsteins | Moog ACA | B5 Perches (removed) | RS4 RSB | ABT Drilled n Slotted Rotors | Redstuff Front & Akebono Rear | Podi Stepper Boost Gauge | Recaro's | H&R Spacers 15f/20r | Clear Corners w/Blackout | Smoked Frt Markers | Cupra R Lip | 20% Tint
    Jul 27 2009
    Charleston, SC
    Thanks guys, whats the difference between the reversion E and F pack? Sorry noob question right there lol
    Oct 14 2011
    Quote Originally Posted by Italiano View Post
    I'm a couple of days ahead of you in this regard.
    This thread is really usefull....http://www.audizine.com/forum/showth...an-quot-F-quot
    The posting by bman005 is really helpful...it comes down to avoid..
    o 07K 905 715 E (black)
    It's the one coil that can't be mixed with any others (having said that check what you currently have, my old ones are 07K 905 715 D (black) so I can use them if a RED goes bad. It will only be temporay, I'll order a single RED replacement and replace them one at a time next go round since I'll have the emergency stock to work with. I think he still has 4 for sale.
    All the others appear to be useable and for the life of me I couldn't find anything that had proof about any one version being better than another.
    I ordered 06E 905 115 E (red) becuase I wanted RED. I took a small chance, ordered them off ebay. Some guy had 8 new RED for sale asking $19 shipped. He had Make Offer there, I offerd $15 shipped ($60 for a set) and he accepted.. I think he still has 4 up for sale....check it out.
    Veteran Member Three Rings digitalAUDI's Avatar
    Apr 14 2010
    Union, NJ
    I just recently had the same code show up, but I had random symptoms of my car stuttering under acceleration. I spoke to my mechanic and we both initially went with the coil pack thought, so I changed them all, and I changed the plugs as well. My problem still persisted. Long story short, after doing some other tests, it turned out to be the cylinder 3 fuel injector that was bad. got that changed and now the car is fine and no CEL.
    just some food for thought...
    Current: 2004 Audi Allroad 6MT, APR Stage 1 (for now)
    Previous: 2006 Audi A4 6MT, Revo Stage 2, 034 Motorsports HFC, B&B Performance Exhaust, Tein S.Tech Springs, RS4 Rear Sway Bar, Upgraded DV, CXRacing Intercooler w/Piping, TSW wheels
    Veteran Member Four Rings JPT's Avatar
    Oct 11 2010
    '05 Kawasaki Ninja ZX12R
    Long Island/NY
    Misfires are in new cars are typically 1 of 3 things. 1 Spark plugs, 2 fuel injectors, or 3 coil packs.
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    If you want to find out if it is exactly the coil packs, take the misfiring coil pack and move it to another location, you should now be getting misfires in that cylinder, this would indicate you have a definite coil pack problem, if the problem is still in cylinder 3 then you have some more reading to do.
    Oct 14 2011
    Quote Originally Posted by digitalAUDI View Post
    Quote Originally Posted by JPT View Post
    Thanks for the info...I was naive enough to think the ignition coil was going to solve my problem. I won't toss that coil in the trash until I know I've got my problem solved.
    Guess I better start to bone up on injector info., haven't dealt with them before.
    Jul 27 2009
    Charleston, SC
    Yah i think i will try changing the Coil packs around to flush out the real problem. I called the dealer today and they did change them under the recall back in 2010, so i am running the new 06H 905 115 pack. Thinking about this now it seems more likely to be a fouled plug or bad injector.
    Jul 27 2009
    Charleston, SC
    Is there any advantage to upgrading the OEM injectors with just a stage II set up (No HPFP)?
    May 21 2007
    Florida
    just because they were change 2 years ago doesnt mean theyre not bad. the coilpacks on these cars are weak. which is why theyre so cheap. what you can do is with the engine running, lift the coil out of the cylinder a little bit. if you hear it arcing, you know the coil is still working proporly.
    you cant do this. your car with run like shit without proper supporting mods and tuning.
    Account Terminated Two Rings
    Mar 02 2012
    Miami FL
    or 4 PCV needs to be replaced/substituted for a catch can
    Jul 27 2009
    Charleston, SC
    ok one more dumb question, when i am standing at the front of the car looking at the motor which one is cylinder #3?
    Jul 27 2009
    Charleston, SC
    May 21 2007
    Florida
    1 in front 4 in rear. That means #3 is 3 from the front
    However the firing order is 1-3-4-2 (unrelated but may be useful to some)
    Jul 27 2009
    Charleston, SC
    perfect thank you!
    Veteran Member Three Rings baldy's Avatar
    May 11 2010
    Aprilia RSV4RF, Yamaha R1, '15 A3 TDI
    BC
    Quote Originally Posted by doublezero30 View Post
    X2 I have had 3 coilpacks go bad since the recall replacement.. I have the Red ones now, and the car seems to idle smoother..
    C7 A6 TDI - TurboSystems 2872..Wagner IC..CGQB fuel system+MAF..RS6 intake..Eurocode sways+inserts..Eibach springs..H&R 15mm spacers..JXB support..Powerflex diff inserts..Waxedshine PPS...OE hitch..HBA retrofit
    Oct 14 2011
    I put the 06E 905 115 E (red) in yesterday and cleared my codes....went for a nice ride down to san clemente and back and she felt nice and strong.
    I've got the cabon cleaning on my radar and will clean the injectors when I do that.
    Active Member Two Rings DuBTime's Avatar
    Nov 04 2009
    91 Corrado VR6T
    Colorado Springs
    It seems like with warm weather and stg 2 I have to replace my plugs 25k +\- 5 I went threw 2 sets (not proud to admit but from auto zone) befor I went to the dealer for oem plugs have held up fine since.... Always #3 drops gap.... Had one coil failed at 30k and at 97k still running fine... Dealer replaced all 4 to revision f's I believe
    Jul 27 2009
    Charleston, SC
    Well just to close this thread out, got the Red CP today dropped them in in less then 5 min and we are GOOD TO GO! runs like a champ again, thanks for all the help guys.
    Oct 14 2011
    CP's for me as well. I've had a set of the Red CP's in for 10 days now and running great....even improved my gas mileage. I realize the real time mileage is suspect, but filled up yesterday and per my calc's I got just under 27mpg on this tank vs just north of 25. And I was driving her pretty hard, wanted to see if I could throw a code.
    Nov 30 2015
    New York
    Quote Originally Posted by mcpcartier View Post
    What happens if they mixed ? I have the 06h905115 black and ordered a 07k905715f by mistake
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    Veteran Member Three Rings konarider94's Avatar
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    Quote Originally Posted by bfunk1414 View Post
    Car will spontaneously combust and fall into a black hole
    2018 A5 S-Line Manual
    Nov 30 2015
    New York
    Quote Originally Posted by konarider94 View Post
    Lol. Dumber question; what if I oder a 4 of the 07? Can only find some Bosch 06 not oem
    Disregard. Contacted the dealership and apparently it is a bosch that they have as well so might as well just order it
