Results 1 to 20 of 20
    Nov 10 2011
    Illinois
    Flush the transmission or only change the fluid
    At what point is it recommended for the Tiptronic auto trans to change out the fluid.
    I realize some dealers (and Audi of America) will say that it is lifetime fluid.
    Is 55K a good time to change it?
    If so, should the trans be flushed or just the fluid changed?
    Any deals out there for OEM Audi fluid?
    Current: 2014 Audi A5 2.0T P+ | 3M Colorstable 35% Tint | Brilliant Black | Chrome Grill Inserts | Interior SMD LEDs |
    Previous Ride: 2009 Audi A4 2.0T P+ | 3M Colorstable 35% Tint | Meteor Grey | Chrome Grill Inserts | Blesk SMD LEDs - license and under-door |
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    If its not discoloured its fine.
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    I was wondering the same thing...
    Quote Originally Posted by kstrohm View Post
    [B]Current: Shopping now....
    Nov 10 2011
    Illinois
    I would think its similar to the B7 recommendations? Maybe there are not enough B8 owners which have got to the 50K miles+ point yet ....
    Mar 02 2007
    Fresno, CA
    Meh, I'm at 90k on the original fluid and don't plan on changing it.
    Dec 01 2011
    If anything just the fluid change, I've heard that flushing the transmission can do more damage than good, it's not meant to be flushed and supposed to last lifetime so I don't know if I'd do that unless you were having transmission issues and a dealer/mechanic actually recommended flushing it.
    Nov 10 2011
    Illinois
    Maybe I'll just hold off for awhile. I just do not want to eventually pass up the ~55K mark and find out I should have switched out the fluid...
    Mar 02 2007
    Fresno, CA
    The only good reason to do it would be if your service advisor really needed the sale to meet his quota for monthly/quarterly/yearly sales goal and his family would not be able to survive without that bonus. Otherwise, you're just wasting your money.
    Senior Member Two Rings Dan_Q's Avatar
    May 18 2011
    2011 BMW 335i, 392 whp
    Colorado Front Range
    Well when you drain an automatic transmission you won't get out the fluid in the torque converter so it will be pretty incomplete if you just drain and fill. Normally you'd drain it-refill it-drive it. Driving it will mix the fluids so if you do that 3X in a row you will have changed out about 90% of the old fluid.
    I do my manual trans fluid every 30k miles and would do the same if I had an automatic. But that is probably overkill and 50k is still reasonable.
    If you're gonna keep it till 120-150k miles then it is probably easier to spend an hour and $75 on fluid every 50k miles than it will be to spend $5000 on a new transmission. If you are going to sell it before that mileage then it probably doesn't matter. If you sell it, most buyers won't even know what transmission fluid is or why you would want to change it.
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by Dan_Q View Post
    No more overkill than the guys who change their synthetic oil every 5k because it makes them feel better about maintaining their cars. Trust me, Audi is in the business of making money and if they think they could get away with recommending and charging for changing ANY fluids before they have to, they would do so.
    May 18 2011
    Yeah they could charge for it. Customers would just buy cars from other manufacturers who say it isn't needed. Not recommending maintenance keeps a car's cost of ownership lower and avoids the hassle of having to bring it in. Let's face it, many luxury car owners are wealthy people who know nothing about cars. They don't want to have to drive in and drop their cars off on a regular basis and of course they wouldn't want to have to pay for it if they did. They're more likely to keep the car for 25k miles than they are to keep it for 125k miles which is the time frame when the affected parts would actually wear out. If you told them engine oil would last forever then half of them would no doubt believe it.
    Every auto technician I know regularly replaces the "lifetime" fluids in their own cars. But like I said, if people don't plan to keep their cars for very long then the only people who benefit by doing additional maintenance are the owners in the future.
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    FWIW, usually "lifetime" means lifetime of the component. If your transmission dies at 100k, then there's your "lifetime" fluid. Mercedes use to do lifetime transmission fluid for the longest time until customers started having their transmissions crap out before 100k miles. Now, transmission fluid changes are at 39k mi intervals. IMO, no fluid is lifetime...they break down at some point.
    I sometimes am weary of Audi's intervals. Look back at the B6 1.8Ts. The timing belt service interval started at 105k miles when they first came out. When water pumps started seizing and belts were breaking before the 105k interval, they came out with a TSB and maintenance booklet insert that revised the TB interval to 75k miles.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Aug 21 2011
    S2000
    Monrovia, CA
    Change and DON"T flush the trans. There are little particles from the clutches that coat the inside one the trans, and you don't want to disturb them. The fluid is very expensive. I will be doing mine at the 55K service. Remember, " lifetime " is until the trans fails. Heat will kill any oil and that is why it is good to change the fluid even if you can't get it all out. My BMW trans lasted over 236,000 miles because I serviced the trans. The first change, the fluid looked like s**t and smelled awful.
    Nov 10 2011
    Illinois
    ^ I'm leaning towards changing the fluid. Probably around the 55K - 60K mark ... I just do not want to deal later on selling a car that has never had the fluid changed.
    Senior Member Three Rings parm104's Avatar
    Jul 06 2005
    2009 Audi A4 3.2L Quattro
    Vancouver
    Audi NEVER recommends a transmission fluid flush. Since the B5 model, they've never recommended a transmission flush. According to Audi, you won't ever have to flush your transmission.
    The only time I had to do it was on my B6 A4 when I put in a new valve body.
    Sep 19 2011
    Montreal/Quebec
    I'm wondering the same thing. I've got an Automatic B8 and when it's cold it feels rough to change. Can changeing the oil do any harm?
    Dec 17 2008
    Charlotte, NC
    CVT's it's recommended at 35-40K
    Ol' Whitey - 1996 A4 2.8 quattro 5MT Arctic White w/ Remus
    #2 - 2008 A4 2.0T Quattro 6MT Quartz Gray - w/ AWE exhaust (1/08 - 1/11)
    #3- 2011 A4 6MT Quartz Gray - Prem Plus, B&O, Titanium - Full Gen1 AWE dual exhaust, Eurocode Everything, 3M Clearbra, Piano Black Dash Surround, MY10 rear headrests, Huper Optik, S-line Stoneguards
    #4 2014 Audi S4 6MT - Monsoon + Black optics Neuspeed exhaust, Eurocode bits
    Audi Brand & Audi Sport Specialist at Northlake
    B8 Titanium Club Member #4
    Senior Member Two Rings Vinhouw's Avatar
    Jan 14 2014
    my two feet
    Tampa, FL
    Quick question, for a transmission service on a 2011 B8 A4 CVT, do you only change the fluid or you have to change the filter + gasket? I was quoted $350 for it at the dealer(not sure if it includes everything in the service,which is fluid, gasket and filter) . The kit on ecs comes with everything for $296.75. Read a DIY for it, and the guy just changed the fluid, no gasket no filter... so is it mandatory to do filter + gasket? if so, might as well pay the $50 more and get it done professionally.
    i got a 2011 B8 A4, automatic transmission
    Veteran Member Three Rings B44's Avatar
    Oct 27 2014
    [QUOTE=kstrohm;7331919]At what point is it recommended for the Tiptronic auto trans to change out the fluid.
    you can do it around the 60 to 70k mark all the way up to 90k is fine. another thing to remember is you do not want a flush because thats bad all you want to do is drain the old fluid and replace the new trans filter and put in the new fluid. also while doing this you could drain and fill the differential fluid aswell to keep things running efficiently again for both the differential and the trans just drain and fill do not flush. check with your local dealer on how many quarts the trans and the diff require.
    this link will give you a pretty good understanding.
    http://www.audizine.com/forum/showth...n-Fluid-Change
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    If you change it regularly (no more than 50,000 mile intervals), there is no need to flush. Also, if you flush, you should ONLY use OEM ATF, I would not use any "flush" products/additives...who knows if they are truly compatible with the trans and the OEM ATF.
