Results 1 to 31 of 31
    Active Member Two Rings ALFRED's Avatar
    Jul 01 2004
    Las Vegas, Nevada
    Remedies for Spilled Soda on MMI Control Module?
    Looking for some remedies and how to...Thanks in advance.
    Oct 09 2008
    Don't drink soda in the car.
    The Awesome™
    Dec 17 2008
    Charlotte, NC
    Quote Originally Posted by JoshDub View Post
    Sippy cups or bottles with screw tops are also wise. But seriously...depending on how bad it is...you may need a new one.
    Ol' Whitey - 1996 A4 2.8 quattro 5MT Arctic White w/ Remus
    #2 - 2008 A4 2.0T Quattro 6MT Quartz Gray - w/ AWE exhaust (1/08 - 1/11)
    #3- 2011 A4 6MT Quartz Gray - Prem Plus, B&O, Titanium - Full Gen1 AWE dual exhaust, Eurocode Everything, 3M Clearbra, Piano Black Dash Surround, MY10 rear headrests, Huper Optik, S-line Stoneguards
    #4 2014 Audi S4 6MT - Monsoon + Black optics Neuspeed exhaust, Eurocode bits
    Audi Brand & Audi Sport Specialist at Northlake
    B8 Titanium Club Member #4
    Jul 01 2004
    Las Vegas, Nevada
    Thanks for your mature response.
    Jul 01 2004
    Las Vegas, Nevada
    Quote Originally Posted by AofC_RR View Post
    I would like to explore the alternatives before purchasing a new one. Thanks for the mature response.
    Established Member Two Rings at1183's Avatar
    Feb 04 2012
    Queens, NY
    Seems to be a common thing.... why do german cars have such little cup holders?? is it revenge for WWII ?? lol
    i worked in the computer field my whole life... spilled fluids (especially soda, coffee and juice) are the enemy... its usually not repairable, and must be replaced..eventually the liquid will corrode the circuit board bad enough, to cause a major short...
    Senior Member Two Rings HiTMaNN's Avatar
    Feb 09 2012
    Audi A5, Benz S550, & Dodge Ram
    Vancouver, B.C.
    Quote Originally Posted by ALFRED View Post
    He sort of has a point though, not really an immature response if you ask me.
    Active Member Two Rings Audi_Fan's Avatar
    Mar 29 2011
    2012 Audi A4 2.0T
    Boston,MA
    I spilled soda, coffee, and juice in the past on my MMI. I took it apart several times and cleaned all parts with rubbing alcohol and q-tips. That at least loosened all the buttons. If some of the lights went out, there is no quick fix for that.
    Oct 09 2008
    Meh. Thought I'd give you some helpful advice since I am not the one with a screwed control panel. If you don't drink pop in the car then you can't spill pop on the buttons and ruin the circuit board.
    You can attempt to clean it. But if it still works now then I'd just start planning to replace it down the road.
    The Awesome™
    Aug 11 2010
    USAF near Aachen Germany
    Alfred aren't you the guy racing Hyundia Tiberons and complaining when they pull you when you hit the top speed limiter?
    Your getting answers on the same level as your questions.
    Take the control out, dissemble it and clean it up.
    If you break it you were going to buy a new one anyway.
    Veteran Member Three Rings tenspeed's Avatar
    Dec 12 2011
    Honeoye NY
    Quote Originally Posted by nedrager View Post
    Sounds like what I would recommend too.
    Remove, flush with water to remove residue, flush with rubbing alcohol to remove water, dry and test.
    Jul 01 2004
    Las Vegas, Nevada
    For all of you out there, I asked a question on these forums for help. I'm not here to judge or be judged. I don't go off telling other people the obvious with a hint of sarcasm or what you should or shouldn't do, that is your own thing. And yes nedrager, that was me. Now back on topic, does someone have some sort of detailed instruction on how to remove and clean the MMI? I tried searching on google and nothing.
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    A hint of sarcasm?
    19 years and 320,000 miles behind the wheel of an Audi
    2022 A6 55 3.0 Prestige with Luxury Package and Black Optic Sport Package (all options). Daytona Gray Pearl Effect. Sarder Brown Interior. (July 2022 - presesent)
    RIP Audis
    2015 A6 TDI Prestige All Options except B&O - (August 2014 - July 2022) (146,179 miles)
    2005 A6 4.2 Prestige All Options - (February 2005 - August 2014) (141,179 miles)
    Dec 27 2010
    Morehead City, North Carolina
    I realize that the audi cup holders are not great, but you should check out the ones in the 5-Series. We have had a couple of those cars and the cup holders were 2 little plastic arms that swung out about an inch above a console. Pretty sure you would even spill a sippy cup in there.
    Apr 17 2009
    lawn gyland
    Quote Originally Posted by tenspeed View Post
    I would do this also, but in the following way:
    After removal:
    Flush with a baking soda / water solution (to neutralize the acidity of the spilled soda - I do this to clean up residue from leaking batteries in small electronics).
    Flush with Distilled water (to rinse off the basic solution used previously + no dissolved organic contaminants as in tap water).
    Flush with Isopropyl Alcohol (to displaced the rinse water used previously).
    Dry with forced air (air compressor or cans) (to dry off excess water / alcohol).
    Toss in a ziplock bag with desiccant packets (salvaged from sneakers, electronics, etc. packaging) to completely dry module. If no desiccant packets available, then use uncooked rice to absorb the remaining moisture. Leave in ziplock bag for at least one week.
    Replace module and cross fingers.
    Nov 11 2011
    Waukesha/Wisconsin
    What I decided to do since I just got a new MMI unit when I bought the car used is put a rag over all of the buttons (between the shifter and cup holder) when I have a drink in the car. This way if there is any sort of spill or splatter it lands on the rag which is easily washed in the washer. No it doesn't look pretty while the rag is laying over the buttons but I'll take that over spending 1K to replace it if it were to start having issues from a liquid spill.
    Established Member Two Rings j_sonel's Avatar
    Jan 18 2008
    '06 A6 Avant 3.2Q, '06 A4 Avant 2.0TQM
    Chapel Hill, NC
    I have heard of using wd-40 as a means to getting the buttons un-stuck, but haven't tried it nor heard of anyone else actually trying it and reporting results. If your buttons are stuck, and you're willing to try anything to avoid replacement, it might be worth a shot. Apparently the wd-40 won't remove the goo, but it will keep it in more of a liquid state allowing movement. Maybe try it on one button and report back?
    '91 Coupe Quattro - 034, H&R, Autocraft, Keskin - S2 look alike
    '06 A4 Avant 2.0T Quattro Manual
    '12 Touareg TDI Lux
    Veteran Member Three Rings AnthraciteA4's Avatar
    Dec 31 2006
    Colorado Springs
    Quote Originally Posted by chuckee98 View Post
    After removal:
    When you get the module out of the car and taken apart, take pictures and post them here. You can use a small SOFT bristle tooth brush and some isopropyl alcohol to scrub off the corrosion and sticky goop assuming you don't have access to an ultrasonic cleaner (the kind they use for jewelry but big enough to fit your MMI board). I would do the scrubbing as step 3 between the distilled water flush and the alcohol flush. I'd also only use canned air because depending on the air compressor you can actually damage some of the smaller components on the board.
    Veteran Member Three Rings SlickMachine's Avatar
    Feb 21 2012
    2018 Ford Explorer Sport
    Aurora, CO
    Stick it in your freezer over night, in the morning the sticky stuff won't be sticky, it will be frozen and brittle. While it's in this state, exercise each button carefully, hopefully breaking free the soda syrup from the button perimeters.
    Aug 11 2010
    Once you get the replacement MMI control in after this one is destroyed, get a new lid for your sippy cup. Sarcastic enough? Maybe you can be the first to post the how-to on cleaning MMI controls after beverage mishaps...
    Feb 28 2012
    ca/San Francisco
    Feb 21 2012
    Aurora, CO
    I would just like to add my experience to this thread, even though it is an old thread, as a sort of therapy for me in getting over the severe anger I feel right now toward my dizzy wife and mother who are the responsible parties today.
    After an exhausting day of shopping, the said two females stopped at Chick fil a to get whatever dizzy females get at that place. It involved hot mustard. The hot mustard ended up upside down on the MMI controls. The volume knob is completely effed, as are the buttons on the right side of the unit. Sticky button presses and essentially a frozen volume knob. Now the kicker: This thread prompted me to warn my wife the day i purchased the car one year ago about not taking any chances spilling ANYTHING on that MMI control panel. Hows that for irony?
    Veteran Member Three Rings MainlandMig's Avatar
    Apr 06 2010
    Atlantic City Metro Area
    1st everyone should know that inorder to do this properly one must remove this unit ..and to do that you have to remove the whole center console 1st
    if u are NOT ready to do this then u can
    1 take it to dealer and pay out the ears
    2 try lightly spraying Distilled water then alcohol to dilute syrup on problematic button and work into unit by gentle repeated pressing then let properly dry...this may take multiple attempts and multiple days..and this will only give you slight improvement ...*not sure how i feel about wd40
    if u can do center console removal and get to the unit then i would recommend chuckee98's steps
    After removal:
    opening the unit is easy and basically its 3 pieces
    once open i would 1st go to work on rubber piece and get any debris out of crevaces
    then i would use chuckee98 steps on buttons then CAREFULLY on circuit board
    BTW mine now works great...even my power button started working perfectly
    Aug 09 2011
    Brooklyn, NY
    Can you replace the knob alone? If yes, How hard is it to replace the knob only?
    Veteran Member Three Rings Unleaded20T's Avatar
    Mar 27 2008
    Ducati Streetfighter V4S
    Allen, TX
    x2
    [Current] 22' S6 | Daytona Gray | BO | Prestige
    [Sold] 21' S5 SB | Glacier White | BO | Prestige
    [Sold] 19' SQ5 | Ibis White | Prestige
    [Sold] 2016 A6 | Moonlight Blue | 3.0T P+
    [Sold] 2011 A6 | Black | Prestige
    "If everything seems to be under control, you are not going fast enough." - M.A.
    Apr 06 2010
    Quote Originally Posted by SPONGE View Post
    the volume knob is a straight pull up job
    but the MMI Main (large/rotary/center) button i would not try to pull up
    if u look at the 3rd pic... u will see the back of the knob has a gold colored pin that is held/riveted into place by a silver saucer star washer and forcing up i believe will damage this and it wont function/rotate properly
    if u source a used MMI unit on ebay u should be able to swap it in from the inside by removing those hex screws
    but that requires removing the center console
    2011 A6 (C6/4F) 3.0 SC Q Prestige | Brilliant Black | Amaretto/Black Leather Walnut Trim | Side Assist
    APR Stage 2 | USP Motorsports Intake | ST Coilovers | StopTech Slotted w Hawk HPS | H&R F&R Sway Bars| B8S4 19 Tri-Spokes/Peelers
    Tints 50% FD, 35% RD, 20% C-pillar & Rear | Under Seat Drawers | 3M Glossy Black Side Markers
    Jun 14 2015
    Modesto, CA
    Take it apart and clean. It's easy.
    I had to fix a sticky "forward" button in my 2012 S5 this weekend after someone spilled soda on the MMI console. Some websites suggest spraying something like window cleaner on the button, but that's just a temporary fix. They stick again when they dry. Just follow the directions here for disassembly:
    http://www.audienthusiasts.com/Project_MMILED.html
    http://blog.ocarbon.com/2010/06/b8-a...removal-guide/
    Once apart, I just cleaned the buttons with q-tips and window cleaner. You can use alcohol if handy. Very easy. Took me less than an hour and they now work like new.
    Established Member Two Rings geekinc's Avatar
    Feb 12 2011
    az
    This stuff worked for me. Don't know what spilled as I bought the car that way but this will clean the contacts, won't harm the plastics and is electronics safe. Just spray and actuate the buttons or knob. It may take a couple of applications but it will take care of the sticky situation.
    --geekinc
    2008 A4 2.0T Quattro 6MT Ibis/Black SLine APR TUNED
    Jan 13 2020
    AZ
    Whew! I finally got our MMI control panel working. Something dripped onto our panel that was causing all the main control buttons to stick, especially the Menu and Back buttons.
    I was really concerned that I would have to remove the panel, and wasn't sure if I would be able to clean it effectively if I did.
    I used the MG Chemicals Contact Cleaner referenced above, and it got most of the buttons working freely again. But, the Menu / Back buttons were still sticking after multiple applications.
    I figured that what I needed was something thin enough to slip around the edges of the buttons, but stiff enough to allow maneuvering and run around to loosen the dried gunk.
    The buttons fit really tight (German engineering) - but I found a solution. I used the SIM card ejector for my cell phone, which is very stiff and much smaller than a paper clip. Combining the MG Contact Cleaner with running the SIM card ejector around the button edges did the trick!
    My MMI buttons all move freely now, and hopefully I've saved myself a fist-full of hundred dollar bills.
    AzJazz
    Established Member Two Rings jang's Avatar
    Jul 27 2019
    Europe
    Quote Originally Posted by AzJazz View Post
    AzJazz
    Had to replace circuit board while ago, apparently some liquid got inside and corroded it. Some buttons and lights stoped working.
    About 35 usd new circuit board + my own labor.
    Sent from my iPhone 11 Pro Max using Tapatalk
    Registered Member One Ring mobiquio's Avatar
    Jun 10 2020
    California
    The craziest thing just happened.
    I jumped in the car after 2 days to get some food and the MMI Screen went to the navigation screen and the radio was still playing so I didn't think any of it. Then while I was driving I noticed there was some spray on the MMI Control buttons. The spray was from a little bottle of air freshener that I put in the cupholder. Apparently, when the plastic bottle expands from sitting in the car it builds up enough pressure to spritz out some spray. So now I am back home and grab some paper towels and wipe up the spray off the buttons and that's when I find out none of my buttons work or show the active button indicator light. None of the buttons on the MMI Controller work now. The on/off button on the dash next to the screen also does nothing.
    Wow, this is the most sensitive control board I have ever seen. Seems like just a little bit of liquid will freeze up the system.
    So far I dried the spray as much as I could and also used an air compressor to blow out any liquids around the buttons. Sprayed some Alcohol around the buttons and blew it with the air compressor again. Now I am just gonna wait and see if after the liquids evaporate it starts working again.
    Just in case. Does anyone know where I can find the part number for the Control Board for this 2011 A6.
