Results 1 to 38 of 38
    Active Member Two Rings jun3ybug's Avatar
    Feb 18 2012
    Missoula, Montana
    Help with Code P0411 Secondary Air Injection blah blah - Upstream flow
    Hi guys! I am new to this forum so be nice, lol.
    Anyway, I just bought a 2004 A4 last Friday and I got a stupid CEL already. I went to O'Reillys and used their scanner and it gave me an error of P0411 Secondary Air Injection Upstream Flow. I just kinda looked around the engine when I got home and was trying to see if there is any leak/broken hose... Not really sure what to look for exactly. I'm going to have look again tomorrow when it's light out.
    I will be going on a snowboard trip this weekend which is about 2 hours away from where I live. Do you think it's fine to take it?
    Thanks for your help!
    Dec 18 2011
    Colorado Springs
    This should help
    Read every post by Old Guy
    http://www.audizine.com/forum/showth...ighlight=P0411
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Veteran Member Four Rings 2.7taudi's Avatar
    Sep 08 2011
    Houston, Texas
    Quote Originally Posted by jun3ybug View Post
    you can drive the car like normal. the secondary air pump is strictly for emissions purposes and will not cause any stress to any other engine components. the pump however, is about 400 dollars.
    all it does is send extra oxygen to the catalytic converters on cold starts to quickly warm them up for optimal use and you will not pass emissions (if your state requires it) with that code. but is perfectly safe to drive.
    Garage: 2001 A6 2.8 FWD 5AT & 2002 A6 2.7T 5AT
    Feb 18 2012
    Missoula, Montana
    It was not okay to drive
    Took it to the ski resort yesterday which is about 95 miles from where I live. Got there fine. But on the way home, just about two miles from the ski resort, the CEL started flashing at me! I pulled over to the side of the road and the car started vibrating, shaking really bad. It felt like it was going to blow up. I was so scared and called Triple AAA. I had them tow me to the nearest town which was about 15 miles. The towing place has a mechanic who works on Audi's so hopefully he will be able to take a look at it today.
    Based on these symptoms, sounds like a bad coil, right? How much should I look into spending?
    Thanks guys!
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2012 TT Sold
    Maine
    Hopefully they havnt been changed under recall. Make sure you ask. So it will cost you 0. CP's are about 20$ or so a piece. Take about 10 minutes to change all 4. Also the code - Take a look at the passanger side. just behind the headlight...look at the tube see if came undone. Had similar issue in the past.
    2002 A4 1.8T - sold
    2007 DTM S4 -Sold Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    2012 TT - TTS Rear & Exhaust- UNI Stage 1+ " More to come"
    2021 SQ5 - " Just getting started
    Jun 08 2008
    Calgary AB Canada
    Yeah, one coil should be a $50 fix MAX for everything. If the shop charges you more youre getting ripped off.
    This has nothing to do with your SAI not functioning properly, and is also why everyone should keep at least one spare coilpack in their trunk at all times
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Feb 18 2012
    Missoula, Montana
    Ugh. The shop just called me and said I have a bad coil. He's charging me $60 for the part and $34 labor which is not bad. BUT then he is charging me $68 for diagnostic. Isn't that included in the labor? This shop is in a really small town and if I have it towed to where I live it would cost lots of $$$$ 'coz it is 95 miles away. Do I have an alternative here or just deal with it and get the car?
    Veteran Member Three Rings meistah's Avatar
    Mar 28 2010
    vancouver, BC
    $60 JUST for the coil?!?!? The worst price I have seen on a coil is $45... it should be 20 or 30 for the coil and the same in labour. $68 for diag is $$$ too, that should be around $45... Alternative would be changing the coil yourself?
    Jun 30 2008
    Erie, Pennsylvania
    Make sure you get a detailed work order/receipt from this mechanic. If your vehicle has not had the recall yet, Audi should cover the parts and labor for you I believe. You have to submit for compensation.
    Feb 18 2012
    Missoula, Montana
    Can I get reimbursed for this? I bought it used and the previous owner has never replaced them before.
    May 03 2010
    2012 TT Sold
    Maine
    You might be able to. Call audi of america and see. Also go to a audi dealership and get the others looked at. Call and give your Vin 1st they can tell you if has had the recall done.
    2002 A4 1.8T - sold
    Senior Member Three Rings andrew.k's Avatar
    Sep 08 2011
    Pickering ON
    Take it to the nearest Audi dealership.
    If it isn't covered under the recall you will probably pay close to the same if not less.
    If it is, then it will be free. Changing coil packs is incredible easy, I think hes trying to rip you off because your a girl.
    SQ5, PORSCHE MACAN S
    Veteran Member Four Rings natalia's Avatar
    Jul 13 2008
    hula hoops
    Denvemolorado
    Keep could in your trunk. I learned this the hard way.
    Senior Member Two Rings shoemaker617's Avatar
    Nov 15 2011
    east coast
    Hi hun, I happen to fix Audi's for a living. I'd be happy to run you VIN to see if the J1 recall is open for your car. PM me if you like
    Veteran Member Four Rings waldo1324's Avatar
    Apr 06 2009
    the Ghost of the Princess, 2007 Ford Fusion, 2006 Honda Accord
    The StL
    sooo,, this is for realz?
    1) ^ yes keep coil packs in trunk
    2) FIND SOMEONE FROM HERE NEAR YOU WHO CAN WORK ON YOUR B6 NEXT TIME SHE BREAKS! UNLESS HE LOOKS LIKE MY AVATAR<<<<<<<<<<<<<
    ""GHETTO MODIFIERS"" member #1
    The Princess: SOLD.. i love you, please forgive me
    "I agree with Waldo 100%" -1997GTX
    ..psst if you have a 2003+ 225 TT, email me..wally.iverson(at)gmail.com
    Feb 18 2012
    Missoula, Montana
    I just called the local Audi shop here in town. They're not a dealer but they're Audi Certified. They looked up my VIN and the previous owner hasn't changed the coil pack. They said they will replace mine for free! Yay! So happy to hear this! Now, I'm just going to pay the mechanic from the other town so I can drive it back to here. And hopefully, I can get reimbursed for that.
    Thanks for your guys' advice!
    Nov 15 2011
    east coast
    Good to here that, as far as the secondary air fault. Most of the time I see broken vacuum lines going to the combi-valve located on the back of the motor. Hope this helps :)..........love the pic btw
    Mar 28 2010
    vancouver, BC
    Glad it worked out. Now post up some pics of your new car!
    Feb 18 2012
    Missoula, Montana
    I picked "him" up last night. He is running so smooth I didn't know that made a HUGE difference. Even the gas mileage is better.
    I wanna do some mods first then I will post pics. Lol. I got the windows tint the very first weekend I got him. But I wanna do clear corners first and my tires look like crap. I am sooo excited!!!
    Mar 28 2010
    vancouver, BC
    Great! Things like coilpacks and spark plugs can make your car go from feeling like an '88 jetta to a brand new car.
    Clear corner is a great mod, I didn't do it until recently. It's small, but visually it makes a big difference. Looking forward to seeing it
    Veteran Member Three Rings DNasty777's Avatar
    Aug 01 2010
    '69 Plymouth Valiant
    Rochester NY
    Just a side note, if your SAI pump does go bad, you can pick one up off amazon for about $250 shipped. Hell of a lot cheaper than the dealer and swapping it out is cake, only takes about 10 minutes.
    2003 A4 1.8TQM
    [Tein S.Techs][Bilstein Sports][RPM 505s][RAI TP][Milltek DP][TT225][Uni Stg2][Magnaflow 16601][Hyperboost DV]
    --Dave--
    Feb 18 2012
    Missoula, Montana
    Quote Originally Posted by DNasty777 View Post
    Sounds good. I am taking it to a shop on Thursday and I will know what the problem is. Thanks for letting me know
    Feb 18 2012
    Missoula, Montana
    My baby is sick again!
    Just before I pulled up to a car wash, solid CEL came on again. I have an appointment this Thursday to get the rest of my ignition coils replaced for free.
    Someone tell me this is going to get better!!! Or this is how it is every week? Lol. He is soooo much fun to drive and I really can't see myself driving a different car. Sigh.
    May 03 2010
    2012 TT Sold
    Maine
    Its prolly just your SAI code comming back. Hopefully its just tube disconect and a really easy fix. You really should get a VAG tool. Will be your cars best friend and can save you $100's easy.
    2002 A4 1.8T - sold
    Feb 18 2012
    Missoula, Montana
    Quote Originally Posted by A4Maine-iac View Post
    Do you have a link to amazon/eBay thats a good deal?
    Feb 18 2012
    Missoula, Montana
    Quote Originally Posted by meistah View Post
    How much did yours cost?
    Mar 28 2010
    vancouver, BC
    An alternative to SAI pump replacement would be removing the SAI system altogether... You can probably get a tune for your car that eliminates the CEL.
    Search amazon for: audi secondary air pump
    How much did my coilpacks and spark plugs cost? or the clear corner mod? Coilpacks should be around $20 a piece... Clear corner mod is free! You take your headlight out, remove the bulbs, drill 2 small holes to pop the corner lens out, then pull it out with your fingers, seal the holes with some sort of sealant.
    DIY: http://www.a4mods.com/index.php?page...earcorner.html
    Feb 18 2012
    Missoula, Montana
    I'm getting my ignition coils replaced today. Turns out I have a bad combi valve. They said it would cost around $400 to fix this. Is that too much? anyone?
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    I'm not sure how the combi valve could go bad - it's fairly simple. I would do coils for sure, but I don't know about the valve, it may just be a cracked or broken line.
    Shit, I just realized you are in Missoula. I have peeps up there that can help you out - go to http://www.bigskyeuro.com
    Where did you take it - Mountain Imports or Import Palace? I went to UM and am alumi.
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Aug 01 2010
    Rochester NY
    Quote Originally Posted by MikeWire View Post
    The valve is metal and it is on the back of the head, they can get clogged with gunk. They recommend replacing it whenever the SAI pump goes bad. A new one is ~$75 with gaskets from GAP, and replacing it is easy enough. $700 seems astronomical to me, I'd do it for a friend for just a beer.
    2003 A4 1.8TQM
    --Dave--
    Feb 18 2012
    Missoula, Montana
    Yeah, the coils are free anyway. I took it to Mountain Imports. Hook me up with these people
    I went to UM as well!!! Graduated 2010.
    Feb 18 2012
    Missoula, Montana
    $400 is what they quoted me but still... I'd buy you beer + dinner but you live so far away lol
    Mar 08 2007
    Air and water
    SATX
    Excellent, they will take care of you there - glad you didn't take it to some oddball repair shop. Click on the link in my sig or the one in my last post, sign up on the site and meet up with the local crew. I was just up in the Zoo last month and we had a small GTG, maybe you can make it to the next one.
    Edit - there's guys up there that work for beer etc., plus you are a girl (I assume from your avy lol), so you're in. I can vouch that there are no creeps
    -Mike
    @countdowngarage
    Feb 18 2012
    Missoula, Montana
    Yeah, Mountain Imports seem like they're really honest. They are super helpful too. Lol. No creeps = definitely a good thing. I'll definitely sign up on this website then! Hopefully, someone will give me a hand on clearing corners too lol
    Senior Member Three Rings Barker29's Avatar
    Jan 19 2010
    2018 VW Atlas
    South Jersey
    I had the same issue with the sai and if it is the combi valve i'm sorry to hear that but first things first check the 40 amp fuse under the hood and make sure it isn't fried because that is a 2 dollar fix and second you can get a new sai pump off of the classifieds for 50 bucks no need to spend all that money
    Sep 12 2012
    Charleston Sc
    HAHA! audis' only have problems if u buy used and dont know whats been done to it. regardless yess you will experience multipule multiple more problems. Gotta love the game to drive one. I LOve my baby girl Aduri
    Sep 16 2010
    Central Wash
    Oct 26 2012
    West Palm Beach, Florida
    I just got that Code too. But I have already changed the EGR Valve. Is the EGR Valve and Combi-Valve the same? I have a 2000 Audi A4 1.8T 5-Speed Manual, and I am the ONLY Owner. The car is doing 429830 Original Miles as of 10/26/2012. I hear no whines, whistles or whatever when the Engine is off or on. What could be another Problem? When I got the Light, I went to Discount Auto Parts, and on the Scanner it showed P0411 Code. Could someone tell me some other Low Cost Repairs please, before I tackle the Pump?
