Check engine light came on the other day so I decided to scan the car with the ross tech vag com. Came up with this DTC:
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Part No SW: 8E0 909 518 AK HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0004
Coding: 0016711
Shop #: WSC 12849 539 435846
VCID: 79F7EF2333C24D6
1 Fault Found:
18613 - Performance Malfunction in Cooling System
P2181 - 008 - - MIL ON
Readiness: 0000 0000
Seems like it could either be the thermostat or the engine temperature sensor located behind the block.
I'm driving a 2004 A4 1.8t quattro manual. I replaced the coolant temperature sensor that's connected to the radiator hose a while ago, that solved the first engine light that came on at the time. Then now this came on. What do you think?
Also, I checked the fans, they are both working. Ontop of that the heat is working just fine too. The temperature gauge gets up to normal temp within a normal time as well. The normal cold start does not work anymore (starts around 1300 rpm) and the fans seems to be running a bit high. Thoughts?
