Results 1 to 28 of 28
    Feb 12 2012
    louisiana
    4 spoke wheel B8 A4 paddle shift retrofit??
    So I picked up the last 2012 A4 in ibis on the lot but it did not have the sports package. I really want the paddle shifters but it doesnt look like theres an easy way to get a 4 spoke wheel with shifters. I really don't want to put out 1G for the 3spoke with airbag. I've been looking on eBay.de like another post suggested but haven't had any luck. Anyways there are some b7 4 spoke wheels with paddle shifters on eBay. Any idea if it would fit? Any other options that won't cost so much? Best case would be for me to find a wheel where I can keep my existing airbag. Any info would be much appreciated.
    http://www.ebay.com/itm/Audi-A4-4-Sp...item3cc1b996df
    Apr 05 2011
    Pacific Northwest
    Hey there...so you cannot put paddles into the OEM 4 spoke. Not made for that. And you cannot switch to a 3 spoke with paddles and keep the airbag either. I don't know of an option where you can either. I kept my eyes on the forum and found someone selling an OEM 3 spoke with paddles and airbag and scooped it up for $400. That was reasonable to me. Look at the classified adds and see what you find. I saw another 3 spoke recently at a reasonable price too. Most folks post them and ask $1K or more, but in reality they won't get that because you can buy a new one from Alex@Europrice for a bit more than that.
    Highlander's Build Thread
    Feb 12 2012
    louisiana
    Hi, thanks for the heads up. I'll definite keep an eye on the classifieds. Hopefully I'll find one at a reasonable price also.
    Senior Member Three Rings Nison_Li's Avatar
    Mar 05 2011
    '15 Q5 3.0T S-Line
    Baltimore, MD, USA
    how much are you looking to spend? i have a rs5 wheel and i'm looking to upgrade to one of those facelifted version. PM me if you're interested
    2015 Q5 3.0T S-line Premium Plus
    Done: LED interior bulbs, S7 Steering wheel, RS5 Pedals, warning tri angle, VCDS mods.
    Planned: Tune, Alu Kreuz, Sway bars, under seat drawers
    Oct 27 2009
    Miami, FL | Boone, NC
    I bought a four spoke wheel with paddles (I reused my original airbag).
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Feb 12 2012
    louisiana
    Where did you get the 4 spoke with paddles? And how much?
    Oct 27 2009
    Quote Originally Posted by lp0525lp View Post
    I bought it on the classifieds for $220. I think it was from a B7...
    There is one small vag-com change you have to make in order to enable the paddles. It is in the steering wheel module, and there is a clearly labeled checkbox for the bit.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Feb 12 2012
    louisiana
    yea i saw a b7 one on ebay but wasn't sure if it would fit or not. Thanks for confirming. I will look for a b7 one now. One question. The b7 wheel doesn't have the silver around the buttons like the b8. Any idea if those could be swapped before install?
    Oct 27 2009
    The short answer is yes. However, it is a major PITA...
    You cannot simply swap the multifunction buttons assembly from your old wheel to the new wheel because your current multifuntion buttons do not have the connectors for the paddles. So I removed the casing from both sets of controls and put the B8 casings on the B7 controls. There are two circuit boards (connected by a ribbon cable) in each casing, so while the swap is not extremely difficult, it does require finite work. The B8 casings fit on the B7 controls. However, the B7 casings doe not fit on the B8 controls. I guess I got lucky that the B8 casings fit on the B7 controls... The process of swapping the casings took around 45 minutes.
    It was well worth the work IMHO. The chrome border makes the steering wheel look a lot nicer. The all black controls are too boring.
    The end result: (B7 steering wheel, B7 multifunction control internals, and chrome-bordered B8 multifunction control casings.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Established Member Two Rings Aloyouis's Avatar
    Nov 21 2005
    2008 A4 S-Line
    MICHIGAN
    Great thread. Question:
    I have an 2008 A4 S-Line and a 2012 A4 Avant prem. I see from above it is possible to put the 08 steering wheel on the 2012. Can I put the 2012 wheel on the 08? Also, I want to swap the rear view mirrors as well 08 has auto (dim/compass). Is this possible?
    Thanks!!!
    Nov 21 2005
    2008 A4 S-Line
    MICHIGAN
    I have an 2008 A4 S-Line and a 2012 A4 Avant prem. I see from above it is possible to put the 08 steering wheel on the 2012. Can I put the 2012 wheel on the 08? Also, I want to swap the rear view mirrors as well 08 has (auto dim/compass). Is this possible?
    Thanks!!!
    Veteran Member Four Rings b4a41point8t's Avatar
    Jun 06 2009
    Los Angeles, CA
    You can get OEM wheels with paddle shifters from Germany. I've been seriously debating it but i figure if Im gonna drop loot on a new wheel then I'd rather not settle and go with 3 spoke sport (thicker wheel) with paddle shifters. Here's one for you :)
    http://www.ebay.de/itm/LEDERLENKRAD-...item3a90080947
    Established Member Two Rings knightmare's Avatar
    Jun 06 2015
    Syracuse, NY USA
    Do you know if this would fit my 2009 B8 A4? I can just install my existing airbag and enable the paddles?
    http://www.ebay.com/itm/Audi-A4-Stee...15435e&vxp=mtr
    Jan 10 2012
    Republic of Boulder
    Quote Originally Posted by knightmare View Post
    The airbags on 4 spoke and 3 spoke steering wheels are not interchangeable. So if you've got a 4 spoke wheel, you'll need to purchase a different airbag.
    PREVIOUS:
    1991 Audi 200TQ Avant
    2001 Audi S4 Avant
    2009 Audi A4 Avant (click)
    2014 Audi allroad
    Jun 06 2015
    Syracuse, NY USA
    OK, thank you for that info. :)
    May 21 2013
    Mississauga, Ontario
    bump^
    Sorry but you're wrong crash. A 4 spoke airbag DOES fit a 3 spoke and vise-versa... Tested and confirmed. Did this in my B7 with MFSW.
    Swapped my old non s-line (4 spoke) wheel to an s-line (3 spoke) MFSW with paddle shift and used my original airbag from the 4 spoke. No problems what-so-ever.
    Oct 27 2009
    Quote Originally Posted by Constantine View Post
    bump^
    I don't see how that can be? Unless you removed the front facing piece from that airbag mechanism which I didn't think was possible. They have different cutouts for the different spoke arrangements
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    May 21 2013
    I may have goofed, my fascia just popped off and I ended up using a backing ring (with the 3 spoke cut out) from a blown airbag.
    Senior Member Two Rings KompressorLOgic's Avatar
    Aug 15 2013
    93 Mazda Rx7
    Puyallup,WA
    hmm well since this thread was bumped back up!
    I just did the b7 4 spoke with paddle swap into my b8, using the chrome cased buttons out of my b8 wheel.
    each button has 1 little screw and the plastic casing come off, must be swaped onto the circuit boards inside from the b7 wheel but they snap right on. they are pretty thin plastic so be careful when taking them apart!
    installed, works great after recode to enable!
    17 Audi A4 P+ ,Daytona Grey, Sport+,6sp manual,034 dynamic+ springs and sway bar,
    10' Audi A4 2.0T P+ Meteor Grey APR stg2, HFC, TDI IC, solo-werks S1
    Oct 27 2009
    Quote Originally Posted by KompressorLOgic View Post
    You did the same exact thing as I did. Great result!
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    May 21 2013
    So this worked great in my b7, and now I'm running into an issue in doing the same to my b8 (2009)
    Got a b7 mfsw + paddles, installed (seemingly plug and play). Same connectors and fitment, BUT when I go in with vagcom, 16 - instruments>7 - coding> byte 2, check off tiptronic, exit and click "do it!"
    It accepts the coding, but then when I open up coding again to confirm it has the old value stored (000016) and the paddles don't work :( (not in D, S, or M).
    For some reason the 000036 coding isn't sticking!
    Any ideas about what's going on?
    Established Member Two Rings Anthony1491's Avatar
    May 15 2015
    Toronto, Ontario
    Had the same problem, switched to a windows 7 pc instead of using windows 10 fixed it. Is it a real cable or fake? If its fake make sure your using the correct version that you bought it with. For example, my 12.12.3 cable came with 14.14.10 (or something) software but it only worked with the 12.12.3 file
    Hope that helps
    2011 Audi A4 Deep Sea Blue
    GFB DV+ - RS4 Grill - ECS Silicone Inlet Hose - Tint - AFe Filter - Ultra Racing Strut Bar - Eurocode HFC - Intercooler Soundbox Delete
    Steering Wheel Paddle Shifter Retrofit - Rohana RC22 19" 9.5 et45 - S4 Struts & Sway bars - Rev Motoring Springs - Custom Magnaflow Exhaust
    May 21 2013
    That was it! Cable reads 11.11, I'm also on Windows 7, but using vcds 11.11.3, found 11.11.0 software and it worked :D
    Established Member Two Rings TheOriginal's Avatar
    Apr 03 2014
    Eastern Missouri
    So just want to clarify:
    I have 2 options for getting paddle shifters on my b8 a4; b7 4 spoke or b8 3 spoke wheels. If I got the 3 spoke then I would need a matching airbag? Or can i switch the face plates?
    What is the vag com coding to activate the paddles?
    May 02 2011
    '15 A6 3.0t, '14 GMC Denali Duramax, '12 F150 EcoBeast
    Casper, Wyoming
    Hold up here, am I reading this right? You can take a B7 4 spoke with paddles, swap the switches and airbag from your B8 4 spoke, and with a bit of VAGCOM magic get the paddles to work?
    I'll uhhh be at the junkyard...
    Apr 03 2014
    Eastern Missouri
    Yes I've done a bit of research, the b7 steering wheel with paddles can be swapped no problem. But ignore the part I said about air bags on 3 spoke wheels... The guy above got lucky and had a blown 3 spoke laying around haha.
    Oct 27 2009
    Quote Originally Posted by buelldozer View Post
    Yes, but you can't swap the multifunction controls exactly per say (the non paddle controls do not have the connecters for the paddles), but you can swap the casings of the controls (I did so because I like the alu border around the B8 controls).
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Aug 30 2016
    westminster, ca
    Hi all
    New to the forum. I have an a4 b8 2012 2.0t with a 4 spoke steering wheel, just swapped for a 4 spoke with paddle. I got lucky on ebay and found a 2009 b7/b8 4 spoke steering wheel w paddle for $100. It's definitely rare these 4 spoke with paddle. It took me a good two weeks of repeat search on eBay to find this. I definitely didnt want to spend alot for a new 3spoke which would require a new airbag, runs around 300-450 from eBay depends on how you buy.
    I used the new wheel, paddle, and the mfsw circuits with my plastic housing from my non-paddle wheel. The swap isn't too difficult. The difficult part is finding the right wheel if you want to use your old 4spoke airbag.
    On side note, I'm in the process of researching to see if I can reverse the paddle so that left is up shift. Anyone with info, please advise. Thanks
    I'm happy to help anyone around SoCal who needs help w this or need to use vcds for coding.
