After some research, the cooler you can keep the oil temperature down, the longer you will keep your tranny. Today, the tranny oil cooling is done by an exchange water/oil and since the tranny radiator is attached to the water radiator, having the water cooled down to 200F in normal operation, I can't expect any better.
Since I installed the AWE intercooler last week, I have now plenty of room by the right side scoop and I start to think installing an additional Air/Oil radiator in this area, with custom lines.
Now comes the questions:
Does anyone have done this mod in the past?
Type of radiator installed since there is so many available?
Temperatures logs after install?
Did you keep the original setup and added the radiator to the circuit or simply condemned the original system
Any feedback would be great
Phil
