Results 1 to 16 of 16
    Veteran Member Three Rings MarcMiller's Avatar
    Feb 22 2011
    Philly215
    Rebuilding PS rack?
    So my power steering rack took a shit on me.
    Originally i was going to buy a new rack and go through that whole process but recently I'm starting to think of other options.
    My friend goes to an automotive school and he said he's rebuilt rack seals before and he would do mine.
    Has anyone on here ever done this or know if its possible?
    It would save me a lot of money so I'm really leaning towards this option.
    He already found a repair kit too.
    Thoughts?
    Much appreciated.
    May 16 2008
    South Texas
    Quote Originally Posted by MarcMiller View Post
    Thoughts?
    Much appreciated.
    Repair kits are not available from Audi or ZF. You might be able to source the seals separate but who knows. Might want to look at a reman rack and just replace it. Good luck!
    Feb 22 2011
    Philly215
    Quote Originally Posted by Scotty@Advanced View Post
    http://www.rockauto.com/catalog/cata...871720-5094682
    Thoughts?
    May 16 2008
    South Texas
    No Parts for This Category
    I don't see anything on that link.
    Feb 22 2011
    Philly215
    Rack and seal kit
    Feb 09 2007
    00 S4
    MA
    I have an extra PS rack, brand new inner and outer tie rods on it too.
    pm me if your interested
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    Feb 27 2005
    North Wales, PA
    just buy a new one. they are one of the worst jobs there is to do on the b5. I hated every moment of my life when i replaced mine. If it didn't work after fighting to get it in, i would have taken a sledge hammer to my car.
    Active Member Two Rings treeski's Avatar
    Jan 02 2011
    RI
    http://www.vwparts.com/parts-outlet-center/index.php
    Part# 8D0-419-502
    That might be the best option around.
    Feb 22 2011
    Philly215
    The only thing that I'm worried about is that i have a 2.8. From what i seen the part numbers are different from the 1.8 and 2.8.
    Cheapest i found the rack that matches up with my car is 500$
    Jan 02 2011
    RI
    Hmm this is true. Well the 2.8 has a steering damper where the 1.8 does not. From pictures they look like the same steering rack, and if thats the case then you could just bolt the damping gear on from your original. It might be worth a shot to give the dealer's parts department a call on it
    Feb 22 2011
    Philly215
    well the repair kit didnt work..put it in and instantly it started leaking fluid again..i bought a new rack from ebay for 305$ with a 175$ core charge.
    just gotta wait for the new one now.
    Feb 22 2011
    Philly215
    Help me out audizine...
    Does anyone know what to do when the steering rack and the steering column dont line up? I dont wanna turn the rack and **** that up and i dont wanna turn the steering wheel and **** the clockspring up...any thoughts?
    Veteran Member Three Rings Scientist's Avatar
    Sep 08 2011
    2001.5 A4 Avant
    Troy, NY
    My experience with remanufactured steering racks has been a waste of money. I ended up paying twice. It is a gamble getting a remanufactured steering rack that has been remanufactured to meet QC standards.
    IOW, you pay now for the real deal or you'll pay later (twice) for a cheap POS.
    Feb 22 2011
    Philly215
    Quote Originally Posted by Scientist View Post
    Okay but i already have the rack..it has a warranty and everything. Thats not my problem.. Im trying to figure out how to line them both up together. I dont wanna mess the rack up by turning it too much or something or turning the steering wheel too much so the clockspring gets messed up.
    Jun 30 2008
    Erie, Pennsylvania
    It's not going to hurt the rack to turn it. That's kind of it's job, actually. Nor will it hurt to turn the steering wheel, as that is also it's job...to turn.
    You just don't want to turn the steering wheel a bunch of times before you bolt it up. That's where you run into problems. If the car has ESP (equipped with a steering angle sensor) it is just important that it stays centered. So leave the steering wheel at the centered position, install new rack, center it, and then bolt it up. You can turn it a bit to line it up, just don't give a full rotation or anything.
    Feb 22 2011
    Philly215
    Yeah i left the steering wheel straight when i took the old one out now the new one is in and the gear doesn't line up. It looks like i might have to turn it about 45 degrees to line it up.
    I also just replaced all my control arms uppers and lowers, my pass axle, and the tie rods.
    Maybe that has something to do with the steering being off?
    The company told me they center the rack before they ship it..im not sure if i could of maybe shifted it as i put it in?
