Originally Posted by
Bushum
Chris,
Was yours making any noise before you took it apart? Here is what mine sounds like. It went from a light tick to this noise in about 25 miles time.
http://s665.photobucket.com/albums/v...t=MVI_4107.mp4
Diagnosticator,
If the surface is ruined would I need a new crank or just machine this one? I assume with machining it would require custom sized bearings. Also do you think something like this would cause out of round in the cylinder or ruin the rod as opposed to just bearings?
The hardness of the crank is much harder than the bearing shell, and due to the very limited miles, there is an very good chance the crank journal is fine, and a same size bearing shell can be reinstalled. Practically all bearing failures are caused by lubrication faults, like Chris showed where the bearing shell rotated in the connecting rod, misaligning the lube delivery hole. Incorrect assembly can result in the lube oil hole being on the cap side instead of the rod side, preventing lube to the piston pin bushing. If the lube to the piston pin is blocked, due to bearing shell rotation in the rod, or from misassembly, then the noise could be coming from the piston pin bushing and not the con rod bearing. The rod bearing is lubricated from the crankshaft drillings, and even if rotated, the rod bearing will always be lubricated. The piston pin bushing is lubed by the hole in the rod bearing and a drilled oil passage in the con rod from the big end to the small end bushing. If the rod journal is damaged, then the rod journal can be re-machined undersize, and an undersize bearing shell installed that matches the new journal diameter. There is usually no connection between the bearing failure, and any other damage to the rod, or an out of round cylinder. If the rod bearing has rotated, and the piston pin lube hole in the bearing blocked, then the head must be removed to get the con rod/piston assembly out of the block so that the piston pin bushing can be replaced also.
