Hello guys, I have a problem here. I cleaned my throttle body and mass air sensor. I now have a pretty rough idle. The car is jumping all over the place between 800-1200 RPM. I'm not sure what the problem is. I cleaned the throttle body and mass air sensor according to procedures I've researched on this website and a few others.
I used the appropriate cleaners (MAF cleaner on mass air sensor, throttle body cleaner on the TB), checked for vacuum leaks, made sure everything was assembled properly, followed the Throttle body adaption procedure according to RossTech, etc...
I did have an issues when I went to do the initial throttle body adaption with VAGCOM. I got an "ERROR" message in the adaption status box. And then two DTCs came up in the engine controller and ABS module:
1 Fault Found:
17967 - Throttle Body (J338)
P1559 - 008 - Fault in basic settings
1 Fault Found:
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-00 -
I tried to do the alignment a second time and the same thing happened- Failure. The throttle body clicked as if it was trying to align and then I got the "ERROR" message again.
I did something different the third time. I started the engine, let it idle for a few minutes (idle was rough), turned it off, and then tried the adaption again. VAGCOM was showing "Adapt. status OK" in the status box so I ran the adaption. VAGCOM displayed "OK" after the program ran so I started up the car and again, it had a very rough idle.
I have no idea what is going on or why I got an adaption error the first two times I tried to do an alignment. Any ideas? I think I am going to disconnect the battery tonight and try to run an adaption in the morning.
