Originally Posted by
M-Hood
Yeah that is because the exhaust wheel effects what % the compressor can flow of its max flow rate for its specs. This is why the 2871 with a 47mm exhaust wheel has a much lower flow rate vs the 3071 with the same exact compressor wheel but with a much larger exhaust wheel.
Don't you mean the GTX is a forged wheel since they aren't really billet? Only reason Garrett came out with the GTX line is because they were losing business to all of the companies offering turbos with new wheels.
While that makes sense Mike that is not how they do it. When Garrett does flow testing with their compressors it combines only the compressor housing and the compressor itself. If you look at their GT compressor maps you will see all the details listed and furthermore they list their turbine maps seperate. Email Garrett if you like. Sometimes it takes a while for them to reply but this is exactly how it was described too me from them. If in fact they did as you ar offering then the turbine specs would also be listed such AR and trims and they are not.
Yes the GTX compressors are forged instead of Billet. I use the term Billet like most in reference to a compressor that is CNC machined instead of cast. You don't want t get me started on GTX compressors as they are total rip off and a complete waste of MONEY (my personal opinion).
Also if you really want to get into how many there is of each turbo there is far more then you specified and Garrett does not list every option on their site, only the most popular. For a GT2871R here is just tid bit of the options,
48, 52, 56 trim
T25 .48, .64, .86 (both with and without wastegate flapper)
T3 (or T31 4 bolt) .63, .82 and V band)
T3 5 bolt .36, .48, .63, .82
T3 cosworth
T25 plus (.63 and .82)
T25 external wastegate .72AR
Compressor options T3, T04E, T04B, T04S, Nissan style with bolt ons (2 bolt inlet and 3 bolt outlet), and even T04Z if I remember correct. SOme of these options are special order. You can also get a GT2554R compressor housing in the GT2871R and GT2560R.
The part numbers you are referring to specifically are ones that garrett lists since they are considered most popular options.
My point had nothing to do with any of this and frankly I find it nit picking a very simple point; The flow rates listed are not 100% since the trims for those tubo combinations are not listed. I have seen people buy T3T4 turbos and then wonder why they are maxxing out 250whp when others are making over 400whp and then they find out they are using 40 trim compressor.
My point was to those that looked at this and would draw the simplified expectation that ALL GT2871R flow 45 lb min or ALL GT3076R flow 52 lb min.
