Page 16 of 16 FirstFirst ... 6141516
Results 601 to 632 of 632
  1. #601
    Established Member Two Rings darren p.'s Avatar
    Nov 30 2015
    Mk2 GTI VR6 B5 S4 Avant E90 M3s
    Quote Originally Posted by TheRussian View Post
    So I just did the retrofit into my depo headlights. Wasn't too hard. It does require a little cutting of the new projector to make enough room for the depo mounting nuts, some longer screws for securing the projector lens, and you do need to cut out the bottom of the light and assemble the unit in the housing.
    I will tell you that the retrofit is well worth it. My headlights are bright, I drown out other peoples lights as if they aren't even there. Love that.
    I made a template in AutoCadd. I have attached the template I made. There are 2 alignment squares to help you size it correctly when you print it out. I hope this helps out.
    Just a head up, when I put my lights together I only used the longer screws to secure the lens to the housing to hold the whole unit together. There are 6 total per projector and it is plenty to keep it all together. The template has all the mounting points on it, but you only really need to drill out the depo and lens holes. you can skip drilling out the H1 Housing holes if you want
    Attachment 135106Attachment 135107Attachment 135108
    Sent from my SM-G973U using Audizine mobile app
    Good info!
    I'm not loving the Depo housings and am thinking of going back to my stock housings. Anyone have a template for the Mini H1 7.0s into the stock housings?
  2. #602
    Jul 04 2012
    Woodbridge, VA
    Official B5 A4 / S4 Headlight and HID Thread
    Quote Originally Posted by darren p. View Post
    Good info!
    I’d just take them apart and trace them and make your own template. Chances are they are the same
  3. #603
    Sep 19 2012
    Saint Clair Shores MI
    Good info!
    from what I can tell, by inspection of the original H1 1.0 template at the beginning of this thread, you can use the same template but you will need to trim the top of them to make them fit. I would cut them out and them mock them in the headlight and just trim back whatever is holding you back little by little until it fits in there.
    But I think that vavJETTAw36 is right, I had a lot of space with my template, I could have easily made them have more material if i wanted to. I guess the only way to see is to try it and see.
    also if you wanted to trace and make your own template feel free. That's why i gave the footprint for both the Depo and the mini H1. use the mini H1 footprint and just trace your projector over it.
    If someone does do a Valeo--> Mini H1 conversion if they could post back and let us know the changes they had to make to make them fit. I'm sure someone will thank you.
  4. #604
    Oct 19 2019
    Bringing back and oldie in hopes to gain a little bit of info before attempting a retrofit.
    My question is: the piece that is cut out from the bottom of housing (shown below from original write up) does it get fastened back in somehow? I know the ballast goes in this square section but I can’t see how that would “seal” up housing.
    If anyone can lend some feedback on this please let me know! Thanks!
  5. #605
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    Clear silicone is your friend.
  6. #606
    Veteran Member Three Rings BlkBullitt's Avatar
    Feb 06 2009
    2007 Q7
    Cleveland, OH
    Quote Originally Posted by colbymc View Post
    My solution was to cut a rectangle out of lexan that fits the opening. You’ll need to drill holes in the lexan that line up with the available mounting holes in the housings so you can attach them with screws. For a gasket I used the rubber gasket from the stock ballasts that I had, however, you could diy something if you don’t have them.
  7. #607
    Senior Member Three Rings ezfour's Avatar
    Apr 17 2010
    Nevada
    I just picked up a set of Depo H7 ecodes for my 2001 A4. I see some reference to turn signal bulb/ connector issues. What, if anything, needs to be done to the turn signal connections?
    Will US model bulbs and holders work on Euro housings? Or do I need to purchase bulbs to fit the euro bulb holder and the modify the car side connector?
  8. #608
    Oct 19 2019
    Thanks for the input!
  9. #609
    Dec 08 2010
    02 GIXXER1000, 2000 JETTA GLX VR6.
    fl
    Hi was reading through this project and I have a question about my 2001 b5s4 hid, the bulb socket in particular the passenger side headlight if there is any vibration via ruff surface on the road it goes out. I took it apart and notice that the socket that holds the bulb the contacts are burned out so its not making good contact. saw a bulb socket on eBay with connectors that looks like the only way for them to work is to cut and spliced into the factory ballast wiring for the bolt socket. what do you think is this something that will work? do you have any suggestions for fixing this problem? thanks.
  10. #610
    Sep 19 2012
    Quote Originally Posted by ezfour View Post
    If you do a search for "b5 s4 depos" you can find the info for this. One of the pins on the socket interferes with the housing, it basically takes shaving down one of the pins on the US plug and then it fits. There are a lot of aftermarket chrome bulbs you can get to if you don't want the Amber's sticking out with the clear corner if thats what you bought. I have stealth bulbs in all of my Amber's up front. Even the fender markers.
    Sent from my SM-G973U using Tapatalk
  11. #611
    Sep 19 2012
    Quote Originally Posted by 01silver4 View Post
    I don't think that your problem is road vibration. I think its more likely that the wiring is old and shorted and the headlight was one of the contact points. Take a look at your wiring in the headlight, look for crack and corded wiring. Find a broken headlight and swap out the wires.
  12. #612
    Oct 19 2019
    Does anyone make brackets anymore? Looking for Morimoto mini H1 into depos.
  13. #613
    Orange County, CA
    This thread should have been stuck years back and I just did it so it wouldn’t get lost.
    B5 Parts For Sale
  14. #614
    Veteran Member Three Rings SN95Audi87's Avatar
    Apr 26 2010
    96 Mustang GT/2001 Audi 1.8T
    North Jersey
    Does anyone make brackets for the D2S Depo headlights? I want to do this project. I will be doing a lot of night driving.
    01 1.8T | B6 Sport Wheels | Forge diverter valve | A8/TT Front Brakes/SS lines | 034 HFC & Milltek Resonated CB | APR TIP & Intake |
  15. #615
    Oct 19 2019
    Asked this question months ago and even private messaged the guys who used to make them with no response. I had someone make and retrofit them for me and holy cow the lights are insane. So worth it. I chose the Morimoto mini 7.0 kit with some LED high beams.
  16. #616
    Apr 26 2010
    North Jersey
    Can you send me the guy who did them for you? It will help me a lot. Thanks man!
  17. #617
    Sep 19 2012
    I posted up a template up for the H7's. I lost the Autocad file I used so no 3d printing, but if you print and overlay over lexan (home depot) you can make yourself an adapter for like 7 bucks. You need to cut out the bottom for the ballast and disassemble/reassemble the projector in the housing. It's pretty straight forward and worth every cent.
    Sent from my SM-G973U using Audizine Forum mobile app
  18. #618
    Mar 01 2011
    Calgary
    I retrofitted my D2 S8 lights with Mori Mini 7.0's - TRS had a Bosch 2.4" retrofit kit that was bolt-in, didn't require removing lenses. I'm wondering if this kit will work for the B5 as well?
  19. #619
    Apr 07 2011
    Home of the mighty beaver
    dunno if anyone checks these but I finally found a suitable LED replacemetn for my 55W HIDs that i use in my H7 housings.. They are bright as hell and worked fantastic all this summer.
    downside: no DRL support unlike some like the morimoto LED
    DDM Tuning Saber 55W ProX Accu/V2 https://www.amazon.ca/gp/product/B08...?ie=UTF8&psc=1
    review link:
    https://www.bulbfacts.com/led-kits/r...ed-review.html
    I am putting these in everything. Fantastic bulb.
  20. #620
    Aug 24 2014
    Newport Beach, CA
    How do these compare to the old 55w HIDS? Which headlights are you running? Assuming DEPO H7?
    2024 M3 Comp xDrive
  21. #621
    Apr 07 2011
    yes depo H7 I was running a morimoto 55W HID before. And these are either as, or almost as bright, i dont miss the HID's at all. Well worth getting rid of the stupid ballasts
  22. #622
    May 10 2018
    MA
    Quote Originally Posted by S4James View Post
    useable with an OEM lense you think? (I'm on LHD RS4 HID's). They've always worked fine, but, I do wish they had the outward throw/distance, that my B9 does
  23. #623
    Apr 07 2011
    well the depos have a decent lense. i did try swapping in a TSX lense and it did didly squat... As far as the stepped OEM lense? Could not tell you, i expect its fine.
  24. #624
    Jul 04 2012
    Woodbridge, VA
    There’s still a power supply box. 6 and a half dozen in the other
  25. #625
    Apr 07 2011
    Quote Originally Posted by vavJETTAw36 View Post
    yes but its tiny, and fits easily inside the housing. Unlike my HID balasts. Plus I hate the look of the things.
  26. #626
    Veteran Member Four Rings awd2ks4's Avatar
    Aug 24 2008
    2000 S4, Blown LS2 240sx hatch, LS3 240sx vert, 02 wrx
    Santa cruz
    So for depo ecodes in h7 what harness needs to be ordered hd relay 9006 or canbus 9006
  27. #627
    Mar 01 2011
    Calgary
    Has anyone done an MLED 2.0 in the B5 S4? Might grab a set of euro valeos and give this a go.
  28. #628
    May 10 2018
    MA
    Quote Originally Posted by zipdoa View Post
    If you do the right lense, it will work great. Like it does in anything else. The lense makes the bulb. The bulb is secondary.
  29. #629
    Aug 23 2018
    Columbia South Carolina
    Curious what these look like. Any link u can share ?
  30. #630
    Apr 07 2011
  31. #631
    Oct 26 2011
    CA
    Would these need a special template or housing bracket?
  32. #632
    Junior Member One Ring
    Oct 16 2015
    Norway
    This might be a shot in the dark, but hoping to revive this thread, 'cause I'm doing some work on my RS4.
    I bought a new ballast and from what I could understand from the time of buying it, it should be a replacement for the oem ballast. Don't remember where I read this. (Long time since I bought it, just been lying in my shelf for in wait for a good time to do this.)
    The OEM ballast has a 6-pin, which from my understanding has 2x pins of 12v, and 2x pins of ground. (Brown is ground, right?)
    The new one I got is a 4-pin, which 1x is ground, and 1x is 12v. (Black and yellow wires)
    My question is, can I actually replace my OEM with the new one?
    But I'm not sure if yellow or black is negative.
    Hope someone sees this <3
    I'm sure this might sound like a really noob question, but I'm not too sure about this stuff.
    (For some reason, I'm not able to upload a picture. Damnit)
    EDIT
    Forgot to mention what kind of ballast I bought, since I didn't get up a picture.
    It's a XENUS LAD5GL, with and D2S connector
