Results 1 to 10 of 10
    Senior Member Two Rings jdaudi's Avatar
    Oct 26 2010
    US
    Successful C6 A6 Horsepower mods?
    I'm looking for some rather inexpensive mods to do to the ol' 05 A6 of mine. My friend has a vag com and says the best tuning you can do Audis is usually in the computer.
    I am fairly new to tuning and was turned off when he said he wasn't sure how to program the newer computers (he's into older audi's, etc)
    My two questions:
    1) Are there any fairly inexpensive mods to do to the 05 A6 of mine to get a little more pickup thats been successful for you guys?
    2) Doing computer mods - does that put more strain on everything? I'd like to try to make this car last as long as it can.
    Thank you!
    Veteran Member Four Rings Ynnekdude's Avatar
    Dec 10 2008
    Chicago
    Quote Originally Posted by jdaudi View Post
    My two questions:
    Thank you!
    Do you have the 3.2 or 4.2?
    Unfortunately, neither engine will see any major HP gains without significant investment on your part. I know there are ECU tunes available for both engines but neither are going to produce anything near as significant as they would with a forced induction engine. From what I've read, the tunes offered on the 3.2 and 4.2 A6 are pretty lackluster. However, consider contacting JHM if you have the 4.2. They are known for their prowess with the 4.2 in the B6/B7 S4. I am unsure as to whether they offer anything for the A6, though.
    Also, if you do have the 4.2, an exhaust will definitely make you smile. Won't be much HP gain but the car will sound quite mean.
    There are a lot of cool things you can do with a vag-com but unfortunately they are not related to power.
    2009 A6 3.0T Sedan w/19" Sport Pkg. Phantom Black.
    JHM 93 Stage II. STaSIS Exhaust. SST Intake. JHM HX. Stoptech ST-60. KW V1s. H&R Sways
    Apr 07 2010
    2019 A4, 2018 Subaru Outback
    Southington, CT
    Oct 26 2010
    US
    Quote Originally Posted by Ynnekdude View Post
    Its the 3.2 (unfortunately i guess now haha)
    Dec 10 2008
    Chicago
    Check this out:
    http://unitronic-chipped.com/main/en...fsi_255hp.html
    Really your call as to whether it's worth it. $500 is relatively cheap for a tune but then again, you're not getting much bang for the buck.
    Oct 26 2010
    US
    Check this out:
    Do you have this? Says it gains about 13HP...
    Dec 10 2008
    Chicago
    Nope. I have the 3.0T engine so I'm lucky enough the have the APR stage II tune + pulley.
    Veteran Member Three Rings paul-g's Avatar
    Dec 02 2011
    2013 Ford F150 3.5 EcoBoost 4x4, 2018 Volkswagen Tiguan
    i was looking at this myself as i ahve the 05 3.2 as well. that's expensive HP and not sure if it's worth it. if i have $500 just laying around bored i might just spend it but seeing that i don't not really worth it to me. just got my tax return backa nd that normally when i make a purchase like this but still never appealed to me enough to do it.
    if you do get it let me know how it is!
    2016 Audi A6 3.0 S line, APR Stage 1, Melen TCU Tune
    Jan 10 2007
    VA
    That gain (if proven) is still only a 5% increase in power.
    Do you notice the car being much quicker/slower when you are by yourself vs. with a passenger? That change in power/weight is about 5%.
    The reality is for a power gain to be noticeable it has to be pretty substantial. For a car like an A4/A6 you have to gain around 20-30% to see 0.5-1.0s improvements in acceleration times, which is noticeable and makes the car seem decently quicker.
    Dec 10 2008
    Chicago
    I don't have any experience with the Unitronic tune and my experience with the 3.2 is limited to the Q5. However, note that tunes don't just benefit you in the HP sector. There are all sorts of other changes which improve responsiveness and overall feel of the car. I believe that's 13HP gained to the crank, not wheels, so it will be pretty negligible.
    $500 is relatively cheap for a tune so, if you are willing, I say go for it and let everyone know your thoughts.
