BOV: 2 types
type 1) closed loop system, i.e. recirculates the air back into your intake.
type 2) open loop system, i.e. vents the air back to atmosphere. Yes, the open loop can cause stalling problems, running rich problems, etc.
DV: 1 type
type 1) vents the air back into the intake.
Guess what, type 1 DV = type 1 BOV. there is no difference. A closed loop BOV will work the same in the A4 as a DV.
Some examples:
Closed Loop:
The Greddy Type-S BOV is a closed loop BOV just like the stock BOV with higher flow capacity and much stronger piston spring for no boost leaks.
TurboXS Valve H-34: closed loop.
TurboXS Valve H-25....wait a minute.... holy shit! what's this say from their website??? and I quote: "The Racing Bypass Valve Type 25 was specifically designed to replace the 1 inch (25mm) Bosch Bypass Valve used in most Volkswagen and Audi applications. The Bosch valve is prone to failure in stock application and not adequate for holding boost in "chipped" 1.8T equipped vehicles. The RBV-25 spring tension is adjustable, making it ideal for your modified vehicle."
How can this BE?! A "BOV" that was made for VW applications?! the world is ENDING!
DV's
HX Compact
Forge Valve
Open Loop BOV's - vents to atmosphere.
Blitz SS BOV:
HKS SSQ BOV
Turbo XS RFL
In Conclusion.
As you can see. The Closed Loop BOV is the same exact thing as the DV's some of you people worship.
The Open Loop BOV is different than a DV and yes, can be 'harmful' to your vehicle depending on your specific application.
BOV = DV = Bypass Valve
Feel free to flame away. I really don't care. I'm sure some of you still will refuse to see how BOV's can be the same as a DV just because that's what someone told you.
