Results 1 to 13 of 13
    Veteran Member Four Rings Docwyte's Avatar
    Feb 02 2005
    '03 911 Turbo, '15 Cayenne Diesel
    Wipers won't turn off!
    Headed up the hill this past Thursday to go skiing. Turned the wipers on to clean the windshield and they wouldn't turn off, no matter that the switch was in the off position.
    They'd continue wiping for quite a while, then stop, then randomly starting wiping again on their own.
    Is this a bad switch, or ???
    '15 Porsche Cayenne Diesel ** Wifes DD
    '03 Porsche 911 Turbo 6 MT **
    '18 Land Cruiser ** My DD
    '17 KTM 690 "Adv"
    Veteran Member Four Rings mbgt72's Avatar
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    I'd be willing to bet you've got them on "rain sensing auto mode" and there was probably something frozen up near the sensor that made it think there was still rain. (sensor is behind the rearview mirror against the glass)
    Are you 100% certain you had the wiper stalk all the way down to off, and not just to auto? The "off" is one click below auto.
    Current: 996TT
    Sold but not forgotten: 2005.5 S4 MT6 l JHM Parts: Stg 1 S/C, LTH, IM, SS Trio, LW Front Rotors, LWFW, Stg IV clutch, 4:1 Diff, Stern Motor Mounts, Snub/Trans/Diff Mounts, F.I.Exhaust l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l Fly'sV4 LEDs l 15% Tint, 50% Front l VMR V710 GM 19" & Enkie RPF01's l JL 10W7, Focal Components l V1 Mirror Display l
    Jan 24 2008
    West Coast
    ^ I don't believe the '04's had the rain-sensing as a standard equipment. It may have been an option, but I'm not sure. I know I didn't have it on my '04, though. I also know my 2010 has it, so I'm familiar with how they work. That said, Doc, is it possible you pulled the stock out - and that you need to push it back so that you can control the system? It used to happen on a Toyota pick-up I had.
    Moderator
    Veteran Member Three Rings noznab's Avatar
    Jul 08 2007
    Tri-State
    Rain sensing wipers didn't come standard until 05
    A few mods here and there
    Feb 02 2005
    The stalk controls the wipers just fine as far as turning them on and being able to cycle between the speeds. It's just that with the stalk in the "off" position, the wipers continue to wipe.
    I checked the window sticker on my car and it doesn't list rain sensing wipers as an option.
    '17 KTM 690 "Adv"
    Feb 02 2005
    Anymore thoughts?
    '17 KTM 690 "Adv"
    Veteran Member Three Rings Apat's Avatar
    Jul 04 2011
    B7 S4 , 97 A8, 99 A4 Avant
    Minneapolis, MN
    2005.5 S4 MT - Apikol snub mount // Apikol rear diff mount // Stern tranny mount // JHM Tune // JHM Intake Manifold and Spacers // JHM "Solid" SS // JHM Stage III Clutch and LWFW // Trex DPs // Fast Intentions 2.5" X-Pipe Cat Back w/ 14" Resonators // PSS9 Coilovers // 034 Rear Sway // 40% 3M tint // Lamin-X "tint" headlights and "gunsmoke" taillights // 19" Neuspeed RS10 summers // 18" VMR V710 winters
    Feb 02 2005
    That sure sounds like the problem, thanks! My search skills need some work, I didn't find that thread when I was looking yesterday...
    '17 KTM 690 "Adv"
    Feb 02 2005
    Update! It was the linkage. Replaced it and all is well in the wiper world.
    '17 KTM 690 "Adv"
    Feb 18 2010
    TX
    So, how did the linkage go bad, doc? Mine started doing the exact same thing on the way home from the slopes this week. Please resurect this thread to describe the problem with the linkage, if you can.
    Feb 18 2010
    TX
    So, how did the linkage go bad, doc? Mine started doing the exact same thing on the way home from the slopes this week. Please resurrect this thread to describe the problem with the linkage, if you can.
    Did the linkage replacement include replacing the motor; that it could have just been a problem in the motor vs. the linkage arms?
    Feb 02 2005
    Audi didn't put booties over the splines. So water/salt/etc eventually gets down there and gums them all up. The fix is to replace the linkage, it's not an issue with the motor.
    '17 KTM 690 "Adv"
    Veteran Member Four Rings LJH's Avatar
    Oct 03 2006
    '84 Ur-q, '04 S4 6MT, '08 Outback XT 5MT
    I did not have the none stopping wipers but I did have VERY slow wipers. When I finally switched out the transmission I was shocked how strong that motor is. I could not budge the wiper arms at all.
    Cheers,
    Jim
