Results 1 to 28 of 28
    Senior Member Three Rings Hammie's Avatar
    Jan 02 2010
    Miami, FL
    splitting open new headlights
    I did the joey mod on my factory headlights already but was wondering, would it be more or less of a bitch to split open some Brand New housings vs lights with thousands of miles on them?
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by Hammie View Post
    I don't think there would really be a difference... I do think lights that have been opened tend to be easier to open again... (less time "baking" them with the head gun)
    Jan 02 2010
    Miami, FL
    I agree but I was thinking of headlights that were never opened, not the ones I have now.. IF I dont find some cheap oem xenon housings I'm Leaning towards modding some chrome E-codes. Save me a few bucks from buying S4 lights if I'm going to open them anyway
    Veteran Member Three Rings AutoUnionLov3r's Avatar
    Mar 03 2011
    MK4 Jetta 2.slow-sold, MK4 GTI 1.8t-dead, TT225-sold
    Pittsburgh
    Good point there Hammie. However I think it would ultimately be the same difficulty new or old, just depends on if you want to re-use your already "joey'ed" headlights or not. The ecode route, since ecodes are not OEM, might be a little easier to work with due to, like you said, the "new" housings and also who knows how tight they're sealed, (being not OEM).
    Veteran Member Four Rings Duchenbagen's Avatar
    Feb 29 2004
    ATL/FLL
    Quote Originally Posted by AutoUnionLov3r View Post
    E-codes are OEM headlights. Just not N/A spec.
    John
    USP CLUB MEMBER #5
    How much does the illusion of integrity cost?
    Veteran Member Four Rings Kwarner's Avatar
    Sep 06 2009
    Bay Area
    Quote Originally Posted by Duchenbagen View Post
    This. Only "e-codes" that are not OEM are the Depo ones.
    Dec 18 2011
    Colorado Springs
    I kinda wanna see how other people pulled theres apart...I feel as though mine was way too awkward and time consuming and damaging...I heat gunned every 3-5 inches and had to pry the plastic back like 90*....there has to be a better way..
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Sep 06 2009
    Bay Area
    Quote Originally Posted by B6A4Dave View Post
    My way was oven for 12 minutes at 225, pull apart what I could while it cooled down and repeat. First headlight took around 3 cycles and second took 2 after I was comfortable with the amount of force to use.
    Dec 18 2011
    Colorado Springs
    So you just pulled the clear housing off?
    I wasnt that smart...and feel like mine got fawked
    Sep 06 2009
    Bay Area
    Used a flat head to pry the channel up starting along the bottom and worked my way around. I went from the middle bottom round the side to the middle top which allowed me to just pull them apart.
    Dec 18 2011
    Colorado Springs
    Sounds like what I did with a different heating method....I just felt like I was destroying my headlights :P
    Jan 02 2010
    Miami, FL
    I felt like that too, but it has held together fine with silicone I used to seal it.. So it'll be the heat gun method again for me. The oven way is just too much time waiting,, while my headlight is baking in an oven no less! lol
    USP WHEELS FOR SALE HERE
    Ocean Blue '04 A4 1.8T/ USP/ stock-ish
    Brilliant Black 2014 S8/ sold
    Aug 26 2005
    I pulled apart a damaged housing just to see what it takes. I doubt I could do it on housings I want to use without ruining them.
    Vorsprung durch Technik
    Aug 26 2005
    I used a dremel tool with a diamond cutting wheel around the seam first, then a heat gun to soften the sealant, but it was still difficult and I made a mess of the job anyway. I don't understand how anyone does this without wrecking the housings.
    Dec 18 2011
    Colorado Springs
    Te heatgun method is definitely time consuming, the first one took about 2 hrs, then the second one I flew through in maybe 30 minutes...too scared the first time to F**K mine up hah.
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    Right with you on that one John...
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Sep 06 2009
    Bay Area
    You have to find that sweet spot of the right amount of pressure to use and exactly how far to push in the tool you're using to pry.
    Dec 19 2007
    York, PA
    i did mine and you can hardly tell. you need to put them in the oven for more than 200degrees. more like 275...for 20 minutes and they come apart pretty easy.
    i tried the heat gun as many people said its better...its way worse, dont even try it.
    Dec 19 2007
    York, PA
    Jan 02 2010
    Miami, FL
    Nate just curious what did you start with there? S4 or chrome e-codes?
    and, they came apart after one round of baking at 275?
    Quote Originally Posted by n7plus1 View Post
    Sep 06 2009
    Bay Area
    Even if you can't get them fully apart, just put them back in for a little while again. I agree that the oven is WAY easier than the heat gun method.
    Feb 02 2012
    New York
    yeah,i agree.
    Jan 18 2012
    UK
    Gonna do this really soon now, just bought my b6 and was wondering how hard it would be
    Dec 18 2011
    Colorado Springs
    Quote Originally Posted by Kwarner View Post
    havent tried it on mine...but anything has to be easier than a heat gun
    Aug 26 2005
    I tried the oven method too, the housings started to melt and deformed when I pulled on the parts to seperate, but the sealant did not soften enough to release.
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    I've done this on 3 sets of headlights so far, 1 set not being from an Audi but requiring the same steps. I've used a heat gun on all 3 and found that the key is patience. On the low setting(500*F) I kept going around the headlight for at least 20 min or so before I even attempted to start prying. You have to get the sealant soft all around before the lens will begin to break free. At that point start at one end and heat 4-5 inch sections as you go down and slowly pry. I found it is also easier to break apart the end closer to the high beam first and work towards the turn signal. I have yet to use an oven but I would imagine that keeping it at a temp around 200*F like others have mentioned for 10-15 minutes would be a great way to do the initial softening. Repeat for 3-4 min a few times as you work your way down the break.
    DG '02 A4 1.8TQM
    My Build Thread
    Jan 02 2010
    Miami, FL
    Yea, exactly what I fear.. Melting everything but the sealant lol
    Dec 19 2007
    York, PA
    nothing melted on me at all, shit was hot. i just used silicone hot pads for cooking to grip and pull and to guard myself from teh heat. they didnt come completely apart the first time but they did after the second attempt for a shorter amount of time.
