Results 1 to 29 of 29
    Apr 17 2011
    Indianapolis, IN
    Stick with G12 coolant after flush or alternative?
    I know you shouldn't mix more generic coolants with the G12, but is there an alternative to G12 if you do a complete system flush? PITA to get to the dealers and didn't know if there was a store bought alternative.
    Senior Member Three Rings Aureus1's Avatar
    Feb 06 2010
    06 Mustang GT, 2006 F350 Diesel, 1997 Jeep Grand Cherokee, 2012 Focus SEL Hatch, 1991 MK1 Cabriolet
    TheCommonWealth
    Stick with G12. Its what our cars were designed for and using other types of coolant can cause issues.
    "You love your car as much as you hate it..." - my GF
    GSE www.granitestateeuropean.com
    Team Sad Panda
    Veteran Member Three Rings DaveS4's Avatar
    Apr 12 2009
    Nova Scotia, Canada
    Stick with the OEM G12. I've gotten kits from ECS with their fluid in it, and I just give it to my buddies when they need to do a flush in their cars (guys with older VW's mostly who don't really give a damn. If it's pink, they're happy).
    2001.5 VAST Stage3 **** Silver * 6 Speed
    2001.5 Completely Stock * Imola * Automagical
    Apr 17 2011
    Indianapolis, IN
    $38 a litre at the stealership! wtf...they make this sh*t out of unicorn tears? Guess I'll shop online.
    Veteran Member Four Rings shorterthanrich's Avatar
    May 24 2009
    2000 S4 Nogaro Blue, 1996 Ford Exploder
    Boston
    You do not need to stick to G12. There's no reason to do that.
    Zerex G-05 coolant works fine with our cars. I've been running it in mine for years now, as have many others in the Boston area. I've never had any issues at all with my coolant system.
    Its cheap and available at Napa most of the time, as opposed to expensive, and only at the dealership.
    FREE BEER, click: Pintley - Tap Into Your Tastes!
    My iPhone/Android App
    2000 S4 Nogaro Blue DxC/BritishTurbo Stage GTX
    GTX2863 Build Thread - 575WHP
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    G12+
    1996 A4 - Rolled into the woods
    2001.5 S4 - Stolen
    2001 STG3+ S4 - Sold
    2011 M3 - Blown up
    2017 S3 [11.990 @ 112.38mph] - Current
    Veteran Member Three Rings Taloras's Avatar
    Jan 19 2011
    PDX
    Other kinds of coolant are fine: mixing is the real killer. The original G12 in my car (when I bought it) had been mixed with a LITTLE bit of green stuff at a quick-lube or something, and was a lovely shade of brown with awesome orange and white deposits throughout when I pulled it out.
    Whatever you put in, flush thoroughly with water a few times after the old stuff is drained. I'm currently running Dex-Cool because it's readily available on the road if I ever get stuck somewhere needing coolant, and because it's surprisingly similar to G12: silicate/phosphate free, OAT based. Others may regard this as blasphemy, but I've been running it for a few months without issues, and I'm not the first person to do so either.
    If you wanna play it safe, G12 is just fine (and usually not too expensive from the VW dealer parts department), but plan on carrying some in your car if you have any kind of cooling system problems, 'cos you'll never find any out-and-about.
    Veteran Member Three Rings AudiHolicS4's Avatar
    Apr 16 2008
    Pasadena, MD
    I know a guy who runs green in his jetta but he flushed the system with water a bunch of times then started fresh with zerex green coolant. He hasnt had a problem and ive seen threads on here about switching im sure its not a problem as long as u dont mix
    2000 Silver S4
    May 24 2009
    Boston
    Yes, before you switch you must do a good job flushing.
    Running crazy expensive, dealership only G12 sucks for when you have a leak, and can't find any when you're broken down. Then pay a crazy amount to refill it.
    Sucks for doing any maintenance requiring removal of the front clip, like a timing belt job or stage 3, etc.
    IMO, there's no reason not to switch.
    Aug 13 2008
    Indiana
    My local NAPA store carries Pentosin G12
    -Nic
    Active Member Four Rings martin0079's Avatar
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    Advanced auto carries g12 as well I saw it on the self the other day. Dex cool is just as good as it is made for an aluminum block and thats the only real special part of g12.
    Veteran Member Four Rings BlkdoutS4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Quote Originally Posted by tricky1090 View Post
    Huh? I just paid $22 for a gallon of G12 from my local VW dealership...
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    It's $21-23 a gallon at VW dealerships. Also who says "litre"?
    Veteran Member Three Rings dubzackvr6's Avatar
    Oct 18 2010
    Stage 2 C7 A6, Tahoe for the kiddos
    SLC, UT
    ^ Canadians.
    G12++ is what I put into my cars when I get around to flushing them. Febi, Pentosin, and Rowe are companies that I've used for G12++. All are VAG approved. None are cheap..but do you really want to cheap out on coolant?
    May 01 2010
    Atlanta
    Quote Originally Posted by dubzackvr6 View Post
    ^ Canadians.
    His location was Indiana.
    Dec 05 2009
    New York
    When I bought my car it had the wrong coolant. After I flushed the coolant, my aux pump failed a few weeks later. Coolant is probably the least expensive of an Audi owner's worries.
    Oct 18 2010
    SLC, UT
    Quote Originally Posted by Fourplay View Post
    Apparently, my joke missed its mark.
    May 13 2011
    2015 BMW F30
    Definitely flush well if using alternative.
    | Autospeed | JHM | Pure MS
    Apr 17 2011
    Indianapolis, IN
    Thanks for the replies. I'll go with the Zerex G-05 after flush.
    ...it's the Queen's English.
    Oct 18 2010
    SLC, UT
    Boom.
    Sep 11 2009
    NE
    The cool part about g2 is that is self seals small leaks. Other say that and I had first hand experience when I screwed up on replacing banjo bolt on a turbo. I know I either overtightened one bolt or something cause the seal not to 100% hold as I would occasionally lose a tiny bit of coolant which would amount to visible difference in tank level after few days. After about 4 weeks it all stopped. After inspecting the bolt again, I found visible crustations around the crush seal which indicate that the coolant eventually clogged the leak.
    Others had similar experiences around different parts of cooling system... it is just designed to go beyond green crap from walmart.
    Before everyone cries foul here, it holds for over a year now and the bolt is a complete pita to replace. That's why I have not fixed it yet since it holds just fine. I am pulling engine soon for power upgrades so the problem will be addressed when turbos are swapped.
    Something to think about beyond the price tag. And the coolant can be drained and reused in almost all its entirety when front needs to be pulled.
    May 01 2010
    Atlanta
    Wasn't aware we were still a colony
    Feb 21 2011
    WA
    G12 really isn't that expensive.. look at the price of all of the other fluids that are supposed to be used in these cars and G12 is pretty spot on.
    I can see a leak causing some headache, but what leak do you have that you're not gonna source the problem after having to top up even once? Previous one off example aside, anytime you have a leak you shouldn't really go through more than a fill/top up before the leak is fixed.. that's just no good. I've caught and reused my coolant both times the front clip as been off, no issues, don't see why you wouldn't do that.
    Veteran Member Four Rings mikehawk666's Avatar
    May 17 2010
    Colorado
    napa has concentrated G12 for around ~$20
    '78 F350
    VW T3 tintop
    Mk2 GTi VR6
    E46 Touring
    Jan 09 2011
    Pleasant Gap PA
    GM dexcool is 12 dollars and makes 2 gallons at walmart. Its orange. It mixed nicely with g12 with no issues and you can run it straight. Cheapest and best solution out their for our motor's metallurgy unless you love throwing away hundreds on coolant if yoru car leaks consistently.
    Veteran Member Four Rings Turbo Nerd's Avatar
    May 12 2009
    B5 A4, B5 S4, C5 Allroad, C5 A6
    Detroit Metro Area
    I get that pink shit for free.
    G12 and the other pink stuff
    Established Member Two Rings Yuckie's Avatar
    Jan 13 2010
    '02 S4, '11 Ninja
    San Diego, CA
    Hey guys premium unleaded is too expensive, can I run water instead? Preferably hose water from my neighbors house, I'm on a budget.
    Seriously though, if the cost of G12 is such a big deal then find another mode of transportation.
    Aug 13 2008
    Indiana
    Quote Originally Posted by sweets4style View Post
    This is just a bad idea....
    -Nic
    Jan 19 2011
    PDX
    Quote Originally Posted by Yuckie View Post
    Our engines are made of iron, aluminum, and a host of other alloys and synthetics, not myrrh and fairy dust. While one shouldn't go for the cheapest option for everything, opting to save a bit on a still-effective coolant that's been used successfully by other Audi/VW owners and that also has widespread availability is perfectly reasonable. Just don't be dumb about it (like mixing coolants and causing the disparate corrosion inhibitors and additive packages to combine in to a lovely radiator-clogging sludge) and it'll be fine.
    May 24 2009
    Boston
    If everyone used your mindset for the S4 it would still cost $8,000 for K04s, tuning, and fueling.
    Being smart about finding lower cost, high quality alternatives is good for the platform.
    As Taloras said, our engine's aren't mystical things that require completely unique fluids, nuts, and bolts to hold together.
