Results 1 to 8 of 8
    Jan 18 2012
    Bozeman
    Dirty/corroded Coil Pack
    I was replacing the spark plugs on my '07 3.2 and I noticed that almost all of my coil packs had corrosion on the metal tube. Everything seems to run just fine. Is this typical or does it indicate a bigger problem? Thanks!
    Mar 21 2011
    magimmeMVE
    Usa
    Any pics? My 04' S4 CP's have no corrosion and look good as new.
    Jan 18 2012
    Bozeman
    no pics unfortunately. I did the work last night and wiped the coil packs off. Didn't think about posting it on here till today.
    Oct 02 2006
    Wadsworth,OH
    Corrosion like rust?
    As long as the car is functioning properly I would imagine they should be OK.
    Do you have engine covers on and or a belly pan? These items help reduce the amount of moisture that gets in to places where corrosion can start.
    Jason
    Jan 18 2012
    Bozeman
    Jason - Not quite rust. Looks more like the corrosion on a battery terminal.
    Jan 18 2012
    Bozeman
    And the 3.2 doesn't really have an engine cover over that area. but the belly pan is there.
    Oct 02 2006
    Wadsworth,OH
    Interesting, I've never personally heard of coils developing that type of corrosion - but I can't say it isn't possible due to the fact that electricity does pass through them.
    Clean them up and add some dialectic grease to the ends of the coils and call it a day. As long as your car isn't missing I wouldn't replace anything yet.
    Jason
    Jan 18 2012
    Bozeman
    Will do, Thanks Jason!
