Good God, I just went through this and was about to post a faux-DIY when I (thankfully) did a search and found this existing thread. Phil, is there anything you haven't DIY'd? :)
You don't need the key. Per the Bentley manual (and per my experience from a couple of hours ago) ... a) remove the 10mm nuts (attached to bell-shaped covers), b) loosen the two 10mm nuts that hold down the metal covers to the license plate light housings, c) remove the 10mm (?) bolt that is holding the lock cylinder in place, d) then detach the "bowden" cable that links the lock cylinder to the latch (the rubber thing slides out and then the metal end to the cable pops straight out; you can disconnect both sides if necessary), e) disconnect any power connector in that assembly, f) rotate the lock cylinder 90 degrees (sorry, can't remember which direction, it will only go one way, I think clockwise from your perspective), and finally g) then reach inside the deck lid and there are two "catches" right between each license plate light housing and the nuts with the bell-shaped covers ... pressing in those catches with your fingers will pop the trim (aka "molding", 8E0827574C3FZ, ECS#438239). Guess what??? The flippin' license plate backing is in the flippin' way! (at least it was for me) So now you may have to remove the two T25-ish torx screws that hold it onto the trunk. It also has double-sided sticky tape (3 flippin' rows of it) that you'll just have to pry off with a flathead or trim tool. Yes. Flippin'.
I used a 1/4" drive ratchet with a 10mm socket to reach all those nuts. When reinstalling, tighten anything from nuts to bolts that you removed to 8 Nm/71 in-lb. They're all the same, apparently.
So a stripped (by someone else) screw just ended up costing me roughly $250-300 dollars for a new molding and two license plate light covers. Well, that and the fact that the inside of one of the light housings has some funky rust and burn marks probably caused by shorts which were probably caused by water ingress. Hmm, let's hope that doesn't happen to the new one.
Please PM me if you get stuck so that I'm notified sooner.
UPDATE: If anyone reads this, you may notice in a subsequent posting I ended up finding out you only need the molding, not the left/right clear plastic light covers. The molding already comes with the clear plastic covers, the screws to keep them in, and even light bulbs, pre-installed.
