Results 1 to 40 of 40
    Veteran Member Four Rings 617 Bones's Avatar
    Wife's - MK3 GTI VR6 Vortech S/C
    Boston
    Difference in B7A4 model year: 2005.5-2006 & 2007-2008
    Searching for a B7 and wondering what's the difference in the model years 2005.5-2006 & 2007-2008? Specifically, I see that APR has a K04 kit available, but only for the 05.5-06 B7A4's... Why?
    B7 A4 Avant 2.0T 6MT - Arctic | H&R + B5 Perches | JHM S/S + 4:1 Center Diff | Apikol Snub + Rear Diff Mount | Hawk HPS | Tyrolsport Caliper Kit | AWE Exhaust | 034 RSB + Spherical End Links | 19" VMR v710
    Veteran Member Four Rings yungcotter's Avatar
    Jun 09 2010
    Queens
    Im pretty sure it is available but they havent updated their site for it. But as far as differences there are some minor changes to the engine and some other updated electronics Ie radio .
    -Theo
    2018 S4,Florett Silver, Magma
    2014 Q5, Phantom Black Pearl, Chestnut, 2.0T,Moms Ride
    2015 S4, Daytona Gray, DSG,Gone
    06 A4 2.0 T, Quartz Gray, Quattro, Tiptronic.
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    Almost every 2008 is a fake s-line.
    And if i remember correctly the diverter valve is fixed on the newer yeared ones? late 07 and 08?
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    http://www.audiworld.com/model/
    This can help with differences between option packages for each year for US models as well.
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Active Member Two Rings njschwinn's Avatar
    Dec 11 2011
    Custom Dirt Bike
    North Fond du lac, WI
    Quote Originally Posted by Solarsuplex View Post
    Hey! Its called "Special Edition"! I kind of like my cars mis-matchedness. Its like a built in body kit so +10 hp?
    2008 b7 A4 2.0T quattro 6MT "Special Edition"
    APR Stage II
    APR Intake
    APR Testpipe
    BFI Snub Mount
    Veteran Member Three Rings saizero's Avatar
    Aug 11 2009
    Chicago
    To answer the original question, we have different engine versions 5.5-06 have engine code BGP, while later models 07 and later are BWT (in N. American anyways). Others versions were only available in the European markets like the BUL which was the engine offered on the 05 A4 DTM. there is a post, somewhere here, that list the specific differences between the engines (ECU map, compression ratios, etc) I think there are 7 different engine variations total. If you want to know more practice your google-foo.
    -Simon
    Current AWE Boost Gauge : STaSIS catback : 034 HFC : ECS Snub Mount : Upgraded Piston DV : CTS Turbo Catch Can : ER FMIC : DTM Front/Rear Votex Side Skirts : Stasis/Ohlins SL Coilovers
    VAGCOM Owner
    AKA: vmSAi
    Jun 09 2010
    Queens
    Here i was bored so i went and found it. All of the different engine codes for the b7.
    Which 2.0T FSI Engine do you have
    -Theo
    Boston
    Very awesome!! Thank you guys for posting this info! I swear I searched different combos of the years, but not engine code!
    Also, in case anyone else has this similar question in regards to the APR K04 setup I got this response from APR:
    Unfortunately it has to do with the ECU programming required to go along
    with the K04 upgrade, not the turbo kit itself. Hopefully we will be
    able to offer this mod sometime in the future for you!
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    05.5s, oddly enough, have seemed to have less problems overall. You get a color display! But you have a smaller fuel rail valve.
    You also get a slightly softer cam, but the hpfp has very few problems. There are also 05.5 models with heated rear seats.
    JR
    2021 Audi S4, P34 Intake
    Aug 18 2009
    A Unicorn
    Portland, OR
    Except for those with a real s-line
    JR
    Most of that could be said of the 2006's too. (mine had color DIS, memory seats & mirror tilt, etc). I believe any year can have heated rear seats if you have the cold weather package - but too lazy to look it up and confirm
    :: Seller feedback ::
    RIP: 2006 DG Avant Tip
    Jun 09 2010
    Queens
    My 06 Has Nothing
    -Theo
    Jun 27 2011
    My 06 has heated rears, bose, 3-spoke MFSW, but no DIS features (just the DTE readout), non-sport, y-spoke 17"s, and that's pretty much it. I don't think I even have a ski passthrouhg. I'm pretty sure heated rear could also be added as a standalone option, in addition to the Cold Weather package, but I dont know for certain.
    Also why does everyone call it a FAKE S-Line. Its basically the normal package from 08 on. The S-Line guys have plenty of things to be fortunate for, they don't need to get so butthurt about them facelifting the frontend! Cripes!
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Quote Originally Posted by 617 Bones View Post
    Not sure whom you contacted, but I have an 07 with that APR file, as does at least one other member with an 07.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    my 2008 DV was rev G with the diaphram. I thought mine was the piston but I was surprised to see the rubber diaphram. Simple enough fix at the expense of plenty blind reaching and cut up hands/arms to get to it...
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    Oct 14 2009
    Okinawa Japan
    Awesome this may explain the differences in pistons that I noticed between Jeff's (vizi) 2005.5 B7 and the OEMplus B7
    Jeff's 2005.5 B7 piston
    OEMplus.coms OE piston
    Feb 25 2011
    Seacoast NH
    Quote Originally Posted by charles.waite View Post
    also why does everyone call it a fake s-line. Its basically the normal package from 08 on. The s-line guys have plenty of things to be fortunate for, they don't need to get so butthurt about them facelifting the frontend! Cripes!
    YOU ARE MY HERO, CHARLES.WAITE!!!
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Hey.....watch with the fake shyte comments....my S-Line is real, except for the chrome pedals and door sills, I guess you can call it half-ass S-Lines. As for the Diverter Valve, nope, I recently replaced mine and it was a 'C', no tears or cracks though, not yet but decided to upgrade to the 'D' version to save some headaches down the line.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Oct 14 2009
    Okinawa Japan
    I almost forget about silly issues with DVs and PCV lol
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Oct 14 2009
    Okinawa Japan
    Some noticable differences between the engines:
    - BPG (US Spec) 280Nm at 2000rpm / compression ratio of 10.5
    - BWT (07 US) 280Nm at 1800rpm / compression ratio of 10.5
    - BWE 280Nm at 1800rpm / compression ratio of 10.3
    - BUL (DTM engine) 300Nm at 2200rpm and has an output of 162KW. Also has the same compression ratio as the BWE of 10.3
    You can find what engine you have on the sticker on the timing belt cover.
    I'm assuming that the BWE engine uses the Vizi style piston, where the BWT uses the Dome flat top style piston found in the OEMplus.com B7?!
    -Shane Drake-
    >DRAKLOREs Build<
    Veteran Member Four Rings flyingfish2626's Avatar
    Nov 23 2008
    2008 GMC Sierra 1500
    Colorado
    Quote Originally Posted by rongeur View Post
    Same here.
    2016 S3 Black Optics/LED/technology package/EQT stage 1 ECU/TCU
    2008 A4 Avant APR stage II / 6-speed.....Sold
    2001.5 S4 Avant/Pearl/Oynx/Tial 605/6-speed......Sold
    2015 VW GTI PP/LP/APR/6-speed....Sold
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by DRAKLORE View Post
    I am an 05.5 and I have the bpg engine. What that means? I have no idea.
    JR
    Jun 27 2011
    Quote Originally Posted by wildcat333 View Post
    I do what I can!
    I've got a totally non sport 2006 avant so I'm jealous of all you SE/S-Line guys!
    -CP
    2017 Q7 3.0t
    Junior Member Two Rings
    Nov 20 2010
    Sabb 97X 5.3
    Portland, OR
    I have an early 2005.5 3.2. It is loaded. Color screen, heated front and rear seats, driver and passenger power seats, power folding and auto turn-down outside mirrors, auto dimming internal and external mirrors, compass, rear heated seats, 3-spoke MFSW, ski tube, adaptive xenons, sport suspension and 5-spoke 18" alloys.
    I got really lucky as I really just walked into a Toyota last December having seen the car on the web and it turned out to be an absolutely pristine car with 38 k miles for $17,500 with a 3-year extended warranty. It was a heck of a deal. I knew nothing about options or packages, only that I wanted the V6 - hey I was coming out of a 4.2L V8 Jaguar XJ8....
    - Tim
    Jun 09 2010
    Queens
    Quote Originally Posted by timfountain View Post
    - Tim
    I slightly hate you lol
    -Theo
    Jun 30 2009
    Washington DC
    - Tim
    Wait a min. Is this the one with the parktronic, woodtrim/leather steering wheel, RNS-E and automated side shades?
    I saw a 06 3.2 that was really fully loaded with your amount of miles on autotrader.
    Parktronic seems to be the very rare items within the B7
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    Quote Originally Posted by yungcotter View Post
    - Tim
    I don't (think) I have the sport suspension or the 18" wheels (glad for that) but otherwise my 05.5 is Black on black with all the same goodies. Mine had 105,000 miles on it, but I got it for $8200 cash. It was missing the glovebox door but I scored a complete black glovebox for $140, then just to be safe I did coils, plugs, BSH PCV fix, DV, N80 & N75. Still have no idea what engine code but it's not even 5AM and 17* out, so I'm not going to check just yet.
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    Nov 20 2010
    Sabb 97X 5.3
    Portland, OR
    Quote Originally Posted by pkny View Post
    This was December last year at the Maund Toyota used car lot on 183 in Austin TX. I think one reason for the low price is that no one wants an AWD car in the south and it was priced down because of that. Oh and also because it had a very ugly Yakima bike rack bolted to the top of it in all the dealer photos. They were asking over $20K for it and I got them down to $17.5K with the 3-year gold start warranty through Toyota.
    I came in between Christmas and new year - basically the end of their quarter and their year and waved a cash offer at them. They were hungry to make their sales targets.. The Yakima came straight off and went on CL the next day, fetching my $180. Oh an no, unfortunately, it doesn't have parktronic - as you say there are rarer than rocking horse sh1t! I am still trying to find the right backup camera to hook up to the Dynavin but so far everything I have seen doesn't look OEM enough....
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    I have a BPG engine in mine...Lol
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Boston
    Weird... I sent APR an email and Steve Graupner from APR responded with what I quoted above.
    I was specifically asking about the APR S3 K04 kit for the B7A4 2.0T.
    Aug 18 2009
    A Unicorn
    Portland, OR
    I could be wrong, but I'm pretty sure no B7 came with automated side shades. The side shades are manual (mine are at least), and the rear is automated.
    Veteran Member Four Rings fordyoz's Avatar
    Apr 20 2011
    Philadelphia
    my 05.5 came with color display, rns-e, cold weather package (heated front and rear seats + ski sack), adaptive bi-xenon, power everything, etc etc. only thing i wish it had was s-line titanium :(
    will update later with engine type
    Borg Warner EFR6758 B7 A4
    Jun 27 2011
    My 06 is also a BPG. And has halogens.... they blow...
    -CP
    2017 Q7 3.0t
    Established Member Two Rings B7Quattro Pete's Avatar
    Oct 19 2007
    '20 Audi Q8 55 Prestige
    Hunt Valley, MD
    JR
    What? Everyone doesn't have heated rear seats? ;-) I also have the auto lowering right mirror when reversing...but that's off the engine topic..
    Oct 19 2007
    Hunt Valley, MD
    - Tim
    Nice...I have engine envy.... but I have the navi! Strangely, haven't seen a lot of 3.2's with nav? :-p
    Nov 20 2010
    Sabb 97X 5.3
    Portland, OR
    Touche, but.... I have navi in the form of a Dynavin, which I am very happy with. I have never used an RNS-E so can't compare but the Dynavin does everything I want. I have a 32GB USB memory stick for memory, iPhone connector, Nav, Bluetooth, DVD on the move, MP3 DVD playback and it looks like it has always been there. I think the Navi is a rare beast on any A4.
    Feb 25 2011
    Seacoast NH
    Quote Originally Posted by B7Quattro Pete View Post
    NO! Rear heated seats and memory seats/with right lowering auto mirror does not exist in 2008 model years. Oh well :(
    Veteran Member Three Rings Homer's Avatar
    Jan 27 2010
    2006 A4 6MT Quattro, 1990 Volvo 240 Turbo
    Bay Area
    Heh, I got lucky with my 06 2.0T.
    Color screen
    Heated front seats
    driver (memory) and passenger power seats
    3-spoke MFSW
    adaptive xenons
    Nav
    Bluetooth
    Parktronic
    6 speed manual
    38k on the clock in the summer of 2010, CPO audi care and all for $19k
    -Jacob
    1990 Volvo 240 Turbo-Project Car
    2017 Audi allroad prestige
    Junior Member One Ring
    Jun 02 2019
    Will the oilpan from a 2006 work for a 2008 a4 3.2 we have different oilpans
    Mar 04 2019
    Staten Island, NY
    My 3.2 has the Navi. Bose system with cd changer, cold package, heated power seats, sport suspension, Xeon headlights, fold in mirrors , power moonroof and ski pass through and the original first aid kit too.
    133k miles and still running well.
    You a bounty hunter...Man's got to do something for a living these days......Dying aint much of a livin boy....
    Feb 15 2016
    Cambridge,Ontario
    This thread is almost 10 years old.lol.
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
