Results 1 to 23 of 23
    Mar 27 2011
    Brooklyn NY
    2008 Audi A6 Brake Pads.
    Hey Guys, I have a 08 Audi A6 and today the brake pads light came on ... I have never changed the brake pads since I got the vehicle. Can you recommend any decent brake pads that are similar quality to the OEM ones... I'm not looking to spend a fortune but at the same time I want to be able to stop the vehicle without hurting anyone!
    Also after changing the brake pads, does the light go away automatically or does it require resetting via VAGCOM?
    Thanks
    FC
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    OEM or go with Akebono pads for less dust with about the same initial bite/feel of OEM. Not sure about the light, I know it goes out on my wife's BMW after changing pads with new sensors.
    I think there is a DIY on Audiworld.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Veteran Member Four Rings JPJ2007's Avatar
    Apr 15 2009
    Middle TN
    If you're doing the fronts you don't need vagcom to retract the calipers. But On the rears you will. Or atleast on mine I did. My rear are those Magnetic ones so the dealer computer was the only one that could retract em.
    I wouldnt go with oem... I just upgraded to HAWK HPS and their 1000x better than OEM. then again, I like being able to brake fast, I also tracked mine
    2006 A6 3.2L Quattro S-Line (got my baby back)
    Mar 27 2011
    Brooklyn NY
    Where did you buy the brake pads? Also how much did you pay for them?
    I am planning to replace front and rear brake pads. I really don't want to go to the dealer!!! I HATE the Dealer.
    Quote Originally Posted by JPJ2007 View Post
    Apr 15 2009
    Middle TN
    Ebay, I bought HAWK HPS Pads, rears for $50 shipped.
    I havnt done the front because their just not ready. Though I can't wait to do it.
    I also bought Slotted rotors for the rear when I did the pads. I'll buy slotted rotors for the front too when I upgrade the pads.
    Well, I was lucky enuf to have a friend who works at a VW dealer as a mechanic and brought the computer home.
    you'll need vagcom to retract the rear calipers.
    Oct 02 2006
    Wadsworth,OH
    We have HAWK HPS pads available below!
    Click HERE to order or for more information.
    Jason
    Apr 15 2009
    Middle TN
    Thats actually a good price. I'll remember that when I do my fronts.
    Can I ask why you don't carry the HPS in Rears????
    Oct 02 2006
    Wadsworth,OH
    We do have them available they just were not applicated to the A6
    Click HERE
    Jason
    Apr 15 2009
    Middle TN
    Ah, Thanks.
    Side Note: Liked the install video. No different than anything else on speed, 4x4 etc... Should start a show :P
    Oct 02 2006
    Wadsworth,OH
    Ah, Thanks.
    Thanks! Check out our youtube channel in my signature there's TONS of other cool videos!!
    Jason
    Mar 29 2011
    Long Island NY
    Where in Brooklyn do you live? I live in Franklin Square (exit 15 ss pkwy). I have vag-com and can assist. New pads in front will turn off brake light immediately. Rear pads are different story. You MUST have vag-com to retract piston on parking brake.
    Bob
    Mar 27 2011
    Brooklyn NY
    I bought the front and rear Hawk HPS for $135. Sounds reasonable, right?
    Veteran Member Three Rings Unleaded20T's Avatar
    Mar 27 2008
    Ducati Streetfighter V4S
    Allen, TX
    Quote Originally Posted by bob audi View Post
    Bob
    do you have the steps to retract with the rear caliper with Vagcom?
    Also, does anybody know which brake rotor size comes standard with the sline? I see two sizes for the brake pads.
    [Current] 22' S6 | Daytona Gray | BO | Prestige
    [Sold] 21' S5 SB | Glacier White | BO | Prestige
    [Sold] 19' SQ5 | Ibis White | Prestige
    [Sold] 2016 A6 | Moonlight Blue | 3.0T P+
    [Sold] 2011 A6 | Black | Prestige
    "If everything seems to be under control, you are not going fast enough." - M.A.
    Veteran Member Three Rings 4Chio's Avatar
    Mar 14 2005
    STL
    I have these on mine and love them!!!
    Jason
    2018 S6 Prestige ,sport, JB4
    2014 991 Cab C4S
    2018 S4 Prestige
    2017 Q7 Prestige
    (sold)
    2016 S3 Monsoon Gray Prestige | Sport seats| 19's W/ mag ride| Milltek Res valve
    2013 X5 M, 08 A6 4.2 Sline, 08 :.R32 ,07 S4 White/Black, 04 S4 6MT,
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by Unleaded20T View Post
    I don't believe it is based on trim level, but more on engine size. The 4.2 and the 3.0t run the larger rotors (347mm front ans 330 rear).
    '09 C6.5 A6
    Mar 27 2008
    Allen, TX
    That kind makes sense, you will go far my dear friend SinCity. :)
    by the way, do you know how to retract rear calipers?
    Veteran Member Four Rings Ynnekdude's Avatar
    Dec 10 2008
    Chicago
    You will need a vag-com to do so. People have done it without one but I HIGHLY suggest borrowing a vag-com or purchasing your own.
    Here's the instructions:
    Open Rear Parking Brake
    Prerequisites:
    Connect a battery charger as per repair manual. See Special Notes
    Cycle the Parking Brake ON, then OFF first.
    [Select]
    [53 - Parking Brake]
    [Basic Settings - 04]
    Group 007
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    The brake calipers will then open, allowing the pads to be changed.
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    Turn ignition off.
    It is normal for the LED in the parking brake switch and the warning lamp in the instrument cluster to blink rapidly at this point.
    The caliper pistons do not move back into the caliper, this is normal.
    Close Rear Parking Brake
    Prerequisites:
    [Select]
    Group 006
    [Go!]
    [ON/OFF/Next]
    The brake calipers will then close.
    [Done, Go Back]
    The LED in the parking brake switch and the warning lamp in the instrument cluster will probably continue to blink rapidly. This should stop after cycling the Parking Brake ON, then OFF again.
    Function Test
    Prerequisites:
    [Select]
    Group 010
    [Go!]
    [ON/OFF/Next]
    The brake pads are now opening and closing 3 times.
    Wait 30 seconds after the the brakes stop making noise.
    [Done, Go Back]
    2009 A6 3.0T Sedan w/19" Sport Pkg. Phantom Black.
    JHM 93 Stage II. STaSIS Exhaust. SST Intake. JHM HX. Stoptech ST-60. KW V1s. H&R Sways
    Jul 11 2012
    MN
    Quote Originally Posted by fchodri View Post
    Thanks
    FC
    Hello, found your topic on google. I'm in need of a replacement brake pads and found those, which look really OK and I was thinking of getting them cheaper from poland (These are alcon brake pads) but is it a good solution? Shipping from eu would probably take a while, so...
    Mar 27 2008
    Allen, TX
    Quote Originally Posted by Ynnekdude View Post
    Thank you very much for the info. I found a similar info on Ross tech but its missing some of the steps you gave me.
    I jordered the Akebonos front and rears from ECS and I should be replacing the pads this weekend.
    Veteran Member Three Rings Audiboy's Avatar
    May 14 2004
    Audis and stuff
    Fremont, CA
    I have Hawk HPS on my A4.
    But been happier with the EBC reds all around on our A6. A lot less dust but better bite than the HPS. Previous to HPS, I had Axxis Ultimates which were a notch behind HP+. Those were dusty but bite hard. HP+ are even more dusty and tend to squeal.
    In any case, I hear good reviews with the Akebono's. I'm sure they will bite like stock but have less dust.
    Sep 28 2016
    i used my milwaukee 12v battery from my m12 drills, unplugged the caliper motor and jumped it via some wire jigging,i left them retracted and ofcourse parking brake lights and warnings went crazy but all i did was apply the electric parking brake and then remove the parking brake and they went back to normal and warnings came off. Ofcourse figuring out which way is retract and which way applies the caliper piston is the hard part. Right back atcha audi. Aint getting me with that vagcom stuff for maintenance lol
    Apr 15 2009
    Middle TN
    Did you just revive a 5 yr old thread?
    lol
    Just FYI guys, you no longer need vagcom for the rear brake release. There's an app for your phone now that will do it over bluetooth to a OBD2 tongle. Really awesome!
    It's called Carista, I love it and all the extra features it offers.
    http://www.caristaapp.com/
    Obviously im as super active member, so im not spamming this product or anything. I paid for it, and it was worth it. It even read modules and stuff in my car that were having issues.
    Jun 19 2017
    Crystal Lake, IL
    I just replaced the rotors and pads on the A6 and did a similar thing with the rear as BKZC6 did. But I bet this tool is a hell of a lot easier.
    Seems pretty inexpensive too for all that cool diagnostic capability as well as the cool custom set ups it looks like you can put together. I think I will grab me one of these soon.
    Thanks for sending that out JPJ. BTW I absolutely love the color of your car. Love my IBIS white, but if there was one of them red ones available......
