Results 1 to 9 of 9
    Veteran Member Three Rings DaveS4's Avatar
    Apr 12 2009
    Nova Scotia, Canada
    RNS-D Install Question
    Putting an RNS-D in my car and have a quick question... I have the harness from the unit I bought online, there are a couple of small gauge wires that need to be hooked up to my car. Does anyone have any wiring diagrams for the install? The site that used to have them is down :(
    2001.5 VAST Stage3 **** Silver * 6 Speed
    2001.5 Completely Stock * Imola * Automagical
    Jan 29 2007
    08 S4 00 S4
    MD
    Post a picture or two of the harness. It's usually plug and play.
    08 S4- Stock SOLD
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    pm me i have tons installation instructions .
    Veteran Member Four Rings 00SantorinS4's Avatar
    Oct 02 2006
    So. Maine
    My Install was just about plug and play. Just need to run the SAFE wire or jump the pin on the back of the unit so it can be unlocked. Of course no info on the DIS without the CAN gateway. Plug the antenna in and good to go.
    I didn't use any type of harness.
    hacker, have any OEM C-Navi discs? Particularly #7 for New England. OEM Discs on eBay are like $80 for an older C-Navi unit...
    I reflashed the firmware on it and now I'm stuck with the German language until I throw an OEM nav disc in and change the language!
    2017 Audi S3//Navarra Blue//Black Optic//SuperSports//Tech//Dynamic//B&O//Injen Evo CAI//CTS Inlet//APR Coils
    Jul 23 2007
    i have only D-Navi 2003 and 2001 version cd's.
    u can change language from menu :
    The unit will likely come up in German, to switch it to English...
    Press the mode key.
    From the menu, use the right hand knob and select the last item "Einstellungen" (settings) by pressing the knob.
    Another menu will appear.
    Pick the first item, "Sprache whlen" (select language) and press the right hand knob.
    In the menu that appears, you will have several languages to choose from, "Englisch (Imperial)" (English in miles) and "Englisch (Metrisch)" (English in kilometers) are the logical ones.
    Pick the appropriate language and press enter.
    Your Nav Plus will now be in English (or the language you chose).
    Jan 29 2007
    08 S4 00 S4
    MD
    You can change back to English from the settings menu. Hit the "Mode" button-then "Settings"- "Select Language" is the first option in the next display.
    08 S4- Stock SOLD
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    Quote Originally Posted by 00SantorinS4 View Post
    I can burn it for you.
    1996 A4 - Rolled into the woods
    2001.5 S4 - Stolen
    2001 STG3+ S4 - Sold
    2011 M3 - Blown up
    2017 S3 [11.990 @ 112.38mph] - Current
    Oct 02 2006
    So. Maine
    Thanks for the above replies gentleman. Here's the problem, to change the language (at least on my unit) you must have a nav disc in because the menu "Sprache whlen" is completely grey'd out and does not allow me to select it.
    My unit came in English and after I did the firmware update (unaware the language was going to switch to German) it's perma German now.. lol. Disco, I had someone from the forums burn me a disc a send it however, it did not read in the unit. I heard that if you do a firmware update it will not read burned discs unless you insert and OEM disc 1 time before using any burned ones. It could have also been the incorrect nav disc for my unit but this guy said he was positive it was for a C-Navi unit.. So I'm open to any helpful insight. If you wouldn't mind burning me one and sending it my way I can paypal for the labor and postage just let me know. PM me and I can shoot you an addy.
    Feb 12 2013
    Australia/New South Wales/2440
    Selling RNS-D
    I'm currently selling my Navi Plus RNS-D, if anybody's interested, I have a question though, does anybody know if it will install in a 2002 a8L?
    Pm if anybody's interested in the RNS-D - I'll post anywhere but I'm looking for around $560 or male an offer? :) comes with code and everything, in perfect condition
