Results 1 to 14 of 14
    Established Member Two Rings mishonio's Avatar
    Nov 10 2011
    Audi A4 6MT, VW jetta GLX
    san fran
    225/50/17 vs 225/45/17 winter tires
    The 17" audi B8 wheels which I just bought from an Audizine member to use during the winter are meant for tire size 225/50/17.
    To fit my spiker spider chains though, I was thinking of going with a slightly lower tire: 225/45/17.
    Will there be issues if I go with 225/45/17 instead of what Audi puts on these wheels which is 225/50/17?
    Thanks,
    Michael
    Sep 16 2010
    Central Wash
    No, that's hardly a difference- and you're not even changing the OEM width, just the aspect (sidewall) by 5%, which for a 225 is...roughly 5mm in diameter. As long as all the tires are the same size, no problem.
    Nov 10 2011
    san fran
    Thanks Rollerton.
    So there should be no issues with the indirect TPMs or other systems...
    Senior Member Three Rings neptunesfinest's Avatar
    Jun 03 2010
    New Jersey
    Might have a slight effect on the speedo and odo due to the smaller diameter.
    Mar 05 2009
    Earth
    I've never used chains (not legal here in Ontario) but I would assume the chains would add extra rolling diameter to the wheel to offset any difference caused by the lower profile tire.
    Senior Member Three Rings dame drizzo's Avatar
    Sep 15 2009
    1995 Audi URS6
    Quote Originally Posted by cory_can View Post
    Why is it illegal? They have ones don't damage the road. Seen them on ecs tuning...
    Current- 2013 Volcano Red Metallic B8 2.0 -Frankenturbo F23L, RAI Custom HUGE FMIC, RAI MS Full Turbo Back Exhaust, Hotchkis F&R Sway Bars
    Past - 2010 Audi A4 2.0 EFR 6258 Stage 3 (Total Loss/ Hurricane Sandy)
    2009 Audi A4 2.0 Stage 2 (Total Loss)
    VCDS RossTech NYC Area
    FIRST AUDI B8 WITH EFR - 330whp @ 22psi 93oct
    instagram.com/damedrizzo
    Xclusive Auto Leasing - Sales & Marketing Manager
    [email protected]
    Veteran Member Four Rings DeMOROlized's Avatar
    Sep 18 2006
    GTA Canada
    Quote Originally Posted by dame drizzo View Post
    Uh, they are illegal because the local law says so.
    1st Ring: 2002 Dolphin Grey B6 A4 1.8TqMS
    2nd Ring: 2006
    Moro Blue B7 A4 2.0TqMS
    3rd Ring: 2010 Phantom Black B8 A5 2.0TqM S Line
    4th Ring: TBD
    Oct 13 2006
    Dogville
    I would only put the 225/50-17, a specified size. The 225/45-17 size is simply wrong and not that close. It also won't match the spare should you need it.
    Nov 10 2011
    san fran
    Quote Originally Posted by equ View Post
    Good point.
    My car though has the 4 spoke factory 18" wheels with the Pirelli P6 245/40/18. I guess the spare is designed to match this tire size.
    I am now buying a winter setup (17" wheels+tires). Already bought the 17" original Audi wheels. For the tires, regardless of whether I go with 225/45/17 or the Audi default, slighly taller 225/50/17, the spare perhaps will not match anyway.
    Am I missing anything? Why using a slightly lower tire will be wrong?
    Oct 13 2006
    Dogville
    Both 245/40-18 and 225/50-17 are factory sizes. They are very close to each other and the spare will work with both. I assume all a4's are shipped with the same spare and some cars come with 17's and some with 18's. I run 245/40-18 in the summer and 225/50-17 in the winter. The other allowed sizes are 245/45-17 and 255/35-19. Aren't four sizes enough choice? Do not stray.
    Mar 05 2009
    Earth
    There are plenty of sizes that are well within specs. Just 2 examples....my winters are 225/45/18 which is fine....245/35/19 is also common and perfectly fine.
    Nov 10 2011
    san fran
    Thank you all for the responses.
    Veteran Member Three Rings brainpan's Avatar
    Apr 11 2010
    sk8 banana
    ontario
    theyve been banned since the 70s , they basically said that the damage they cause compromise the road safety and that they didnt offer any big safety advantages that out way the damage cause to the road
    110$ ticket, plus theyd probly tow the car until the studs are removed, pretty sure ontario is the only place that they are banned in canada, well theyre actually legal in northern ontario... if that makes any sence
    Bryan
    Oct 13 2006
    Dogville
    Agreed that those two sizes also work. But really the choice is not infinite and if OP is questioning whether 225/45-17 is acceptable, I don't want to give the impression that "lots of sizes work". I personally don't go with diameter even but revs per mile (listed in specs in tirerack.com). So e..g. 245/40-18 is 805 revs per mile and 225/50-17 is about 803 (and then there is variation by manufacturer and of course tread wears out). I'd personally stay in the 800-810 range on this car.
