All doable, however...
The cost to obtain the motors, ecu, parts, ect plus the labor is going to exceed the cost of simply upgrading the car to a 3.2 A4 or a B7 S4. I'd almost be confident that it'd be cheaper to upgrade to an RS4 as well, rather than sourcing an RS4 V8 and putting it in your A4. Plus, if you upgrade cars you not only get the powertrain, but other options (recaros, brakes, ect). You also will have a more valuable asset, since an S4/RS4 is worth more than an A4 with a motor swap.
If you're going to do a swap, it's gotta be unique with the ability to make a ton of power... 2.7T, VR6T, or SC 3.0T.
Honestly why not tune and mod you 2.0T? If you are stock a simple tune outpowers a 3.2, a K04 upgrade should be as quick as 4.2 V8, and a GT28/30 series turbo would be near RS4 power levels.
