Results 1 to 40 of 75
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Piston Ring Replacement
    I know that there is an oil consumption thread open already.
    I figured this might deserve it's own thread.
    I have gone through all the AOA recommended repairs and tests to finally warrant replacement of the piston rings.
    I'm at 37k miles now and my warranty will run out in another year or so. (50k)
    I have coverage thru my car insurance also, but there is a deductible.
    Does anyone have experience with getting their rings replaced?
    My understanding is the whole engine needs to be taken apart and it will take a week.
    I have some concerns about long-term ownership of this car after the engine has been rebuilt.
    Taking that up with AOA and the dealership right now, but wanted to get some feedback from everyone.
    -cW
    2023 X3 M40i Alpine White
    Dec 17 2008
    Charlotte, NC
    You're getting more than rings. Current protocol is replace the pistons and rings. If that fails then it's a new long block.
    I've seen several of these done. Usually they're fine after that.
    Ol' Whitey - 1996 A4 2.8 quattro 5MT Arctic White w/ Remus
    #2 - 2008 A4 2.0T Quattro 6MT Quartz Gray - w/ AWE exhaust (1/08 - 1/11)
    #3- 2011 A4 6MT Quartz Gray - Prem Plus, B&O, Titanium - Full Gen1 AWE dual exhaust, Eurocode Everything, 3M Clearbra, Piano Black Dash Surround, MY10 rear headrests, Huper Optik, S-line Stoneguards
    #4 2014 Audi S4 6MT - Monsoon + Black optics Neuspeed exhaust, Eurocode bits
    Audi Brand & Audi Sport Specialist at Northlake
    B8 Titanium Club Member #4
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Quote Originally Posted by AofC_RR View Post
    I was supposed to be fine after the PCV was replaced...
    Still doesn't make me feel better.
    Would rather have everything been perfect straight from the factory.
    I should have waited for a 2011.....
    -cW
    Apr 05 2011
    Pacific Northwest
    I'd look at it this way. Since your car wasn't perfect from the factory, the dealership and AOA will make sure that you get the right repairs so you are satisfied long term. And if something in that system fails, even outside your warranty, you can easily push for coverage since it has been well documented. I actually think you're all set.
    Highlander's Build Thread
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    On our '07 B7 2.0T, we had the piston/piston rings replaced. It was consuming a quart every 700 mi. So far, it hasn't consumed oil. 1500 mi and the oil is still at the max fill mark. It seems promising but I'll keep an eye on it. I wouldn't worry too much about it.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Veteran Member Three Rings routertyty's Avatar
    Aug 09 2010
    Honda Mini van
    Menlo Park, CA
    I'd be looking into the lemon law... Make them replace it with a new 2012.
    2011 Meteor Gray - A4 2.0T Tip Quattro Prestige & Sports
    Alu Kreuz Drivetrain Stabilizer • Eurocode Sways and End Links • Weather-Tech Mats • Hόper Optik 50% • S-line Stone Guards
    LED License Plate • VAG-COM'd • Sun Shades • B&O Stereo • OEM Chrome Tailpipe • 034 Silicone Turbo Inlet Hose
    Mar 02 2007
    Fresno, CA
    Meh, my '09 doesn't consume oil. Maybe you broke a mirror in the past 7 years or didn't notice that black cat that crossed in front of you on your way to buy your A4 or that ladder you walked under when entering the dealership...
    Mar 05 2009
    Earth
    ^ my 09 doesn't consume any oil either.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    What can I say. Love the car hate the problems.
    I will be a happy camper if they extend my powertrain warranty.
    -cW
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Quote Originally Posted by cory_can View Post
    That's good for you, but sucks for me.
    I think there was a bad batch or rings in MY 2010.
    -cW
    Mar 05 2009
    Earth
    My point was that you aren't immune to issues by merely buying a different MY....I'm sure 2011 and 2012's will also include their share of unique problems that creep up over time.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Yes, but in my case the whole engine is getting taken apart and put back together.
    So that's not quite the same as a steering shudder, water pump, wierd transmission shifting, or intake mani problems.
    All of which I also had and got corrected and was fine with.
    It doesn't help that every independent shop I've talked to recommends I push for extended powertrain coverage or just dump it when I hit 50k.
    -cW
    Sep 13 2009
    2010 A4 2.0T
    Mississauga, Ontario
    got my water pump replaced last week, and am in the midst of an oil consumption test myself. I anticipate it to fail, given the horrendous numbers I'm getting.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    When did you get your car? I think in Oct of 2009?
    Maybe we have the same build date....
    -cW
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    Quote Originally Posted by hender View Post
    how is your consumption in terms of numbers? 1 quart every 1k?
    [B]Current: Shopping now....
    Jun 11 2009
    North Jersey
    I had my pistons and rings replaced around the 29,000 mark. Currently at 35,000 and has not burned through oil.
    2010 A4 Brilliant Red, Prestige, S Line, ADS, APR Stage 2, APR Downpipes, H&R OE Sport springs
    Aug 21 2011
    S2000
    Monrovia, CA
    I just had my engine piston rings, pistons and bearings replaced by audi. My car had 45,000 miles when this was done. I love the fact that i now have essentially a new motor. All audi mechanical repairs in CA are good for 1 yr or 12,000 miles. I"m looking foreword to a long love affair with this car. I average 30,000 miles a year on my cars.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Quote Originally Posted by FSures View Post
    Were you a MY2010 with a 2009 build date also?
    -cW
    Aug 21 2011
    S2000
    Monrovia, CA
    2009 with a late 2008 build date.
    Sep 13 2009
    2010 A4 2.0T
    Quote Originally Posted by k9lovr View Post
    i've been recording every time i've had to top it off ** but its more like 1QT every 900km / ~560mi.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    And they did the PCV fix for you already?
    Looks like you will be in the same boat as me.
    I see new piston rings in your future....
    I'm supposed to hear back from AOA today on the warranty situation.
    -cW
    Sep 13 2009
    2010 A4 2.0T
    -cW
    don't think i've had the PCV fix yet. I just had my water pump replaced last week.
    Veteran Member Four Rings Leo14's Avatar
    Mar 09 2010
    North E. Jerz
    I'm surprised to see you need rings so early.. They just said I needed rings and im at 65k, even though I'm a b7.. my friends 09 burns oil to shit, dealer said he needed new turbo and hes at 82k. Usually takes them a week yes, engine needs to be rebuilt basically.
    RIP QG TI B7 A4
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    My oil consumption is not as bad as Hender, but my guess is Audi is aware of faulty parts (rings, pcv) in some of these cars.
    If it was just due to normal wear and tear, they would not OK a 5k+ warranty repair at 37k miles.
    It has to have been a bad batch of rings, etc that they know about.
    -cW
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Good news.
    They have extended my powertrain by 1yr/12k miles.
    So I'll be fully covered till 5yr/62k miles.
    SA also told me any carbon build-up or parts that need cleaning will be taken care of during this repair.
    So I'm feeling a lot better about this now.
    -cW
    Sep 13 2009
    2010 A4 2.0T
    Good news.
    -cW
    good stuff. i'll pursue similar with mine, then! i'll keep this thread posted with my progress as well, since we seem to be brothers.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Sounds good. I'm going in next Mon and it'll be in the shop for about a week or so.
    -cW
    Veteran Member Three Rings vtheman's Avatar
    Jul 09 2011
    Crown Vic Interceptor
    California
    Good news.
    -cW
    Cool, so now you can buy a catch can and be our guinea pig ;)
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Quote Originally Posted by vtheman View Post
    Not sure about the catch can, but the Eurocode inlet hose looks good for the $$$$.
    I am back in the shopping mode now :)
    -cW
    Aug 27 2008
    Houston Area
    Good news.
    -cW
    Speaking of carbon buildup... Any chance you can get some pics of the intake valves?
    2013 6MT S5 - Monsoon/Black
    Prem+ | Sport diff | Adaptive dampers | Nav | B&O
    Res AWE exhaust | USP intake | USS Sways | OEM 19" speedline | AluKreuz | 034 Trans mount | Interior LED | VCDS tweaks | F1 tint | Xpel PPF
    Previous : 2009 6MT A4 | Quartz/Black | Prem+ 2001 5MT A4 | Silver/Black | Premium pkg
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    They don't normally let us into the service area unless they want to show us something.
    I'm not much of a grease monkey so I'll have to rely on what they tell me regarding carbon build-up or sludge, etc.
    I'll definitely ask though.
    -cW
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Update:
    Got the car back on Friday.
    Took a week to get in the queue and then another week to get it done.
    Looks like there are quite a few of these getting done at the dealership.
    Here is the write-up.
    I went easy on the car the first 100 miles, then this morning did a spirited run to work.
    Good pistons + GIAC Tune = WOW!!!!
    I did not realize how much power I had lost from leaky piston rings.....
    -cW
    Veteran Member Three Rings STA4's Avatar
    Jan 12 2012
    Mississauga, ON, Canada
    -cW
    Good to hear. Improved performance may also be due to the removal of the carbon build up.
    Peter
    2009 A4 2.0T Quattro Premium 6MT
    Meteor Grey/Black | B&O | STaSIS Tune/Exhaust/Springs/RSB/Wheels | K&N Filter | Eurocode TIH/HFIP/IHK/HFC/Alu Kreuz | GFB DV+ | R8 Coilpacks | Strat O2 Spacer | BFI OCC | Podi Boost Gauge | Rieger Rep Spoiler | RS4 Rep Grille | A4L Foglight Grilles | LED Interior/Puddle/Plate/Signals | Morimoto 5500K HID Foglights
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Quote Originally Posted by STA4 View Post
    SA didn't mention anything about carbon build-up.
    I asked them a few times, but maybe there was.
    They were scrambling getting a bunch of these done so I dunno if their engine guy was really in the mood to answer these questions.
    Car feels great now and my warranty extension is coming in the mail in a couple of weeks so I can't complain.
    -cW
    Sep 13 2009
    2010 A4 2.0T
    Horseshit. They said I was burning .31L / 1000KM so it passed the test.
    I've been topping up way more than that. How could I suddenly get this "spectacular" oil consumption.
    so pissed right now. they act as if topping up every goddamn month is "normal"
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Did you get a new PCV yet? They should have at least got that taken care of for you first.
    -cW
    Sep 13 2009
    2010 A4 2.0T
    -cW
    that's going in next week.
    can you or anyone else around mention what their approx. "good" consumption is? i was told anything less than 0.5L/1000km is acceptable...but wtf! forrealsies? a fucking QT of oil every 2nd fillup is acceptable?
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    I'm still burning some.
    On pace for 1 qt in 1500-2000 miles.
    Must be the Manhattan commute.
    -cW
    Senior Member Two Rings lockeed's Avatar
    Feb 06 2010
    Quebec
    2010 here. Here are my last fill up kms:
    Low oil warning @ 41,500km - 1qt
    Low oil warning @ 44,901km - 1qt
    Low oil warning @ 46,628km - 1qt
    I asked for an apointment on feb 24th... I'm leaving the car there for 7 days as I'm going on vacation. They better find the problem this time. This will be the third time I ask for this issue to be taken care off. Last time, I brought the milleage at which I added oil... pretty much the same frequency as now... They told me they didn't found anything and to keep monitoring the oil !
    Senior Member Three Rings Nison_Li's Avatar
    Mar 05 2011
    '15 Q5 3.0T S-Line
    Baltimore, MD, USA
    sent my car in for the second part of the oil consumption test, it failed and pistons on order.
    SA told me at least 1 week before i see my car again.
    2015 Q5 3.0T S-line Premium Plus
    Done: LED interior bulbs, S7 Steering wheel, RS5 Pedals, warning tri angle, VCDS mods.
    Planned: Tune, Alu Kreuz, Sway bars, under seat drawers
