Results 1 to 21 of 21
    Feb 13 2004
    Silicon Valley, CA
    Can't check oil level on MMI
    So, for some reason, I can't check my oil level on MMI. Every time I try to, I get the message that the car must be on for approximately two minute and the engine warm, then the car needs to be off. If I turn the car completely off, it tells me the ignition has to be on, if I turn the ignition on, I get the first message.
    Guess I need to go to the dealer.
    Kevin - Moderator, Audizine
    Veteran Member Four Rings rayray's Avatar
    Sep 17 2010
    ‘19 S5/SB; ‘17 Q7
    Massachusetts
    Did you just add oil? I know this message popped up, a few weeks back for me, after I had to add a quart.
    2019 S5 Sportback Prestige | Daytona Gray Pearl on Black | Black Optics | S Sport Pkg
    2017 Q7 3.0T Prestige | Ink Blue Metallic on Nougat Brown | Driver Assistance Pkg | 21"RS Wheels | Towing Pkg
    Feb 13 2004
    Silicon Valley, CA
    Nope, I was checking to see if I need to add oil
    Sep 17 2010
    ‘19 S5/SB; ‘17 Q7
    Massachusetts
    Try resetting the MMI. It's a long shot, but it may work.
    Veteran Member Three Rings formula1guy's Avatar
    Apr 14 2009
    B8 A4 Avant S-line,2010 A4 prem + w sport package
    Northern California
    Hey Kevin,
    The wife and I get the same message in both of our cars once in a while. Usually after I've added oil. I would give it a day or so, try again whenever you start the car. If it continues then you're right, maybe a trip to Stevens Creek.
    W
    Veteran Member Four Rings maga4's Avatar
    Aug 12 2011
    Olathe, Kansas
    I don't know if mine is different for any reason (3G MMI/Nav) but I can check it after driving for a bit while the car is still on. I just did it today at a stop light leaving work after about 4 or 5 min of driving. Have you attempted to read it while the car was on after driving for a bit? Sounds kind of strange to say based on what you said above, but may be worth a shot? Good luck!
    2010 A6 3.0T Prestige, Quartz/Black
    35% Tint, VCDS, Hardwired V1, LED Interior/License Plate, Chipwerke Pro, WeatherTech
    Previous: 2011 A4 P+, APR Stage 2, 35% Tint, Eibach Pro-Kit, VCDS, Gloss Black Grille, Fogs,
    LED Interior/License Plate Lights, Short Shifter, BFI Catch Can, V1, Rieger Lip Replica, FRT's FMIC, aFe Filter
    Feb 13 2004
    Silicon Valley, CA
    resetting MMI worked perfect!
    Sep 17 2010
    ‘19 S5/SB; ‘17 Q7
    Massachusetts
    Quote Originally Posted by Stubek View Post
    Cool. So.... Do you need to add oil?
    Senior Member Three Rings Speycaster's Avatar
    Aug 16 2011
    2006 Audi A6 Premium (Wife's); 2008 Chevy 3500 Club Cab Duramax Diesel; River Wild, Custom Jet Sled
    Roseburg, OR
    Dip stick from ECS Tuning!
    2010 2.0T 6MT, APR Stage 2 ECU flash, APR turbo back quad exhaust, APR Carbonio intake, Eurocode HFIP, Eurocode Intercooler Hose Kit, 034 Turbo Inlet Hose High Flow Silicone, E-Code Xeon head lights, Various Vag-Com changes, H & R Coilovers, Hotchkis H-Sport ARB's, Eurocode Alu Kreuz Billet Aluminum Drivetrain Stabilizer, Stratmosphere Hypershift short shifter, TyrolSport Brake Caliper Stiffening Kit, S-Line Side Blades, 19" x 8.5" Hartmann Euromesh 3-GS:ML wheels, 255-35-19 Toyo Proxes 4 Tires
    Established Member Two Rings cdauks07's Avatar
    May 26 2008
    Bloomington, IN
    Quote Originally Posted by maga4 View Post
    I'm pretty sure checking it while driving is fairly inaccurate so it wouldn't do any good.
    2014 A4 Prestige Glacier White Metallic
    Feb 13 2004
    Silicon Valley, CA
    nope, only down a half quart in 5,000 miles!
    Dec 02 2010
    New Jersey
    Quote Originally Posted by cdauks07 View Post
    Absolutely correct - the oil needs to drain back into the crankcase to get an accurate reading. If the oil is circulating through the engine, the reading means nothing.
    Feb 13 2004
    Silicon Valley, CA
    I tried it in the parking lot at the grocery store and in my drive way. Even let the car sit 30 minutes, went back out and let it idle for 5 min and tried again, but the MMI reset fixed it.
    Oct 02 2010
    Singapore
    Alternatively you can open up your bonnet, power up the car (no need to run the engine) click the side 'up/down' button of wiper stalk. You should see the oil level display in the MFD, this method work immediately after top up of engine oil no need to wait for MMI to refresh which may take one day.
    Feb 13 2004
    Silicon Valley, CA
    That is good to know.
    I also have the "dipstick mod" just for this type of thing and used that.
    Sep 17 2010
    ‘19 S5/SB; ‘17 Q7
    Massachusetts
    Quote Originally Posted by des_me View Post
    hmmm.... I must try this soon... interesting to know
    Veteran Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    Yeah I posted the hood open one some time ago. Never figured out how to make it available full time though.
    Reaching Me:Please don't ask me questions on the forum or send me private messages as it may be a while before I respond.
    If you need something email me directly at [email protected] I don't frequent this forum very often.
    www.audienthusiasts.com
    Sep 17 2010
    ‘19 S5/SB; ‘17 Q7
    Massachusetts
    Quote Originally Posted by DavidB8 View Post
    Now that see that pic, I do remember you posting this.
    Mar 10 2013
    I have a 2009 A4, and the oil level MMI was working perfectly - until I was poking around the engine bay and opened the oil lid, closed it. Didn't do anything else. Now I get this message. Tried resetting MMI (Pressing setup + control knob + top right). Tried reading MMI with hood opened.
    Still getting the same odd message: "Oil Level display available after approximately 2 minutes. The engine must warm and must be switched off."
    Does it need to wait a few days before reset of MMI registers?
    Veteran Member Three Rings gunsmoker's Avatar
    Oct 24 2011
    Mansfield,MA
    ^^^ You need to wait a couple of days after you close the hood, especially if you have the stage I oil consumption fix. They made the ECU software more picky.
    2011 A4 2.0TFSI Quattro 6MT, Premium+, 18" Sport Package, Ice Silver, Light Grey, Dark Walnut, AWE Exhaust, STaSIS ECU Tune, Deval CF Splitter, aFe Pro Dry S Filter, ECode Turbo Inlet Hose, Alu Kreuz, Osir CF Valance, R8 Coil Packs, ECS Two-piece S4 Rotors, H&R Rear Sway Bar, 034 Trans Mount, RS5 Pedals, Ultra Racing Strut Bar
    Senior Member Two Rings tgofsweden's Avatar
    Nov 03 2012
    ///M3
    GBG, SWE
    hi David,
    mine is pre-equipped with dip stick, what do I need to get/add to have this feature in mmi?
    thx
