Results 1 to 7 of 7
    Senior Member Three Rings jeradw's Avatar
    Jul 18 2009
    2008 A4 (his) 2010 Tiguan (hers)
    Wisconsin
    B-Pillar Interior Trim Removal
    Hi all!
    I think I've narrowed down a god-forsaken rattle to the driver side b-pillar. I want to get in there and see if I can isolate it! I've done a little searching around, but haven't found a really good article on how to remove the b-pillar. Some have some decent instructions, but no good pictures. I think I just need some good pictures so I know what I'm looking for when removing these clips.
    This guide seemed pretty good, but it's for the b6 platform and I didnt know if the pillars removed the same way:
    http://www.audizine.com/forum/showth...r-removal-swap
    This one seemed detailed, but mentioned caution around the airbags and whatnot:
    http://forums.audiworld.com/showthread.php?t=2016871
    Here is a B8 guide - again...not sure if the instructions are the exact same:
    http://www.audizine.com/forum/showth...B-Pillar-trim?
    Could someone please shed some light on this for me? Thanks for the help!!
    -Jerad
    2008 Tip A4 Special Edition - Brilliant Black
    18" Enkei EKMIII Gunmetal (summer) // Hyper Silver (winter) | 35% Tint | Eibach/Koni FSD Street Kit | de-Badged
    AWE Diamond Black QuadTip | Blackout S-line Grille | Ti Trim | Color Matched Front Reflectors | Smoked Side Markers
    Front Filler Plate (Black) | Plastidip'ed Trunk Strip (Black) | K&N Drop-in | APR 93 Stage I
    Established Member Two Rings daudic's Avatar
    Jul 06 2009
    2007 A8l. 2003 TT Roadster. 1985 Yamaha Vmax!
    Lancaster/Ohio
    Sorry, no pictures! Remove the driver's o-crap handle and the bolt behind the airbag plug. Pull the headliner trim out a little so you can see behind it. Note: it might have a lip that tucks under the rear panel, but it will flex. The upper B panel has 1 bolt right above the middle hidden behind the headliner trim. Remove it and the panel will pop off with some force. Grab the B pillar from the top and pull, then slide it up. When you put it back on, align the seatbelt adjuster with the mechanism behind it and press the panel back into place. Slide the rubber door trim back out and put the bolts back. The bottom panel can be removed after taking the top panel off.
    Veteran Member Four Rings Sal_B7's Avatar
    Dec 11 2007
    2005 A4 2.0T Quattro 6Spd
    San Diego, CA
    I used the B6 DIY when i removed my headliner. Pretty much spot on with the B7 interior. The only thing is that that there is a bolt that holds in the top part of the B-pillar that you need to unbolt. Forgot what size it was.
    '05 A4 2.0T Quattro MT APR Stage 3
    2008 APR Holiday Giveaway Winner!! Thanks APR!!
    FRRG Southern Ring
    Xbox Live ID: Sqzn2zz
    Senior Member Three Rings Khaotic's Avatar
    Feb 21 2011
    2001 Audi A4 Avant 1.8T Quattro
    Sweden
    I swapped my headliner a while back and found this pic that might help you a little with acutally getting it off;
    At the red circle there's a bolt and the clips are circled in blue.. Mine came off easy just removing the bolt and grabbing the bottom at the clips and pulling.
    I have the A-pillar lying in the garage aswell if you'd like a pic of it aswell from behind to better understand, but its just like on a B6/as daudic describes it.
    No need to worry about the airbag curtain, you wont be anywhere near the connector to it (which is at the back).
    2007 Audi A4 Avant 2.0 TQ 6MT S-Line
    Exterior: Bi-Xenon Retrofit | 30% Tint | KW V2 Inox | 19" VMR 701
    Interior: LED Lighting | Black Headliner | RS4 Shiftknob | oCarbon Trim | TTS Steering Wheel | Audio build
    Engine: REVO Stage 2+ | STaSIS Exhaust | R.A.I HFC | Custom CAI | AWE FMIC | HPFP Stage 1 | RAI Catch Can | JHM Flywheel & Clutch | USP Metal Slave & Clutch Line | JHM SS Trio
    Jul 18 2009
    Wisconsin
    Thanks guys - I'll give this a shot this weekend and report back!
    Edit: so I decided to try this already tonight. I was able to get the top portion of the B-pillar off without a problem, but I am getting stuck on removing the bottom portion. I have the front seat portion of the trim unclipped, but I cant for the life of me get the back seat portion unclipped! Does the back seat section unpop the same way as the front seat section?
    Thanks guys!
    Feb 21 2011
    Sweden
    Yea, its the same at both ends at the bottom.. But thoose metal clips sits real hard sometimes.
    Jul 18 2009
    Wisconsin
    Quote Originally Posted by Khaotic View Post
    Ok - well thats good. I found some other post last night saying that you have to remove the rear seat cushions in order to get to that piece of trim.
    http://www.audizine.com/forum/showth...illight+remove
    Specifically, post number 7 by Joe
