Originally Posted by
Stereodude
That would explain why I totally forgot to mention running the engine leaner to get more power. Oh wait... That's right... I did mention that. I guess I don't have as much to learn about tuning as you think.
Not looking down on you buddy, but you really don't understand, and I am not going to write 10 paragraphs.
The logs I have seen from APR show they run it leaner then REVO, but like I said IDK how that compares to stock.
At any rate, as far as gas mileage goes it is a moot point for the most part, as in the cruise range the car will run 14.7:1 anyways. Technically it will have some variance from that for emissions running the cats slightly lean and then slightly rich................
You are thinking about what tuners do at high load areas on the map, adjust AFR, adjust timing.
When most people think about fuel economy they think about non WOT driving.
The vast majority of tunes do not at all affect what the car does when you are going 70 mph at 2200 rpm (or whatever it actually is) at very low throttle settings.
So your statement of running it leaner might be true, but that is not an across the board running it leaner, it is much more complicated then that, and they adjust the AFR based on engine load/rpm and possible other things.
OEM does a very good job of getting the best economy/emissions at low load, and a tuner will have a hard time bettering that. Is it possible to get better fuel economy from a tune? Yes, but almost always at the expense of emissions, as the economy/emissions are not the same things. Either way, most tunes don't touch this stuff.
If you still don't understand, I can post up screen shot of AFR tables to illustrate.
