Results 1 to 19 of 19
    Senior Member Three Rings cyberbrutus's Avatar
    May 09 2011
    Chicago
    When to shift for maximum acceleration ?
    I always shift between 5000-5500 in S mode and am wondering if there is a secret shift recipe for maximum acceleration.
    Should I shift at different RPMs in different gears ? Does chipping/HFC/Intake change anything ?
    I know there are a couple of race car drivers in the forum and was wondering if they can shed light on this topic.
    I have 8 speed tiptronic with padel shifters.
    2016 A6 3.0 P+, LED, Sport, Bose
    Gone but not forgotten: 2011 A4 P+, Titanium, P. Black, Nav, B&O
    APR Stage 2+, HFC, Carbonio, LED I/L, VAG-COM, Hoen Xenon, Llumar 35%, 19x9.5 40F/35R AG M310 M.Black (Winter)
    Old Build Thread: http://tinyurl.com/3zh6mtw, Old Winter Thread: http://tinyurl.com/8x3oabo, Old Project B.O.B: http://tinyurl.com/7gbgf65
    Veteran Member Four Rings MilesM's Avatar
    Jan 17 2011
    RSQ8
    LA / SF
    Doesn't mean I'm going to know the optimal RPM to shift at for every car, because every car is different.. Lol.
    That said, I've found that with my 6 speed Tip it grabs gears around mid 5000's to just under 6000 when launching. Under normal acceleration it runs to redline before it shifts, not sure if my tune and other mods have raised the redline.
    Veteran Member Three Rings v1nyd's Avatar
    Jun 15 2008
    Long Island NY
    Well every engine mod you do depending on what it is will definitely effect the car on a dyno...and on a dyno is where you'd be able to see where your car is performing at RPM wise. But in reality for a 8 speed automatic it's not going to matter much to you unless you're racing this thing down a 1/4 mile.
    Forum douchebaggery
    May 09 2011
    Chicago
    Quote Originally Posted by Miles M View Post
    Lol...I knew you would respond..
    How do you calculate in a race car situation? Dyno or any other tools ?
    May 09 2011
    Chicago
    Quote Originally Posted by v1nyd View Post
    My coworker has the 8 speed too..I want to win just in case we decide to race.
    Thats the reason why I wanted to know the ideal shift RPM.
    Jun 15 2008
    Long Island NY
    Quote Originally Posted by cyberbrutus View Post
    gotcha, in that case bragging rights is well justified.
    Forum douchebaggery
    Aug 27 2008
    Houston Area
    You'd have to do some math for the 8speed, but ...
    http://www.audizine.com/forum/showth...-with-APR-tune
    2013 6MT S5 - Monsoon/Black
    Prem+ | Sport diff | Adaptive dampers | Nav | B&O
    Res AWE exhaust | USP intake | USS Sways | OEM 19" speedline | AluKreuz | 034 Trans mount | Interior LED | VCDS tweaks | F1 tint | Xpel PPF
    Previous : 2009 6MT A4 | Quartz/Black | Prem+ 2001 5MT A4 | Silver/Black | Premium pkg
    May 09 2011
    Chicago
    Quote Originally Posted by B8_Jim View Post
    Thanks Jim. I will post my findings.
    Senior Member Two Rings ljnaum26's Avatar
    Feb 02 2011
    Us
    Its weird, sometimes i feel like my car pulls harder in D than sport. Anybody ever notice this?
    May 09 2011
    Chicago
    My car pulls hard only in S mode. But if I let the car shift, the results vary every time. Thats why I take over manually and shift it.
    Btw, I dont know if you guys know this but APR Valet mode is not fool proof on cars with padels. You can run the RPMS higher than 4000 if you shift manually.
    Jan 17 2011
    RSQ8
    LA / SF
    Instinct, Sound, Feel. There are shift lights, but those are just references.
    Senior Member Two Rings fredjones's Avatar
    Apr 24 2009
    Mobile, Al
    Shift preference has changed in my car as my mods have changed. With stage 1 I rarely like to go above 4000rpm before I shifted. With the stage 2 I find myself keeping it in a gear up to 5000rpm because the boost just keeps pulling. I also have found the stock tiptronic transmission program does not know the ideal shift points to use with the stage 2 and a lot of times I will use manual mode to get it to shift just where I want. Too bad the transmission can't be reprogrammed too.
    2009 Audi A4 Prestige, Brilliant Black
    Mods: APR Stage 2, APR Downpipe, H & R Rear Sway Bar, License Plate LED.
    Aug 27 2008
    Houston Area
    I got curious - the tighter gear ratios of the 8 speed changes things a bit, but not that much...
    This is using the gear ratio info from http://models.audiusa.com/a4-sedan/d...#chassis_specs, and the Audi "idealized" torque curve so the real world will vary a bit...
    Apr 25 2012
    Michigan
    Get a stick and solve all of your problems.
    Established Member Two Rings alk's Avatar
    Jul 23 2011
    Denver
    How will having a stick help you shift at the optimal shift point if you don't know what the optimal shift point is?
    Established Member Two Rings Frings's Avatar
    Apr 10 2012
    NEOhio
    A little off topic but sorta on topic. Where's the rev limiter on the 2.0T?
    Veteran Member Four Rings ultra's Avatar
    Apr 12 2007
    13 Allroad
    San Antonio,TX
    lol@S-mode
    Eurocode
    2013 Allroad Volcano Red, Eurocode goodies
    2018 SQ5 Florett Silver S-Sport package
    Veteran Member Three Rings gunsmoker's Avatar
    Oct 24 2011
    Mansfield,MA
    I did such a plot some time ago using a closer approximation of the torque curve and the 6MT ratios. My conclusion was that 1-2 and 2-3 shifts were good at red line and for 3-4, 4-5, and 5-6 there was like 500 RPM before red line where the higher gear had more torque. In reality I start shifting to second at 5500 because otherwise there isn't enough time under hard acceleration to avoid getting the boot by the ECU. Haven't had the chance to get close to red-line in 4th yet.
    2011 A4 2.0TFSI Quattro 6MT, Premium+, 18" Sport Package, Ice Silver, Light Grey, Dark Walnut, AWE Exhaust, STaSIS ECU Tune, Deval CF Splitter, aFe Pro Dry S Filter, ECode Turbo Inlet Hose, Alu Kreuz, Osir CF Valance, R8 Coil Packs, ECS Two-piece S4 Rotors, H&R Rear Sway Bar, 034 Trans Mount, RS5 Pedals, Ultra Racing Strut Bar
    Aug 27 2008
    Houston Area
    Quote Originally Posted by gunsmoker View Post
    What did you use for a closer approximation ? From what I've seen it varies car to car and ambient conditions...
