Tools needed:
Strong glue (I used a plastic epoxy)
Tooth pick or similar
#10 torx bit
extra hands (I did it by myself but another person would help a lot)
Parts Description:
End Cap - Black end cap held on by two silver #10 torx screws
Plasitc Retainer - Black plastic retainer that holds the SPRING ROD onto the END CAP. It is held on by two black #10 torx screws
Spring Rod - Long silver rod with a spring around it. There are also two white SUPPORT CLIPS on this rod.
Support Clip - White rod clip that goes inside the SUPPORT ROD.
Support Rod - Silver rod that the fabric cover attaches too and rolls up onto.
Aluminum Extrusion - This is what the end caps screw onto and the fabric rolls up into.
Step #1 - Remove end cap
You only need to remove one of the caps. It's the side that doesn't have the button to remove it from the car. There are two small #10 torx screws that are recessed pretty deep. I had to buy a small screw driver set that had a thin torx bit. My regular 1/4" bits wouldn't fit. You don't need to remove the center screw.
Once the cap is unscrewed from the aluminum extrusion you can pull out the cap, spring and support rod. Here is the rod and the white support clips that go inside the fabric support tube.
Step #2 - Remove spring rod retainer
There is a small plastic retainer that is held on by two black #10 torx screws. It's kind of tight but you can get the torx bit in there. Once the screws are out just slide the black plastic retainer out of the way. (This is a picture after things have been glued but it shows the retainer)
Step #3 - Find what's broken
The reason why the cover wouldn't retract anymore was that there is a plastic connector inside the cap that can break. This makes it so the spring tension isn't held anymore so there's nothing to pull the cover back in. You need to anchor the spring rod to the cap again. This is where the epoxy comes in. I glued the spring rod back to the cracked plastic connector. Mix up the epoxy (I used a 5 min set time) and use a tooth pick to spread it in between the rod and the spring retainer.
Before the glue hardens all the way you need to put the plastic retainer back on with the two black torx screws. This will sandwich the spring rod onto the connector. Now just wait for the glue to harden.
Step #4 - Reassembly/Tensioning
Now unlike most reassembly proceedures this isn't "Assemble in Reverse Order". It is difficult to show this step with pictures so I will try to explain as best I can. First, insert the spring rod into the support rod that holds the cargo fabric. With the spring rod about half way into the support rod you need to start spinning the cap counter-clockwise. You should resistance from the spring as you do this. If you don't feel resistance then the glue didn't hold or the spring rod is spinning still.
You will need to spin the cap until the fabric starts to retract. It helps to have another person hold the other end of the entire thing so the fabric hangs down towards the ground. Keep spinning the end cap even after the fabric has been fully retracted. I gave it another ten turns before I stopped.
Step #5 - Reassembly/End Cap
Now you need to screw the cap back on. DO NOT LET GO OF THE END CAP!! You will loose all the spring tension and the cap will spin wildly. If this happens go back to #4.
While still holding the cap slide it back into the extruded aluminum piece. It can only go on one way but it's still a little funky as there's spring tension trying to spin the cap out of your hand. Once the cap is back onto the aluminum piece you can let go and screw the two silver torx screws back in.
You are now complete and test out the cover. I hope that I explained everything all right and that this helps out anyone has this problem.
