Results 1 to 12 of 12
    Nov 13 2011
    Tampa Fl
    Radio removal tool alternatives
    Anyone have a hot tip on what I could use to get the radio out other than the audi tool?
    Mar 03 2011
    If you want to remove it without destroying anything in the process, just get the tool. They aren't expensive. Or see if a local car audio place can pop it out for you.
    Nov 13 2011
    Tampa Fl
    Audi is closed today, CD error 3 and I can't F'n stand the radio or sat. If I here moves like Jager one more time someones gonna get hurt :) Gonna try grinding down an old kitchen knife to the right width.
    Veteran Member Three Rings gear_head81's Avatar
    Apr 08 2008
    empty for now
    Lexington, KY
    did you try the classical station or turning the player off and just listening to the sweet sound of your V8. the plastic face on the stereo is extremely fragile be very very careful with it, and you would need to grind down at least 2 kitchen knifes possible 4 depending on how much of a PITA its being.
    A.R.M. Member - Military 4 Rings Member (Veteran)
    Veteran Member Three Rings Dcass08's Avatar
    Jul 21 2011
    Rochester NH
    I cut down a hacksaw blade. It worked well.
    Nov 13 2011
    Tampa Fl
    http://www.ebay.com/itm/Audi-Vw-Radi...#ht_755wt_1163
    Guess I'll have to deal for a couple more days, hopefully these work!
    Nov 13 2011
    Tampa Fl
    I cut down some strips of aluminum and slid all 4 into the slots, the stereo didn't budge, it looks like the factory tool has some little notches though, did you cut those into your hacksaw blade?
    Veteran Member Three Rings adioman6000's Avatar
    Jan 12 2011
    SLC
    at autozone you can rent a radio removal kit. i think it has the one for audi in it.
    Apr 08 2008
    empty for now
    Lexington, KY
    Quote Originally Posted by adioman6000 View Post
    that is true, and i think o' reilly's sell them
    Veteran Member Three Rings stormscr3's Avatar
    Jul 08 2008
    2011 Ford Edge
    MA
    i used lock pick tools i had ... works like a charm
    Senior Member Three Rings rstein's Avatar
    May 20 2011
    I went to Best Buy. Just drove right up to the bay where they do the audio work for the cars right when they opened up one morning and the guy had popped my radio out for me for free but I threw him 20$ for lunch.
    Veteran Member Three Rings Slavchob's Avatar
    Apr 27 2010
    2003 Audi S8
    Syracuse NY
    Walmart has the tools for like 5 bucks when I bought them 3 months ago. There's two in the box. You need 4
