Originally Posted by
icrashcars
Are there any physical differences between these two engines or does the extra 60Hp in the S8 come from the tune and exhaust?
More than just a tune and exhaust. Your A8 is a 32V. The equivalent 32V S8 was not sold in the United States, and was 40 hp up on the regular A8. The 40V version was 60 hp more than your 300, and 50 hp more than the 310 offered by the A8 40V.
Audi S8 32V.
01) Solid exhaust tappets.
02) Different camshaft profiles.
03) Different ECU.
04) Different pistons (higher CR).
05) Larger intake plenum.
06) Larger throttle body.
07) Larger exhaust manifolds.
08) Larger exhaust ports (different cylinder heads).
09) Different catalysts.
10) Different injectors.
11) Different transmission (lower final drive).
12) Different rear differential (lower final drive).
13) Different MAF.
14) Different airbox.
Audi S8 40V.
01) Different camshaft profiles.
02) Different ECU.
03) Different pistons (higher CR).
04) Larger intake plenum.
05) Larger throttle body.
06) Larger exhaust manifolds.
07) Larger exhaust ports (different cylinder heads).
08) Different catalysts.
09) Different injectors.
10) Different transmission (lower final drive).
11) Different rear differential (lower final drive).
12) Different MAF.
13) Different airbox.
All S8 engines rev higher than the equivalent A8's, hence the lower final drive to make the best of the engine's peaky nature. They're redlined at 7,000 rpm versus the A8's 6,400. It'll take more than a tune and exhaust to boost your 300 hp to 340, never mind 360 hp. Not without some form of forced induction. To attain those numbers whilst keeping the engine naturally aspirated, you're talking big bucks - tubular headers, cat delete, lumpy cams, throttle bodies, custom tune. I wouldn't fancy running an A8 engine at 7,000 rpm with your hydraulic tappets long term.
