So I'm not sure whats going on so heres some background.
A couple weeks ago my rear brakes started to seize up and it trashed my rear rotors and pads so I cleaned up the rear sliders, checked out the rear brakes and made sure the ebrake cable wasnt getting stuck and up until last night my problem was solved.
Now all four of my brakes are sticking, I'll be pushing 15 psi in fourth just to get above 45mph.
Heres whats weird about it though, the brakes will get so bad like that and the steering wheel will start to shake and I can stop on an incline and the car wont roll at all, but then if I pump the brake pedal 5-10 times they will release and I'll be able to drive the car normally again.
This morning I left my buddies house, brakes acting like they should, not sticking at all and then halfway home I had to pull over and try to pump my brakes to get them to release because I could hardly move.
After the last incident I've stopped using my ebrake and just park the car in gear because I thought that was the problem but clearly its something bigger.
So I need some help here because I just did the A8 brakes up front and dont want to trash those too.
