Results 1 to 40 of 69
    Established Member Two Rings TheSilverF0x's Avatar
    Oct 11 2011
    '19 Mustang GT
    Virginia
    Fluttering, loss of power...At my wits end
    Ok, so now there's another problem that just surfaced this morning. I'm just going to be blunt and to the point about it.
    First of all, I've searched and read, but mine seems a little different, so here it is.
    I'm having loss of power. It feels like when you blow an intercooler pipe off, but not nearly as bad. It's felt like it's NA all day today. Tonight, I went driving on the road in front of my house to listen to the turbo.
    When I accelerate (full throttle) up to about 3,500 rpm, it sounds like the turbo is fluttering. I've searched fluttering turbo, and all the info I've found talks about it fluttering off throttle not wide open.
    After the fluttering noise ceases, you don't even hear the turbo anymore (or I can't). Again, it sounds like an NA motor revving up.
    I don't have any codes present.
    I have noticed since I got the car back last week (before this lack of power/fluttering stuff started), the turbo has been making the dentist drill noise. I notice it primarily while cruising, and give it about half throttle (enough to shift down a gear or two). It's decently loud when it happens because I could hear it over the cd player (wasn't turned up loud by any means).
    I'm going to go to Lowe's to pick up the parts to test for a boost leak tomorrow evening, but if I can't find anything there, where do I start next? I might as well pull the TIP and check for shaft play too, but would you try replacing the DV?
    If it's the DV, I assume that would make the fluttering noise with the boost leak test, correct?
    Oh yeah, when I popped the hood to look around with a flash light, over the turbo smelled like popcorn.
    I'll still continue to search, but any helpful input? I'm trying to read, but it's like my mind isn't accepting input. I have a load of stuff going on at the office, I told my wife last night that I wanted a divorce, I haven't slept in what feels like weeks, and I bought this car October 8th and have only rode it a total of about 3 weeks since I've had it. It's been in the shop pretty much since I bought it. I'm just getting stressed out really bad and overwhelmed with it all.
    As always, any help is greatly appreciated guys!
    B9 S4 that's stock'ish
    Veteran Member Four Rings waldo1324's Avatar
    Apr 06 2009
    the Ghost of the Princess, 2007 Ford Fusion, 2006 Honda Accord
    The StL
    Quote Originally Posted by TheSilverF0x View Post
    possibly a bad N75 valve or blown turbo?
    and good luck with your shit storm..stay strong brother!
    ""GHETTO MODIFIERS"" member #1
    The Princess: SOLD.. i love you, please forgive me
    "I agree with Waldo 100%" -1997GTX
    ..psst if you have a 2003+ 225 TT, email me..wally.iverson(at)gmail.com
    Senior Member Two Rings AndrA4's Avatar
    Feb 24 2011
    (Syracuse)
    Hmm... dentist drill sounds like a blown turbo. Did you check your exhaust gases? If its blue, chances are your turbo is blown. Anyone else want to chime in?
    Jun 27 2011
    Sounds like a blown DV to me. Possibly a blown N75 but that usually sends the car into limp mode which it doesn't seem like you are experiencing.
    Dentist drill noise is probably a blown turbo. Could happen for various reasons, including low oil pressure, or a bad N75 causing surging which would wear out the bearings.
    I would get a new 710N DV (they're like $40) slap it in and see if it helps. I usually hate throwing money at a problem before I know whats causing it, but cheap and easy test fixes like this I'm ok with.
    Is there any chance the shop your car was at could have done anything to the turbo? You said it wasn't making the noise before...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Oct 11 2011
    '19 Mustang GT
    Virginia
    I looked last night at the 710N DV on ECS, but can't order anything because the ATM machine ate my check card the other night. It took the card, and the bank told me that they'd send a new one in 5-10 days because it's policy that when a card is eaten that they replace it and destroy the old one. I might try to stop by the bank, get more cash out, and then go get a prepaid debit card to order that.
    Correct me if I'm wrong, the N75 is equivalent to a boost control solenoid right? I search later this evening when I get home, and find out how to replace it. I might just go ahead and get one of those too.
    I had to drive the car to work today, and the turbo noise is getting louder. The boost surge didn't seem as bad today, but at certain short periods, the car feels normal, then it goes to feeling anemic again. I'm going to try to pull the TIP, airbox, etc., Friday and check for any shaft play, visible wear, and such.
    I don't think the dealership would have done anything. They did the 90k maintenance and put in a new oil pressure sensor, but that's all that I know of. Everyone always spoke highly of them, so hopefully they wouldn't have screwed it up.
    I took the car to the dealership because I had the dreaded red oil light of doom, but when they checked my pressure it was really good. With the turbo acting up, I almost wonder if it had any type of oil starvation associated with the oil light, but it doesn't seem likely where the pressure is good.
    What's a good way to check for a vacuum leak on these cars? When I had my DSMs, we would take a can of starter fluid and barely, barely mist around the lines. When the car revved up, then you knew you were close. Got any better suggestions?
    Apr 06 2009
    The StL
    if nothing else , id suggest pussy-footing the hell out of that thing until you get a new n75
    btw-- i have a used one for sale .. pm'd
    Jun 27 2011
    Pulling the tip sounds like the best idea at the moment. It could be the DV but it could also be the turbo.
    The N75 is a Wastegate control valve, basically a solenoid as you are describing. Its a very likely failure candidate for what you are experiencing. Its expensive, but you could always go with the "E" revision that ECS lists for 1/2 the price of the newer "J" revision. I wouldn't count on it lasting as long as the J revision, but it'll do the job at 1/2 the price. I would check the out the turbo before you drop any cash on an n75. Of course Waldo's used one may be the ticket for you.
    While you're pulling the TIP, you might want to just throw in a new, or used but still functional Diverter Valve just to rule that out. I'm not sure if there is some way to test if the N75 is functioning correctly or not, maybe someone can chime in on that.
    -CP
    2017 Q7 3.0t
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    does it sound like this? If so you will need to replace your turbo in the near future.
    Jun 27 2011
    Sounds like a kazoo...
    -CP
    2017 Q7 3.0t
    Oct 11 2011
    '19 Mustang GT
    Virginia
    Quote Originally Posted by waldo1324 View Post
    You have a PM good sir.
    Oct 11 2011
    '19 Mustang GT
    Virginia
    Mine sounds like a super high pitch dremel or rotary tool. It's getting louder too. I hardly ever heard the turbo when I bought it, but can hear it with music on now.
    I'm checking everything Friday. I'm going to pull the TIP and check the turbo. I'm keeping my fingers crossed because I really don't want to buy a turbo yet. I'm still trying to figure out my plan of attack; whether that includes selling this car and getting a manual, or just keeping it and doing a GT28RS/APR III+ setup.
    Dec 28 2006
    Western Maryland
    Sure sounds like it’s time to replace the turbo.
    Oct 11 2011
    '19 Mustang GT
    Virginia
    Do the K03s not last any longer than 89k miles? Better yet, does anything on these cars last more than 80k?
    It is what it is though, and if it has to be replaced, then I guess I'll start searching for a new turbo and feed/return lines. Eventually when everything is new, I won't have to worry about anything failing on me. Then that's when a meteor will decide to hit my car and total it, haha.
    Dec 19 2007
    York, PA
    im at almost 110k with VERY little shaft play
    Veteran Member Three Rings 03a4sport's Avatar
    Nov 14 2006
    Noblesville, IN
    I was really intending not to read this thread since my problems seem to be just like yours. My car seams to be surging anytime I'm in 2nd gear lately (feel a pull, then a lull, then a pull). For what it's worth, I've heard the "dentist drill" for about a year now and think my turbo is just about to die on my. I plan on pulling the TIP to see what I can find. My Forge 007 is only a few years old now.
    I'm hoping for the meteor impact any night now. At least that way I can have insurance cover it.
    So now the question is, replace the K03 and stay the way the car came factory, or upgrade to a K04? Decisions, decisions.
    Quote:
    Originally Posted by B6driver
    its suppose to scoop up air, not snow... too much air + missing screws = dragging pan at 70 mph and people behind you scattering when the pan flies off
    ____________________________________
    Current: 2010 B8 S4 Prestige DSG / Roc Euro Intake / 034 Transmission Mount Insert / Ebay LED interior lighting
    Wrecked by someone paying attention to their Iphone and not the road: 2006 S4
    Sold: 2003 A4 1.8TQM
    Apr 06 2009
    The StL
    Quote Originally Posted by 03a4sport View Post
    good excuse for a ko4! i cant wait for my 126K turbo to crap out... i wonder what it takes to go KO4?? time to search!
    Oct 11 2011
    '19 Mustang GT
    Virginia
    If I'm replacing it, then I'm going to go with at least a K04 unless I come across a K03 insanely cheap. I'm hoping that I won't have to, but it's not looking so good. I guess I'll find out Friday.
    I ordered a 710N from ECS this morning, and hope it ships today. I tried calling them and chatting both, and never could get anyone last night or this morning. I went ahead and ordered it anyways though (fingers crossed).
    Jun 27 2011
    I usually order from GeniuneAudiParts.com. They're awesome, almost always the best prices, and since they are located on the west coast, really fast shipping for me as well. Their site sucks, so you have to know the part numbers you need, but they're great otherwise.
    I think with a K04, (at least according to APR), all you need is TT injectors, the turbo itself, some gaskets, a compressor o-ring, some turbo->DP studs and a tune. I would it would be $1800 out the door for all that. Install wouldn't take much if you're handy with a wrench, as its basically bolt on.
    -CP
    2017 Q7 3.0t
    Apr 06 2009
    The StL
    Thats it?? i have that in my couch cushions))
    Jun 27 2011
    Haha, it adds up. You can get just the kit from ECS for $1380 ($1340 with Genesis 380cc injectors instead of TT injectors) You could probably get the tune for less than APR's page says. If you already have a tune through them, the upgrade to the K04 file is like $200. So doing all the work yourself, buying a legitimate KKK K04, not a chinese RPTurbo POS, and assuming you can get upgrade pricing from APR you'll be at $1600 rather than $1800+.
    That makes it marginally more palatable. You could probably find a used K04 out there in the classified for less too. The hardware is only $30. The injectors ate $280 at Eurocode. So, $310 plus whatever the cost of the turbo.
    -CP
    2017 Q7 3.0t
    Apr 06 2009
    The StL
    now youre talking my wallets language-- used!!
    please paypal your K04 donations ...its for a good cause...will somebody think of the children??!!
    Jun 27 2011
    I'm accepting donations too. 10% goes to charity, the other 90% also goes to "charity".
    -CP
    2017 Q7 3.0t
    Oct 11 2011
    '19 Mustang GT
    Virginia
    Are there Genesis injectors that aren't so good? Seems like I may have heard that, but I could be wrong.
    I'm pretty good with a wrench when I have the place to do it. We had a garage in our town and moved it due to some different owners coming into play, but last night I went down by my parents house and my dad was telling me about another garage with 25 minutes of both of us for a really good rate. I told him I'd foot half the bill just to have a place inside to work on the Audi. It's cheaper to do that than pay a mechanic at the rate I'm going with it.
    I've been trying to look around for some KKK K04 pricing. I did look on eBay for a KKK, but probably wouldn't buy from there. I've actually seen locals buy a few chinese turbos, and man, it NEVER turned out good. That's one thing I would never skimp on. However, I wouldn't mind finding a good, used turby for the right price.
    Oct 11 2011
    '19 Mustang GT
    Virginia
    Oh yeah, I'm accepting donations too. 10% charity, the other 90% to strippers...errr, I mean the children. It's all for the children.
    Jun 27 2011
    People sell them here on the classifieds on occasion So keep checking there. The Genesis injectors are fine, but less compatible with tunes because they don't have an optimal spray pattern and their flow rate ramps a bit differently than the TT injectors. APR's tune doesn't work perfectly with them for instance; it works, but not as well as it could. I think other K04 tunes might be tailored around them though since they are a bit cheaper than TTs. I would shop around and decide on a tune, then worry about the injectors after you decide on that.
    You could also just slap a K04 in without a tune or injectors and it would run just fine. You wouldn't be using the fullest potential of the K04, but it'll run.
    -CP
    2017 Q7 3.0t
    Dec 28 2006
    Western Maryland
    Actually the Genesis 380's are an excellent choice. They have a dual cone 15° spray pattern which is pretty much the same thing as the OEM injectors. The flow difference between 380cc and 386cc is minimal and the ECM can easily accommodate the difference. The Siemens and Bosch 380's are a single cone straight spray pattern. I have been running the Genesis injectors for ~90k trouble free miles. For the $$ I think they are a decent alternative to the TT 386 injectors and are worth considering.
    Edit: But now that you mention it I do recall some threads from a few years ago (MikTip maybe?) who had better luck with the TT 386's than the Genesis. I'm running the GIAC 1+ and they perform flawlessly. No cold start issues even in subzero conditions.
    Jun 27 2011
    Oh really? I thought people had been having issues with them getting lean codes and such. I stand corrected (probably not the first time on this exact issue actually... I'll learn eventually).
    -CP
    2017 Q7 3.0t
    Dec 28 2006
    Western Maryland
    I edited my original post as you were responding. I don't recall ever reading about lean codes from the Genesis 380's but I do recall someone commenting about smoother performance with the TT's coupled with the APR 1+. They have certainly been flawless with my GIAC 1+.
    Jun 27 2011
    I think it was a quirk with the APR 1+ tune. Hence my disclaimer about it not working perfectly with their tune.
    -CP
    2017 Q7 3.0t
    Nov 14 2006
    Noblesville, IN
    You guys are all bad influences. I'm going to end up buying myself a early Christmas gift and probably splurge on the complete ECS kit w/injectors and 1 program APR tune. So, rather than paypal donations, those of you that have ECS gift cards with minimal balances, send them to me and I'll complete a full DIY on the whole install.
    Nov 14 2006
    Noblesville, IN
    Looks like a deal....
    http://www.ebay.com/itm/Ko4-015-turb...#ht_500wt_1204
    Only question is, APR k04 tune is the only thing that would be needed, right?
    Jun 27 2011
    GIAC, REVO, APR, etc all make K04 specific tunes. I would pick whichever shop is closest to you. If you are already tuned you could stick with the same company and upgrade the tune for cheap usually.
    I would ask what brand that K04 is also before you pull the trigger. Be very wary of Fleabay turbos.
    -CP
    2017 Q7 3.0t
    Nov 14 2006
    Noblesville, IN
    I know there's a GIAC dealer about an hour from me. Need to call them up tomorrow and figure out how much the tune is.
    Jun 27 2011
    You should also look into this: LINK
    Only $4500+. Totally reasonable....
    -CP
    2017 Q7 3.0t
    Oct 11 2011
    '19 Mustang GT
    Virginia
    This
    I would definitely check what brand it is. I'm guessing that it's probably a cheaper chinese one, but I could be wrong. If it's a KKK turby, then that's a great deal.
    Oct 11 2011
    '19 Mustang GT
    Virginia
    Is the tune on par or close to factory smoothness? That's the reason I've leaned more towards the APR. I've always read that they are super smooth and feel close to factory.
    In any case though, I'm going to have to drive a few hours no matter what tune I decide, so I'm open for suggestions. Thoughts everyone?
    Apr 06 2009
    The StL
    [QUOTE=Charles.waite;7128644] LINK
    QUOTE]
    holy shit-- what a monster
    ...do they have layaway?
    Oct 13 2008
    Da Bay
    I have a used k04 and tt225 injectors and tt225 MAF available if you want to go the used route.
    Nov 14 2006
    Noblesville, IN
    Doesn't look like a true Ko4 to me.
    Oct 11 2011
    '19 Mustang GT
    Virginia
    I replaced the 710N today with the new one I got from ECS Tuning, and while it feels just faintly stronger (probably in my mind to be honest), the problem is still there.
    I drove up to a local grocery store today on the way home from my parents (where I installed the 710N). There's a retaining wall and it's a decent uphill grade, so I rolled the windows down to listen to the turbo. When the turbo starts to spool (2k-3.5k rpm), instead of being the normal sssssshhhhhhhhhhhhhhh noise that a turbo's suppose to make, it makes more of a shdddshdddshdddshddd noise (like if you pulsated the normal spooling sound).
    Here's my idea. I forgot to send my address to Wally for the N75 with the Paypal message, so it'll be a few days till it gets here. So, I thought about eliminating the N75 by connecting the two hoses from the compressor (pressure side) and the wastegate, and testing it to see if that corrects the problem. If the N75 is the problem, then theoretically, this should correct the problem, right?
    I've searched a lot of post tonight about removing the N75 and how the boost will be on/off, but other than that, will there be any negative issues?
    I also know that it'd just boost to the stock wastegate pressure, but even if it was 10 psi, then it wouldn't be bad as long as I could drive the car without worrying about screwing it up. While I'm talking about stock wastegate boost pressure, what is it? I'm searching as we speak, but not coming up with anything.
    EDIT: Just came across something will searching. Where the car is still 'stock' tuned, if I eliminate the N75, will it throw the car into limp mode?
